Old 05-04-2009, 12:49 PM   #1
dbunch
dbunch is on a distinguished road
Default Fog Lights, Dashboard lights, Tail lights are not working
2004 Saurn Vue
AWD 6cyl
OUT OF WARRANTY
120,000
I got up the other morning and started the car and the main light on the Dashboard that lights up the Speedometer and everything else did not come on.
My fog lights don't turn on and it seems my Tail lights aren't working either.
I was told it was a fuse.. After looking at my fuse panel it looked like the fuse panel on the interior passenger side labeled IGN1 was the one.
But I pulled the fuse and it looks good.
Any other suggestions.
Thanks
Add to dbunch's Reputation
Rate the quality of this post and help dbunch reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dbunch is offline   Reply With Quote
Old 05-04-2009, 01:32 PM   #2
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
Default Re: Fog Lights, Dashboard lights, Tail lights are not working
Do your wipers work? If not, I suspect your BCM (Body Control Module) is bad.
Not a Saturn.
Add to Tom92SCm's Reputation
Old 05-04-2009, 03:25 PM   #3
far2grumpy
far2grumpy's Avatar
I'm in the boat with Tom92CM on this one.
Does the problem still exist?
If so, and you have no better offers, you could disconnect the battery ground cable for 10 to 15 minutes, then reconnect and see what happens. This has been known to clear confused BCM logic circuits - on a temporary basis.
Old 05-06-2009, 04:04 PM   #4
dbunch
Tom,
Yes the windshield wipers are working fine.
Old 05-07-2009, 07:41 PM   #5
Bismarck318
Location: Heart of the Rustbelt, AKA The Angry White Planet Ohth
Could it be a ground bus located under the carpet?? I'm unsure if Saturn did this, but past GM cars did this, poor design, problem would or could be intermitant.
Add to Bismarck318's Reputation
Rate the quality of this post and help Bismarck318 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-08-2009, 01:51 PM   #6
VTchemist
VTchemist's Avatar
A poster (a few years ago) described a similar problem. I thought I remembered his "grounding" contact has rusted away. It's in the rear of the VUE.
Might this be the case? Can you get under your VUE to inspect the various wires that are supposed to be grounding the wires.
If you can't, try this.
  • Access your wiring harness in the jack storage area.
  • Find the ground wire (green),
  • Run a wire from the green connector to a solid metal point on your body (you may have to scrap away a painted surface in the jack area).
  • Connect the wire and test the lights.
I uploaded a photo of the harness to this note.
Hope this is of help to you...
Add to VTchemist's Reputation
Rate the quality of this post and help VTchemist reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 03-05-2014, 10:01 PM   #7
mlloydlgt
mlloydlgt is on a distinguished road
dbunch,
I'm in the same here. I see this thread is old now, but did you find a solution?
no dash lights, no tail lights, but wipers work fine....
Tom,
Add to mlloydlgt's Reputation
Rate the quality of this post and help mlloydlgt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mlloydlgt is offline   Reply With Quote
Old 05-03-2015, 07:32 PM   #8
spectrum88
spectrum88 is on a distinguished road
2002 VUE 3.0L
i just ran into this situation because i recently pulled the combination switch out because it was damaged, thinking all the vues were the same, went to a local salvage yard and got one, got home plugged it in, nothing. only thing i get is blinkers, and low and high beam. so going to order a new one in hopes it works. it worked before should work again.
Add to spectrum88's Reputation
Rate the quality of this post and help spectrum88 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spectrum88 is offline   Reply With Quote
Old 10-10-2015, 04:33 PM   #9
leckster
leckster is on a distinguished road
tl;dr Check you PARK fuse in your interior fuse box.
Just want to update this thread with what worked for me. I had exactly the same problem, no Fog, no Dashlight, no idle rear lights (break lights work). I looked in the small fuse panel on the passenger side of the car and sure enough the 10A PARK fuse was blown. Replaced it and now everything is good .
I drive a 2003 Saturn Vue 3.0L V6 AWD
Add to leckster's Reputation
Rate the quality of this post and help leckster reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
leckster is offline   Reply With Quote
HELP HELP HELP!!!! NO TAIL LIGHTS OR DASH LIGHTS..... PROBATION IN three HOURS!!! RBrown20 S-Series Tech 15 02-04-2009 05:04 PM
Dashboard Lights & Tail lights out ry-guy L-Series General 1 01-19-2009 10:55 PM
clear tail lights and black tail lights on ebay cheap ericblkredline Vue Mods 5 08-28-2008 03:08 PM
2003 Ion Tail Lights & Cluster Lights Out ticklescat Ion General 3 12-31-2005 06:13 PM
