Old 05-13-2009, 07:23 AM   #1
Roushy
Roushy is on a distinguished road
Default Check Engine Reset!!!!
I noticed my gas cap has been recently becoming more and more loose after each fill. Basically after 4 years the plastic on the cap is wearing down. On Sunday after my fill-up my Vue threw a CE Light. I figured it was the cap because it didn't even tighten.... just spun. I went to NAPA and picked up a replacement cap. They had a direct replacement and not a "Univseral" replacement cap.
Check engine light is still on. I ran an ODBII scan and found nothing. I disconnected the negative on the battery and its still there. I read on some websites there is a method of resetting through the fuse box but I can't find anything that says "Reset" on it.
I have a 2004 Saturn Vue (4 cyl).
Any help???
Add to Roushy's Reputation
Rate the quality of this post and help Roushy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Roushy is offline   Reply With Quote
Old 05-13-2009, 07:34 AM   #2
wolfman
wolfman's Avatar
Default Re: Check Engine Reset!!!!
If it was indeed the cap, the light will go out on its own within a few days or so (depending on your driving habits) when the PCM see's the condition is absent through enough ignition cycles.
Add to wolfman's Reputation
Old 05-13-2009, 07:38 AM   #3
Roushy
Yeah this has actually happened before. Ran the CE Light for a few days and it went away. I just didn't know if there was a way to reset the light rather than wait 4 days. I see the CE Light and I think "BOOM" instead of just the gas cap
Old 05-14-2009, 11:22 AM   #4
Roushy
Default Update:
UPDATE: I checked the codes at 2 different places and both said there are 0 errors in the car. Neither of them could clear the warning light because there was nothing to clear. They suggested going to the dealer but I know Saturn would probably hose me.
My gas cap was loose when the light went on and I replaced the gas cap with a NAPA Auto Saturn Replacement Cap. Drove about 40 miles since the light has come on, about 30 since it was replaced.
Thoughts?
Old 05-14-2009, 11:45 AM   #5
far2grumpy
far2grumpy's Avatar
Default Re: Update:
Thoughts?
It's probably a GM - Saturn specific code not readable by standard OBDII devices ... use this link for more information on similar problem:
http://www.saturnfans.com/forums/sho...ight=CEL+CODES
BTW, I've read somewhere - some vehicle - CEL's caused by loose/defective gas cap may clear after 40 to 50 ignition cycles.
I did a quick check of Saturn documentation and have not found - yet.
Old 05-14-2009, 12:03 PM   #6
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
When you disconnected your battery, how long did you leave it disconnected for? Did you do anything while the battery was disconnected?
On other vehicles, sometimes you have to wait 15 minutes after you've disconnected the battery for the ECU to lose all remaining power and reset itself. Or applying the brakes a bunch of times that will speed up that process. I've also heard that if you touch the negative battery cable to the positive cable, that will also work.
Not a Saturn.
Add to Tom92SCm's Reputation
Old 05-14-2009, 12:05 PM   #7
Roushy
I read that if the gas cap was loose or defective that a new cap wouldn't simply remove the error. The drive cycle is a high speeds for a few minutes with accel and decel. I don't even get above 45 on my way in to work and back so I am going to take a highway route home and see what happens.
The other thread was informative but didn't really give me an answer.
Thanks for the help though!
Old 05-14-2009, 12:06 PM   #8
Roushy
I waited about 3-5 minutes once the negative was disconnected. Should I wait longer?
Old 05-14-2009, 12:20 PM   #9
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
Try it again waiting 15 minutes while you pump the brake pedal a few times.
Not a Saturn.
Old 05-14-2009, 12:38 PM   #10
Roushy
I will try that and let you know!
Old 05-15-2009, 06:52 AM   #11
Roushy
Solution: I did remove the negative and let it sit for about 30 minutes. Before I reconnected I noticed the clock was still on so I hit the breaks a few times and the clock when out. Reconnected and everything is fine.
Thanks everyone!
Old 05-16-2009, 03:17 PM   #12
Nelsonspride
Nelsonspride is on a distinguished road
yeah u get like a metal piece of wire or etc disconnect both wires from battery and touch them together for like 15-30 seconds it can reset pcm or if they are able to touch together without a piece of wire be my guess
Add to Nelsonspride's Reputation
Rate the quality of this post and help Nelsonspride reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nelsonspride is offline   Reply With Quote
Old 05-16-2009, 03:57 PM   #13
guitarrick
guitarrick is on a distinguished road
Thanks everyone!
I had your answer but someone beat me to it! Happened to me in my Dakota that was stolen (replaced with a Vue ), only I left the gas cap on top of my toolbox and drove away. That light came on and drove me nuts! I just replaced the cap and reset the computer by killing the power for 20 minutes or so... You want to do a reset like that after doing anything to the motor, even after changing your air filter, spark plugs etc.
Add to guitarrick's Reputation
Rate the quality of this post and help guitarrick reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
guitarrick is offline   Reply With Quote
Old 06-18-2017, 08:10 PM   #14
Lava
Lava has a spectacular aura aboutLava has a spectacular aura aboutLava has a spectacular aura about
Check engine light came on ,,Went to AutoZone and tech did free computer diagnostic...
1.Discovered issue was with Canister Evaporator Purge Valve Solenoid ..
2.a Diagnostic printout suggests checking wiring .or
b.Fuel saturated vapor canister , or
c.Failed Evap vent solenoid ...or
Inspected closely and discovered that the protective wire wrap ( the style that is split along it's length had rubbed a small pin head size hole in the wire coating ..copper wire deteriorated and broke ...on one of the leads from the evap solenoid
Striped and soldered wire . then coated with liquid rubberized wipe on electric tape. two coats , and wrapped in electric tape ....
I went ahead and replaced the evap solenoid since the car was on the lift and the solenoid only cost $ 30.
Final : Disconnected battery , waited 30 minutes as suggested in this thread
Check Engine light reset and not visible ...
2007 SATURN ION 87,000 MI APPROX..
Add to Lava's Reputation
Rate the quality of this post and help Lava reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Lava is offline   Reply With Quote
Old 06-20-2017, 07:33 AM   #15
cjhsa
cjhsa is a jewel in the roughcjhsa is a jewel in the roughcjhsa is a jewel in the rough
lava: Do you remember what the code was exactly?
2007 VUE AWD V6 3.5L
Add to cjhsa's Reputation
Rate the quality of this post and help cjhsa reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cjhsa is offline   Reply With Quote
What is the "Drive Cycle" needed to reset the engine code ziprhead S-Series Tech 20 06-29-2015 04:38 AM
Check Engine Light(Serive Engine Soon) tugger75 S-Series Tech 12 07-08-2010 08:05 PM
Help! How do you reset engine lights on '04 Saturn L300? Statfreak101 L-Series Tech 9 06-30-2009 06:36 PM
reset service engine light liamsaturn S-Series General 1 05-30-2008 12:38 PM
Smog check code reset herrtodd S-Series Tech 3 01-18-2006 09:12 PM
