#1 | ||||
![]() Join Date: Jun 2009
I have a Saturn Ion 2004 5 speed Does any know where the bleeder screw for bleeding the clutch is
Or procedure to bleed clutch help would be appreciated.
#2 | ||||
![]() Join Date: May 2009
2006 ION-2 Sedan
isnt it on the slave cylinder hose. its got a rubber nipple over it.
... GET MONEY$$$$
#3 | ||||
this one is driving us crazy, the clutch wont bleed out but were having a problem finding the bleed port according to the dealer there's a 9mm bleeder screw some where on the slave/hydraulic line. we see a nipple with a rubber cap on the slave cyl but it doesn't have bleeder screw ( picture included)
#4 | ||||
![]() Join Date: Feb 2009
there is a bleeder screw in an acess hole where the hydraulic line goes in the trans, if that doesnet work which half the time it dosent, youll have to use a mighty vac on the fluid resivoir that always does the trick
... Certified Saturn Technician
#5 | ||||
![]() Join Date: Mar 2006
2005 ION-2 Sedan
isn't the clutch fluid shared with the brake reservoir on the ion? if that's the case, can't you just bleed the brakes?
#6 | ||||
Thank you gentlemen another source tole me had to use mighty vac. Have to go and find book to see how to connect Mighty vac.
#7 | ||||
The bleeder is at the transmission where the line goes into the bell housing.
Better method is to vacuum bleed the system from the master. You do need a good air tight fitting do do this though. ... A lousy day in paradise is still a day in paradise.
| Thread Tools | |
| Display Modes | |
| Bleeding clutch | arendsg | S-Series Tech | 13 | 06-04-2009 03:07 PM |
| clutch bleeding | RobertGary1 | S-Series Tech | 2 | 06-03-2009 12:48 PM |
| Clutch Bleeding? | Brock4u | Vue Tech | 0 | 04-16-2008 07:28 AM |
| bleeding clutch | 92sl24ya | S-Series Tech | 10 | 02-21-2004 06:46 AM |
| clutch bleeding | 94sc2boy | Miscellaneous Tech | 1 | 10-27-2000 10:01 PM |
