Old 06-03-2009, 02:50 PM   #1
a7x_audiojunkie
a7x_audiojunkie is on a distinguished road
Wrench Turn signals don't work, hazards do
1997 SL1; 1.9L DOHC/EFI
I got in a crash, and busted up my headlights. I have new parts and got it back together today. On the right turn signals, the brown wire was cut in the crash, but i spliced it (the bulb was also broken).
At that point, my left blinkers worked, and my right rear worked, but flashed very fast. Now that I have all working bulbs in and wiring fixed, NEITHER will work. Not even a ticking from the control panel. I checked fuses and everything seems fine.
Anyone know what is going on here?
Add to a7x_audiojunkie's Reputation
Rate the quality of this post and help a7x_audiojunkie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
a7x_audiojunkie is offline   Reply With Quote
Old 06-03-2009, 03:10 PM   #2
a7x_audiojunkie
Default Re: Turn signals don't work, hazards do
So they work fine when the car is running it seems... I guess I never payed attention to whether they worked without the car running before. If they ARE supposed to work, feel free to reply, otherwise, my bad I guess
Old 06-03-2009, 05:03 PM   #3
They aren't dependent on the engine running. The key needs to be in the RUN position.
Add to madpogue's Reputation
98 sl2 - turn signals not working / hazards working normal Jetfixer10 S-Series Tech 14 10-31-2016 04:10 PM
Turn signals not working. Hazards work cwills2 L-Series Tech 17 03-20-2016 08:37 PM
sc turn signals and hazards wont work faf112 S-Series Tech 4 03-20-2016 07:07 PM
94 SL2, hazards disable turn signals My Range S-Series General 3 11-21-2005 06:53 PM
turn signals and hazards just stopped working renadena S-Series General 6 05-14-2005 04:14 PM
