Old 06-05-2009, 09:45 AM   #1
98Saturn
98Saturn is on a distinguished road
Default Wheel Bearing seems OK
I have a 98 Saturn with 103k miles. I put new tires on the car a few months ago, and I noticed afterwards that there appeared to be some road noise. I just assumed it was the tires. Two weeks ago, I had a new clutch installed, and they mentioned that the front wheel bearings were shot. I read through everything I sould find (Thanks Twin Cam for the excellent instructions) to learn more about how to diagnose.
Sure enough, when I turned left, the noise would get louder, and would go away when I went straight or turned right. From other threads, I surmised that this was due to a bad right front wheel bearing.
I loosened the halfshaft bolt (slightly) and removed the wheel and brake calipers and torque plate. With lots of free room, I tried wiggling the hub to see how bad it was, but the only movement I can get is the small bit of turn (rotation around the axis of the hub) from the play of the transmission.
Any ideas as to what could cause this? Is it that I can't generate enough force across the small diameter of the hub to really see the play? I am sitting here with everything I need to change the hub/bearing (12 ton press, Harbor Freight adaptors, new hub, etc....)
I'd rather not pull the steering knuckle off I don't have to, but should I just replace it since I'm over 100k miles and have everyhing?
I'm still a novice at at lot of this, and I'm wondering what is more dangerous.. Me replacing the hub, or letting it go.
98 SL2 w/130k miles driven and another 30k+ towed with my RV
Purchased new in South Carolina, survived 9 years in Vermont, now putting up with traffic in Northern VA.
Add to 98Saturn's Reputation
Rate the quality of this post and help 98Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
98Saturn is offline   Reply With Quote
Old 06-05-2009, 09:57 AM   #2
mr18436572
mr18436572 is on a distinguished road
2000 SL2
Default Re: Wheel Bearing seems OK
Another way I use to diagnose wheel bearings, to determine exactly which side is bad - with the car in the air and in neutral, rotate each front tire with one hand while wrapping your other hand around one of the coils of the spring. The side with the bad bearing will transfer the vibrations from the bearing to the spring to the hand and it should be pretty noticeable.
2000 SL2 auto - 167k - sold
1996 SL2 auto - 161k - sold
1997 SC2 auto - 105k - sold
2000 SC2 auto - 117k - sold
1996 SL2 auto - 250k - sold
2001 SC2 5sp - 160k - sold
Add to mr18436572's Reputation
Rate the quality of this post and help mr18436572 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mr18436572 is offline   Reply With Quote
Old 06-05-2009, 10:28 AM   #3
98Saturn
I tried rotating the wheels with my hand on the springs, but there was almost nothing coming through the spring. Slightly more on the left side (which still had the brake pads, etc. attached) than on the right (which had the wheel and rotor, but I didn't remount the brakes.
Any other suggestions? I may just button everything back up and see how it works. It just kills me that I spent $200+ to make sure I had everything (tools and parts) I needed to bang through this, and it looks like I jumped the gun.
Old 06-05-2009, 11:04 AM   #4
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
Try another $5-10 at Harbor Freight for a stethoscope. These bearings can get pretty bad before they evidence any "play". It's also better to check for play with the wheel/tire on, since it acts as a bigger "lever".
Add to madpogue's Reputation
Old 06-05-2009, 11:48 AM   #5
fetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nice
1997 SW2
They don't always get louder when turning left either. Stupid thing. Let mine go a couple of months before doing anything about it as I couldn't decide it actually was the bearing. It'd make a noise when turning left, or going straight but not when turning right Now it's all better, except for the ABS codes Low Saturn hasn't had the chance to look up for me
My collection of S-Series info: "https://drive.google.com/folderview?id=0B5D8XfJgavxrdE5mcHBlMG5rbUU&usp=sharing" (copy & paste between quotes)
Old 06-05-2009, 12:15 PM   #6
98Saturn
Thanks for the advice. If you don't think it is life or death, I'll swing in to Harbor Freight next week and grab the stethoscope as madpogue suggested.
Old 06-05-2009, 10:49 PM   #7
Growser
Growser is on a distinguished road
Growser's Avatar
I have a fleet of Saturns, so I went to the pull your own junkyard and bought a pair of knuckles, purchased new BCA bearings/hubs from Rockauto and paid my local machine shop $40 to take out the old and press in the new bearings. That way I could do the job on an afternoon without running to a machine shop and now I have a spare set of knuckles for the next job. I'm a novice, too, but by searching this forum I replaced the hubs/bearings, outer tie rod, lower control arm, brakes and rotors, struts and springs (coil springs were broken) all the same afternoon. I figure with 165,000 miles on the car I hope this would be the last time any of those parts would need replacing (maybe not the brakes) and I might as well enjoy the ride/response of the new parts.
Just replace the bearings, if you think that's your problem you're probably right. Don't be intimidated, it really isn't that difficult of a job.
7 Saturn Car Family with + 900,000 miles.
2002 SL2, 2000 SL1, 1997 SC2, 1997 SC1, 1996 SC1, 1994 SC2, and now a 93 SC2 project car.
Add to Growser's Reputation
Rate the quality of this post and help Growser reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Growser is offline   Reply With Quote
Old 06-22-2009, 02:54 PM   #8
98Saturn
Growser,
You were right about this not being too difficult. I borrowed a press to try pressing out the hub/bearings, but after 2 hours of trying to remove the snap ring, I took the knuckle and hub to a local shop. Before I could finish mowing my front yard, the shop called and had the new bearing and spindle pressed in. Re-assembly was a piece of cake. Thanks to all who have posted information on front wheel bearings. In the future, I would not attempt the pressing myself, it was too easy to take it to the local shop. $48 to press out the old and in the new sure beats the $330 quote I was given by another shop for the whole thing.
Wheel bearing MikeNW S-Series Tech 6 07-05-2009 11:01 AM
Wheel Bearing? tmthomp L-Series Tech 10 04-20-2009 08:33 PM
Wheel bearing ? Maxwaxquad4 Vue Tech 7 06-23-2008 12:34 PM
wheel bearing help lansing78 L-Series Tech 0 01-06-2007 11:18 AM
Wheel bearing 94sl2guy S-Series Tech 12 12-23-2005 04:29 PM
