Old 05-30-2009, 09:40 AM   #1
mysticpc
mysticpc is on a distinguished road
mysticpc's Avatar
Default Tranny Help
Have a 97 SC2 with 159k miles. Everything is fine until you reach highway speeds and then the car starts blowing trans fluid all over the exhaust. At 35 mph or less, it doesn't leak a drop. Just wondering if anyone has seen this before or has any suggestions short of pulling the tranny.
Thanks!
Add to mysticpc's Reputation
Rate the quality of this post and help mysticpc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mysticpc is offline   Reply With Quote
Old 05-30-2009, 03:58 PM   #2
Default Re: Tranny Help
Um, elephant-in-the-room question -- automatic or manual?
If it's an automatic, the one place where I could imagine it blowing fluid under certain pressure would be the cooling lines that go to the radiator.
Add to madpogue's Reputation
Old 05-30-2009, 09:06 PM   #3
mysticpc
mysticpc's Avatar
Dizzy Re: Tranny Help
Sorry, it is an automatic. Checked the coolant lines and that's not it. The fluid appears to be coming from the torque converter area. I've read about the differential pin coming loose and knocking a hole in the case but wouldn't that leak all the time?
Old 04-01-2013, 03:17 PM   #4
Michæl70
Michæl70 is on a distinguished road
Default 1997 saturn sc1 same problem
Hi
My 97 saturn sc1 sohc is doing the same thing. trans cooling lines are fine. Its not made any strange noises. But it will spot while sitting and blow fluid while going down the road. it is and automatic also.
Add to Michæl70's Reputation
Rate the quality of this post and help Michæl70 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Michæl70 is offline   Reply With Quote
Old 04-01-2013, 04:14 PM   #5
If it's "spotting" while sitting (sounds like a cat with a kidney problem....), start with the obvious external stuff - filter, drain plug, those sensors by the filter. If that's all dry, check the mating between the tranny and engine; a leak there could be the torque converter, or the diff pin has internally poked a hole in the case and it's leaking into that space, and out through the seam.
SW2 Tranny to SL1 Tranny? will it fit? victor S-Series General 12 09-27-2009 08:42 PM
Auto tranny to manual tranny p8ntballsniper8 S-Series General 4 04-27-2009 06:26 PM
New Tranny Solenoid $37 New Tranny Valve Body: 460.00 greasemonkey26 S-Series Tech 2 08-10-2008 07:06 PM
Sl tranny to Sl2 tranny Dro S-Series Mods 2 02-15-2008 04:02 PM
V6 tranny 06vueawd Vue General 1 10-06-2006 08:50 AM
