Old 06-04-2009, 04:46 PM   #1
rfranks
rfranks is on a distinguished road
Default About to change the transmission fluid
IS Castrol High Mileage Automatic Transmission Fluid ok to use in my 1996 sl2. I only plan on changing out 4 quarts and the filter. Thanks
Add to rfranks's Reputation
Rate the quality of this post and help rfranks reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rfranks is offline   Reply With Quote
Old 06-04-2009, 07:57 PM   #2
2NDSOUT
2NDSOUT's Avatar
1999 SL
Default Re: About to change the transmission fluid
I don't see any reason why it wouldn't be good.
However,
You will need to make sure that you find a comparable Dexron Level ( I think there is Dexron II, Dexron III, and Dexron IV)
If you check in your owner's manual it will tell you which Dexron level your car requires. Check to make sure the ATF is compatible. Obviously the ATF stuff made today is going to be better than it was in 96.
You will need to make sure to change the fluid and filter EVERY 25K-30K miles from now on....otherwise, plan on doing a Trans rebuild.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Old 06-05-2009, 11:02 PM   #3
Growser
Growser is on a distinguished road
Growser's Avatar
Many of the "high mileage" fluids have additives used to swell seals and gaskets. If you're not having a leak issue I would use another brand.
Use a Saturn OEM filter, and make sure you remove the magnet if there's one there. Take a look at this post: http://www.saturnfans.com/forums/sho...ilter+pictures
7 Saturn Car Family with + 900,000 miles.
2002 SL2, 2000 SL1, 1997 SC2, 1997 SC1, 1996 SC1, 1994 SC2, and now a 93 SC2 project car.
Add to Growser's Reputation
Rate the quality of this post and help Growser reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Growser is offline   Reply With Quote
Old 06-06-2009, 05:55 AM   #4
The Critic
The Critic is on a distinguished road
The Critic's Avatar
Castrol High Mileage has a much higher viscosity than most ATFs. The transmission was originally validated with Dexron-III (which no longer exists), but the Castrol HM ATF doesn't meet the viscosity requirement of the original Dexron-III fluid.
I would use a different ATF such as Valvoline Maxlife ATF. Preferably, I would use a Dexron-VI fluid if money was no object.
'10 Altima 3.5SR V6- 5k
'96 SL2- 150k!
'92 Previa- 99k
Add to The Critic's Reputation
Rate the quality of this post and help The Critic reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
The Critic is offline   Reply With Quote
Old 06-07-2009, 07:19 AM   #5
sdowney717
sdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of light
walmart sells lots of dexron 3.
I dont klnow what does not exist means.
Add to sdowney717's Reputation
Rate the quality of this post and help sdowney717 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sdowney717 is offline   Reply With Quote
Old 06-07-2009, 10:56 AM   #6
Special Forces
Special Forces has a spectacular aura aboutSpecial Forces has a spectacular aura aboutSpecial Forces has a spectacular aura about
Special Forces's Avatar
2006 ION Red Line
It's no longer on the market. It's not made. When the new Dexron came out it said to discontinue the Dexron 3 use. The newer ones are better for whatever reasons and go above the Dexron 3 level.
/// Need rebuilt valve bodies? PM Me. \\\
//// Why bother with ebay when I'm right here? \\\\\
Valve bodies built to order
Please PM me about valve bodies, do not post a visitor message.
Add to Special Forces's Reputation
Rate the quality of this post and help Special Forces reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Special Forces is offline   Reply With Quote
Old 06-07-2009, 04:00 PM   #7
The Critic
The Critic's Avatar
http://www.sandyblogs.com/techlink/2009/05/
'96 SL2- 150k!
'92 Previa- 99k
Old 06-08-2009, 09:07 AM   #8
Special Forces
2006 ION Red Line
Originally Posted by The Critic View Post
I believe that supports my claim.
Old 06-10-2009, 09:15 PM   #9
harryrs
harryrs is on a distinguished road
2000 SL
The link you provided was a great help to me. Many Thanks, Harry.
Add to harryrs's Reputation
Rate the quality of this post and help harryrs reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
harryrs is offline   Reply With Quote
Old 06-10-2009, 09:39 PM   #10
Manual Transmission Fluid in the manual transmission in place of the Dexron-3. That is what this part number (88861800) is.
TIP: Any vehicle that previously used DEXRON-III for a manual transmission or transfer case should now use p/n 88861800 (88861801 in Canada) Manual Transmission and Transfer Case Fluid. And power steering systems should now use p/n 89020661 (89021183 in Canada) Power Steering Fluid.
See this thread at BITOG.
http://www.bobistheoilguy.com/forums...Number=1112608
Amsoil ATD is the Torque-Drive
The bottom line is that the 100C viscosity of Dexron-VI is too low for use in the manual and may not be that great for the automatic either.
Old 06-10-2009, 10:09 PM   #11
The Critic
The Critic's Avatar
Completely FALSE.
The only reason why Dexron-VI is not recommended for manual transmissions is because GM chose not to revalidate Dexron-VI for a low volume application. Also, many of GM's manual transmissions are supplied by outside vendors who chose not to revalidate the transmissions with Dexron-VI.
Dexron-VI is better than Dexron-III(H) in terms of viscosity retention. Even though Dexron-VI starts out a 6.0, it stays there. With Dexron-III(H), it starts out at 7.4 but it will shear down to 5.5 or less very quickly.
'96 SL2- 150k!
'92 Previa- 99k
Old 06-10-2009, 10:26 PM   #12
Completely FALSE.
That is true but the 6.0 is too low of a viscosity. The problem with Dex-3, either the original or the 2nd version of the spec is that it is not viscosity stable. The original Dex-3 spec was OK for the manual but the 2nd was borderline low and Dex-VI is too thin to start. there are/were several Dexron-3 specs and they all had viscosity stability problems and film strength problems. This is also how/why you blow a diff pin, film failure and subsequent pinion weld to pin. Anybody can look at the numbers of either fluid and see that the Dex-VI has a lower viscosity. That is why GM stated to use a different part number. Everyone of these transmissions that were originally speced for a Dexron-3 type fluid have shifting issues with the Dexron-VI, no matter who manufactured the transmission. This pertains primarily to the manual transmissions but some of the automatics respond very well to a higher viscosity fluid also.
Old 06-10-2009, 10:44 PM   #13
The Critic
The Critic's Avatar
Again, not true.
I have a contact at GM who is one of the developers of Dexron-VI and he answered all of those concerns.
The issue is simply with revalidation of Dexron-VI on certain platforms.
If Dexron-III(H) shears down BELOW 6.0 within 5-10k miles, what good does it do to have a higher starting viscosity?
Also, the film strength of Dexron-VI is actually 20% higher than Dexron-III.
I would be happy to forward your questions to my contact at GM to answer if you wish.
'96 SL2- 150k!
'92 Previa- 99k
Old 06-10-2009, 11:05 PM   #14
I disagree.
The original cert was for a viscosity in the 7 range. The fact that the Dex-3 shears down in a hearbeat is not the issue. The trans was designed to shift properly with the aid of the hydraulic coupling of the synchros. Hence the reason for a heavier fluid, but not too heavy either. Every one of these ZF take off transmissions has shifting issues with thin fluid. The Dex-6 is too thin at 6.0 even if it stays at 6.0 for ever. The transmission will shift poorly and that is the issue.
You can spend hours reading up on all of the stuff people have poured into these transmissions trying to get them to shift right. Once the clutch material is worn down nothing but mechanical overhaul will fix them. When the synchro clutches are in good condition then if you pick the right fluid they work. And even when worn they work better with the design viscosity fluid.
Old 06-10-2009, 11:11 PM   #15
The Critic
The Critic's Avatar
I disagree.
Could you please explain further?
If the transmission was designed to shift properly with hydraulic coupling of the synchros, then the transmission testing was validated using Dexron-III(G) or Dexron-III(H) for an extended period of time. Transmissions are validated for at least 100,000 miles, if not 150,000 or more. During the validation testing, the fluid would have sheared down well below 7.
Again, Dexron-VI was not revalidated in Manuals, but at least in automatics, clutch wear was improved significantly with Dexron-VI.
'96 SL2- 150k!
'92 Previa- 99k
Old 06-10-2009, 11:56 PM   #16
An automatic is an entirely different issue, apples and oranges.
When you do these lab experiments to validate a lubricant you start with new components and operate them according to the design. What that boils down to with a manual is you do not operate it like you were driving in a 24 hour road race and your brakes have failed. The manual in most of the Saturns is over 100,000 miles and has suffered some operator inflicted abuse. So what will work with a properly used/operated transmission might prove marginal with what you find in the wild.
With a low viscosity the clutch has to do more to gain sync speed and the synchro teeth tend to wear along with the clutch facing. Both of these make for blocked shifts and/or difficulty in shifting between gears rapidly.
By increasing the viscosity you gain an increase in the hydraulic coupling between the synchros before the clutch contacts the cone. It works the same way the torque converter works. The torque converter is totally a hydraulic connection until it is locked. If you are familiar with the behavior of an automatic when it is cold you may have noticed that it tends to be harder to hold it stopped when in drive until it warms up. This is why the "oil cooler" is located in the radiator. Tends to maintain a constant oil viscosity/temperature.
This is why that Tech Link article recommends a different fluid for the manual transmissions that were originally speced for Dex-3. That is also true for a long list of GM products. Do a search on GM 88861800. Every one of these transmissions has had shifting complaints using any of the revised Dexron-3 fluids. The first revision did not get a letter either, IIRC. FYI, Saturn is speced for a Saturn transmission fluid first and Dex-3 is acceptable if the preferred is not available.
The quest for ever increasing fuel economy will result in reducing the viscosity of all lubricants.
Old 06-24-2009, 12:01 AM   #17
The Critic
The Critic's Avatar
I have yet to read about any shifting complaints with the revised Dexron III fluids.
I still stand by what I said-- the main reason why GM has a manual transmission lubricant for use in automatics that originally called for Dexron III(H) is because Dexron-VI was not revalidated in these applications.
I'll call my contact at GM this week to see if I can get anymore info, and I'll be happy to put you in touch with him as well.
'96 SL2- 150k!
'92 Previa- 99k
Old 06-24-2009, 01:24 AM   #18
plasticoupe
plasticoupe is on a distinguished road
Out of the blue, but related... someone posted that the diff section of the TAAT automatic trans is identical to the diff section in the 5-speed. True? And if so, is that a sealed-off and separate section of the TAAT automatic transaxle, or does it just use the same Dex III, nee Dex VI, as the transmission section? Any special drain or fill precautions? Hot tips to avoid throwing out the diff pin/trashing the trans?
TIA
J.R.
'01 SC2
SoCal
Add to plasticoupe's Reputation
Rate the quality of this post and help plasticoupe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
plasticoupe is offline   Reply With Quote
Old 06-24-2009, 02:14 AM   #19
Fox Slaughter
Fox Slaughter is on a distinguished road
Fox Slaughter's Avatar
Get your pin welded or get a Quaife LSD?
I'll be sitting at my desk
With a gun in my hand, wearing a bulletproof vest singing
"My, my, my, how the time does fly, when you know you're going to die
By the end of the night."
Add to Fox Slaughter's Reputation
Rate the quality of this post and help Fox Slaughter reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Fox Slaughter is offline   Reply With Quote
Old 06-24-2009, 02:19 AM   #20
quantumech
quantumech is on a distinguished road
TIA
I imagine someone will correct me if I'm wrong, but the differential and the transmission are in the same compartment, and use the same fluid. If you drain the transmission fluid, the differential will not have fluid in it. This is why you need to remove some fluid to check the diff pin through the VSS port. I believe it's been stated previously that the differential between the auto and manual are the same. But, I'm going from memory, and there's alot going on up there.
For filling the transmission, just make sure your funnel leaves an air escape hole. It's pure physics...you're displacing the air that is in there after the draining, and it needs to go somewhere. If you don't, it's bound to "belch" up at you, which isn't any fun. That's only fun if it's liquid nitrogen...ah, I miss those days filling the detector (man, I need a job).
Don't drive like you're on the drag strip, and you shouldn't throw the pin. Well, be less likely to do it anyway.
Sasha: 2000 SL1, Manual, 130,500 miles 5-18-2014.
I learn from my experiences. If I screw up, I'm sorry.
Add to quantumech's Reputation
Rate the quality of this post and help quantumech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quantumech is offline   Reply With Quote
How to change transmission fluid in VUE with manual transmission David 93 SL2m Vue Tech 35 06-30-2017 06:47 PM
5spd Transmission Fluid Change - Fluid? Satsational S-Series Tech 17 10-20-2008 05:57 AM
122,000 miles on transmission with no transmission fluid change in car's history. foo General Saturn Discussion 10 04-22-2008 05:04 PM
Change transmission fluid? gws35 Vue General 6 05-20-2007 04:44 PM
transmission fluid change 93 saturn sl2 S-Series Tech 32 07-14-2005 11:41 AM
