Old 05-31-2009, 01:38 AM   #1
EXCALIBER12
EXCALIBER12 is on a distinguished road
Default Idle accelerates on its own
Hi Helpers,
I have a 2002 SL2 manual 5 speed with around 100,000 miles. My car has a problem idling. Everyday at various times the car will jump to an idle of around 1700 RPM's. The only way to get it down is to shut the car off and restart it. The engine light never comes on and I have an OBDII reader which reads no errors either. I haven't tried anything yet to fix it except to changes the plugs, wires, and air filter. Does anyone have any suggestions??? Thanks in advance
Add to EXCALIBER12's Reputation
Rate the quality of this post and help EXCALIBER12 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
EXCALIBER12 is offline   Reply With Quote
Old 05-31-2009, 01:44 AM   #2
Number6
Number6 is on a distinguished road
Default Re: Idle accelerates on its own
I was getting an elevated idle like that before I cleaned my EGR valve. But I was getting a code thrown too.
Add to Number6's Reputation
Rate the quality of this post and help Number6 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Number6 is offline   Reply With Quote
Old 05-31-2009, 07:37 AM   #3
rickystarshine
rickystarshine has a spectacular aura aboutrickystarshine has a spectacular aura about
rickystarshine's Avatar
2005 ION-2 Sedan
With the car running, open the hood & locate the Throttle Position Sensor or TPS, Tap on it lightly with the handle of a screw driver or similar, if the idle changes, you need a new TPS, I went through 4 of them in my 2001 SL1 & when they go bad, they don't always throw a code.
2005 ION 2 5 spd 202,155 miles
2001 SL1 Auto 298,252 miles
1997 Sl1 Auto 163,266 miles
Add to rickystarshine's Reputation
Rate the quality of this post and help rickystarshine reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rickystarshine is offline   Reply With Quote
Old 05-31-2009, 08:35 AM   #4
a427847
a427847 is on a distinguished road
In the same throttle body assembly as the throttle position sensor is the idle air control valve. Check that out too.
Add to a427847's Reputation
Rate the quality of this post and help a427847 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
a427847 is offline   Reply With Quote
Old 05-31-2009, 11:37 AM   #5
TPS is the more likely suspect. The signal is read by the PCM "relatively", so when you shut it off and re-start it, it's like re-booting Windoze; the PCM gets a fresh signal and everything returns to normal, for a while. Classic bad TPS symptom.
Add to madpogue's Reputation
Old 05-31-2009, 03:50 PM   #6
velleguy73
velleguy73 is on a distinguished road
2001 SL
2002 SL
Some light reading.
http://www.saturnfans.com/forums/sho...lve%2Fdiagnose
Add to velleguy73's Reputation
Rate the quality of this post and help velleguy73 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
velleguy73 is offline   Reply With Quote
Accelerates on it's own SaturnFixer S-Series Tech 8 12-27-2009 12:21 PM
Press Release: GM Accelerates Its Reinvention as a Leaner, More Viable Company Charlie General Saturn Discussion 3 04-27-2009 10:58 PM
My 1996 SL2 accelerates really slow recently. mw44118 S-Series Tech 2 08-06-2008 11:12 AM
idle idle idle idle idle idle (dead) nocolourblue S-Series Tech 23 12-29-2006 02:08 PM
Car accelerates by itself!!! amazinghl Miscellaneous Tech 16 03-31-2004 12:10 PM
