Old 05-17-2009, 02:01 AM   #1
Triggamane
Triggamane is on a distinguished road
1999 SL1
Dizzy Vehicle Speed sensor replaced and still throwing code.
My speedo does not work and the car doesnt shift right it shifts hard and the service engine light is on because it has no output from the VSS. I replaced the VSS and reset the computer by disconecting battery for at least a half hour. Still no speedo and after 3 mins of driving Service engine ligth comes back on. Where do i start? I already looked at the wires an they look to be in good shape th eplug and everthing are clean. There is also only 1 wire coming out of the plug for the vss. Any help please i need my car to pass inspection.
Add to Triggamane's Reputation
Rate the quality of this post and help Triggamane reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Triggamane is offline   Reply With Quote
Old 05-17-2009, 07:05 AM   #2
Default Re: Vehicle Speed sensor replaced and still throwing code.
What year and model car will help a bit There are 2 speed sensors, which one did you replace? There is one by the oil filter on the transmission and one on top of the differential area above the axles. What code number are you getting?
Old 05-17-2009, 08:02 AM   #3
eljefino
eljefino's Avatar
1995 SW1
The VSS has two wires. Either you're looking at the backup light switch or a wire got pulled out.
Also look at the wire color (x with x stripe) and post that here... IIRC there's another wire that has the same connector that can get screwed up.
Add to eljefino's Reputation
Old 05-17-2009, 10:54 AM   #4
Reverse light switch functionality is part of the selector switch, which has a bunch of wires coming out of it. (Reverse light circuit has two wires anyway.) There's only one VSS, located on the top of the tranny. The sensors on the front of the tranny are the TSS (turbine speed sensor) and TTS (tranny temp sensor). AFAIK, they all have two wires. If you have a sensor connector on the tranny with only one wire, I'd say that's your problem; a wire has pulled out of the connector. That was probably the problem in the first place, and, pardon me for saying this, an example of how testing and referring to documentation are cheaper than throwing parts at it.
Add to madpogue's Reputation
Old 05-17-2009, 11:48 AM   #5
The VSS and the TSS are the same type of component. Hence the question, which one was changed? And did it have 2 wires in the connector?
Old 05-17-2009, 01:02 PM   #6
Triggamane
1999 SL1
Attention Re: Vehicle Speed sensor replaced and still throwing code.
Ok well it is a 1999 sl1. The sensor in the front of the tranny under the tranny filter has two wires a red with black stripe and a blue with white stripe. The two sensors on the front and back appear to be identical so i replaced both of them. That could be a problem from what im hearing. The sensor in the back of the tranny above the axle has only one tan colored wired. The plug that plugs into it is capable of holding two wires but where the other wire would be at in the plug is a rubber plug that looks like it belongs there. Like if it had another wire and it pulled out it would be just an empty hole instead of having a rubber plug in there. I do not know the code number but when i have them plug it in it says no output signal from the vehicle speed sensor. Thanks I kno you guys will help me figure this out. I also know that this trannsmission is the one that came with the car and the motor is out of an sl1 but it had been replaced before I ever got the car so who knows if that is related.
Old 05-17-2009, 01:58 PM   #7
Brain farting at the moment. Can't remember for sure. Check the connector that goes to the oil pressure switch, at the oil filter area. See if it looks like the connector to the VSS and see if it has two wires. If it does swap them.
Add to ssicarman's Reputation
Old 05-17-2009, 02:07 PM   #8
Triggamane
1999 SL1
It has two wires on it but it is not the same type of plug
Old 05-17-2009, 02:08 PM   #9
Triggamane
1999 SL1
The speed sensor on the front of the tranny that is under the transmission filter has the same type plug and two wires on it tho.
Old 05-17-2009, 02:31 PM   #10
The VSS back by the axle has 2 wires a yellow and a purple. You are looking for a plug with those color wires.
Old 05-17-2009, 02:31 PM   #11
Oil pressure switch on your 99 should only have one wire. Lacking pictures are you able to plugswitch the connector on the oil switch into the VSS? If not then check the back of the engine area for plugs that can swap.
Any engine work done that would have needed things unplugged in recent memory?
Old 05-17-2009, 03:06 PM   #12
Triggamane
1999 SL1
Thumbs Up Re: Vehicle Speed sensor replaced and still throwing code.
ssi car man you solved my problem thank you so much you saved me. what had happened was somebody before me just swapped th emotor so when they were plugging back in the harness they mixed up the plugs apparently. thank you so much very much appreciated.
Where is the vehicle speed sensor? 2sweetcheeks S-Series Tech 5 08-18-2016 04:01 AM
L300 Vehicle Speed Sensor Urbanrover L-Series Tech 2 03-22-2005 09:46 AM
Vehicle speed sensor. dday S-Series General 23 03-19-2005 11:27 AM
Vehicle speed sensor wire? BlueDevil Vue General 10 06-22-2004 02:03 PM
vehicle speed sensor (VSS) dohc 97 S-Series Tech 4 04-07-2002 05:31 PM
