Old 05-08-2009, 09:51 AM   #1
thevaledic
thevaledic is on a distinguished road
Mad High idle problems 2001 SL1
Ive got problems with a high idle on my 2001 Saturn SL1, 92k miles. Upon starting it revs up to about 2500 RPMs and will slowly drop to normal. After the car has been running a few minutes, anytime it is put in park the idle will again shoot up past 2,000 RPMs. But when stopped in gear it is normal. Idle is slightly rough too, but high idle is more prominent. In addition the check engine light is on. Had the codes read at Autozone, they were P0301 (cylinder 1 misfire) and P0507 (idle higher than expected: duh!). Other threads I'm reading point strongly to vacuum leak. Any thoughts would be appreciated.
Add to thevaledic's Reputation
Rate the quality of this post and help thevaledic reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
thevaledic is offline   Reply With Quote
Old 05-08-2009, 10:14 AM   #2
OnDaGround
OnDaGround's Avatar
1993 SC2
Default Re: High idle problems 2001 SL1
Intake manifold is leaking. Spray water or brake clean around cylinder one on the manifold. If the idle changes you found the leak.
Saturnless...
Old 05-08-2009, 10:20 AM   #3
OnDaGround
OnDaGround's Avatar
1993 SC2
http://www.saturnfans.com/forums/sho...lve%2Fdiagnose
Read that. It's all about high idle.
Saturnless...
Old 05-08-2009, 10:29 AM   #4
rc1488
rc1488's Avatar
Intake manifold gasket replacement:
http://www.saturnfans.com/forums/sho...d.php?t=115925
Add to rc1488's Reputation
Old 05-08-2009, 10:51 AM   #5
OnDaGround
OnDaGround's Avatar
1993 SC2
Good stuff Rc. I'm gonna add that to my high idle thread that way it's in there for future peeps.
Saturnless...
Old 05-08-2009, 03:37 PM   #6
thevaledic
This is some good info, thanks. I have actually already tried the spray water test with no results. Is the brake or carb cleaner more effective in finding vacuum leaks?
Also, I must confess I'm a greenhorn about cars. I'm not even sure where the intake manifold is. I thought it was a big part that kind of looks like a hand with four hugely deformed fingers. That's where I sprayed the water. Again, another simple detail but one I'm not sure of...should I use the sprayer on a mist-like setting or a more focused stream?
I should also mention that I thought I heard a hissing noise near the top of cylinder 1, right below the power steering fluid reservior. But the guy at Autozone said it sounded normal. I can't be sure because I don't know what "normal" sounds like.
Finally, if it is the intake manifold gasket, according to other threads I've read here that is quite a difficult task, more than I can handle. So any ideas how much a reasonable shop would charge? Should I go to an all-purpose car repair place like Midas, or a genuine Saturn dealer?
Thanks again for any and all input.
2001 SL1 High idle - cant get ECTS clip off eriklane S-Series General 16 01-10-2010 04:00 PM
High Idle problems! Varopriest S-Series Tech 5 10-13-2007 11:34 AM
2001 SL1 high idle after cleaning Throttle Body rickystarshine S-Series Tech 6 11-19-2006 08:33 AM
2001 SC2 High Idle and Stall Problems 440sixPack S-Series Tech 0 03-20-2006 11:19 AM
2001 sc2 w/ a high idle Mean Green SC2 General Saturn Discussion 0 10-27-2004 09:56 PM
