Old 04-29-2009, 10:32 AM   #1
1994Saturn
1994Saturn's Avatar
1994 SL1
Happy DOHC Tightening sequence Valve Cover
A picture of the order of the tightening sequence for the Aluminum DOHC valve cover. This does not apply to the plastic valve covers... Tighten to 89 in-lbs..
Current:
1998 SL2 Auto issues 112K
Past:
94 SL1 Sold @134K.
Add to 1994Saturn's Reputation
Rate the quality of this post and help 1994Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-29-2009, 10:42 AM   #2
Low Saturn
Low Saturn's Avatar
2000 SC2
Default Re: DOHC Tightening sequence Valve Cover
Yep.
http://www.differentracing.com/tech_.../camcover.html
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
-2000 SC2
-2001 Chevrolet Suburban
Old 04-29-2009, 10:44 AM   #3
Low Saturn
Low Saturn's Avatar
2000 SC2
Originally Posted by Low Saturn View Post
And thare actually is a sequence for the comosite covers as well, its the same as the aluminum ones. At least thats what the FSM says.
Mike
-1991 Turbo SL2.
-2000 SC2
Old 04-29-2009, 11:33 AM   #4
This is the pattern for the 11 bolt composite cover.
Intake
9 5 6 10
3 1 2
8 4 7 11
Exhaust
Old 10-29-2009, 06:44 PM   #5
squeeker
squeeker is on a distinguished road
1996
Mad Help - Snapped Valve Cover Bolt
I replaced my leaking valve cover seals today, and discovered that the cause of the leak was due to the injector wiring harness being previously trapped under the valve cover seal! Unbelievable.
Unfortunately, I snapped the number 1 bolt before my torque wrench reached 89Lbs. It snapped clean off at the top of the head, so I can't grab it with a vise-grip. What is the best method for removing the remaining piece of the bolt?
1996 Saturn SW2 DOHC - Phenolic Valve Cover, Original Bolts.
Add to squeeker's Reputation
Rate the quality of this post and help squeeker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
squeeker is offline   Reply With Quote
Old 10-29-2009, 10:14 PM   #6
The torque spec is 89in-lb. That might be why it broke.
How far down in the head is the broken bolt?
You can drill a small hole in the end of it and use an easyout on it if you are good with a drill. The other approach is to cut a slot in the end of it with a Dremel tool and take it out with a small screw driver. If you cleaned out the holes before you installed the bolt it will come out easy. You might nick the head with the Dremel but you can patch it up with JB Weld, or a dab of RTV. Whatever you do not break off an easyout in the bolt as they are almost impossible to remove.
Welcome to the Forums!
Old 04-26-2011, 01:51 PM   #7
boilerroom
boilerroom is on a distinguished road
1994 SC2
I almost got tripped up by that damn Inch pound spec - i read the directions 3 times - luckily when putting the cover back my buddy caught it - close call
Add to boilerroom's Reputation
Rate the quality of this post and help boilerroom reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
boilerroom is offline   Reply With Quote
Valve Cover Torque Sequence toddmog S-Series Tech 6 04-07-2009 01:23 PM
04 Vue 2.2L Head Bolt Tightening Sequence mzukos Vue General 2 05-19-2008 11:56 PM
Valve Cover Sequence And Torque Specs? srl1104 S-Series Tech 4 11-17-2006 12:26 PM
torque sequence for a 93 DOHC cam cover? ck93sc2 S-Series Tech 6 06-28-2006 01:51 AM
Torque Sequence for Cam Cover, DOHC Luke Miscellaneous Tech 4 07-07-2002 12:22 PM
