#1 | ||||
![]() Join Date: Sep 2004
2001 L-Series 3.0L Sedan
2002 L-Series 2.2L Sedan
I just replaced all 4 struts in about an hour on my mom's saturn. The rears were leaking so i did all 4. When i first did the stabilzer links on my Saturn L300 I did the fronts incorrectly. Well not incorrectly but made my life a little harder. When trying to remove the STABILZER Links. DO NOT remove on side of the stabilzer link first. Remove the top bolts on both sides before removing the bottoms. Because it will torque against u because it's attached to each others side by the sway bars. And once u remove both top bolts and pop them the tops out you can then push the stabilzer link all the way down to have easy access to them.
| Thread Tools | |
| Display Modes | |
| Auto Trans End Cover Replacement Tip | sgoti | S-Series Tech | 0 | 05-08-2009 07:04 PM |
| sprints are on + strut removal tip | meatshieldd | Vue Mods | 9 | 09-12-2007 08:04 PM |
| Lower Auto Transmission Mount replacement tip | hydromech | S-Series Tech | 0 | 08-05-2007 09:44 AM |
| Transaxle Input Shaft Nut Replacement Tip | JohnHupp | How-To Library | 1 | 09-16-2005 01:50 PM |
| 93 sc2 Radiator replacement tip.... | plum_sc2 | S-Series General | 4 | 12-26-2004 11:52 PM |
