Old 05-03-2009, 11:59 AM   #1
kb7010
kb7010 is on a distinguished road
Default Bearing or seal problem..?? or maybe..????
I have a real good one.. on my 01 SL coupe.. there is a noise on the left side that sounds like a bunch of birds/screechy type noise.. ( faster you go .. louder and more noise is there ) so I took wheel off a couple weeks ago and sprayed rust penatrate oil at the axe seal that GOES into the trans.. ( so at the trans seal where axle goes into ) now the noise is back..????? yeah I knew it would come back.. lol
BTW: CV boots are all OK.. plus the oil wouldn't have sptopped the noise as it is sealed up.. right..????
anybody have ANY idea.?????
None of my buds or I have never seen of heard of this one..
so far you guys are 100% on my other questions/problems.. for that I thanks you once again in advance...
thanks in advance for ANY help or advice..!!!! honest.!!!!
Rex
Add to kb7010's Reputation
Rate the quality of this post and help kb7010 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kb7010 is offline   Reply With Quote
Old 05-03-2009, 12:10 PM   #2
Default Re: Bearing or seal problem..?? or maybe..????
Left or right axle? Check the transmission fluid level. Should be half way up on the crosshatch cold.
Old 05-03-2009, 12:38 PM   #3
Uhhhm, manual or automatic?
Are you sure it's in the drivetrain? Could it be the brake wear tell-tales?
(BTW, not relevant to your issue, but by definition, it's not an "SL coupe".)
Add to madpogue's Reputation
Old 05-03-2009, 12:54 PM   #4
Manual and autotragic have about the same cold level spec.
Noise went away when seal area was sprayed.
Old 05-03-2009, 04:15 PM   #5
kb7010
Correct..!!!!
ALL levels are OK.. not brake pads.. again.. sprayed the LEFT axle ( drivers side ) seal at the TRANS.. and noise went away for a couple of weeks..
good one eh..????? lol
thanks for the input so far..!!!!
Rex
Old 05-03-2009, 04:36 PM   #6
Hose it off with a can of break cleaner so its all nice and clean. Sometime in late 2000 the design of the seal was changed and there should not be a metal cover over the seal. You should see the actual rubber of the seal outer lip riding on the axle CV joint shaft. Try and clean that junction real well. What you want to do is get some regular chassis grease onto that junction and coax a bit up under the outer lip without trashing it in the process. An old tooth brush should do it.
Old 05-09-2009, 01:58 PM   #7
kb7010
Thanks a million.. just sounds like the problem.. lol
when I get it fixed ..!!! I WILL .. post back with results..!!!!
you guys are the best..!!!!
Rex
Quill Seal/Bearing & FSM jjbendo S-Series Tech 7 09-28-2009 12:53 PM
Bearing or seal noise.????? kb7010 L-Series Tech 1 05-02-2009 09:03 AM
window seal problem??? saturnhouse S-Series Tech 2 11-25-2008 05:27 PM
Replacing input shaft seal/bearing Khandyman S-Series Tech 1 01-16-2007 04:18 AM
Tranny Seal Problem SliverXZennon S-Series General 1 04-29-2004 07:01 PM
