Old 04-27-2009, 08:52 PM   #1
mjm
mjm is on a distinguished road
Default how to remove throttle cable from 2000 Saturn SL2 1.9L DOHC
I'm all ears....tried searching...no luck...
Add to mjm's Reputation
Rate the quality of this post and help mjm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mjm is offline   Reply With Quote
Old 04-27-2009, 09:08 PM   #2
velleguy73
velleguy73 is on a distinguished road
2001 SL
2002 SL
Default Re: how to remove throttle cable from 2000 Saturn SL2 1.9L DOHC
How far are you looking to go? If you are trying to take it off the throtlebody? Just pull the throttle actuator all the way open, slack the cable by hand, push it out of the raceway, and slide the cylinder on the end of the cable out. The cable will be perpendicular to the actuator.
For reference, the cable is centered on a small metal cylinder. The cylinder is held into the actuator when it is under tension.
While you are at it, check out the throttle body cleaning video's in the how-to section. You might be surprised how much black goo is piled up in there.
Good luck.
Add to velleguy73's Reputation
Rate the quality of this post and help velleguy73 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
velleguy73 is offline   Reply With Quote
Old 04-27-2009, 09:13 PM   #3
off-track
off-track's Avatar
Check this video out.
http://www.youtube.com/watch?v=LZ5cAVjjnWg
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Old 04-27-2009, 09:45 PM   #4
velleguy73
2001 SL
2002 SL
That's got to be the shortest video richpin has ever made. Great stuff.
Old 04-27-2009, 09:58 PM   #5
Low Saturn
Low Saturn's Avatar
2000 SC2
This is one of those things that is easier to just do than to try to type instructions for.
Its really self explanatory once you get into it.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 04-28-2009, 07:13 AM   #6
mjm
I guess I was not specific enough....i am pulling the engine, and I need to remove the throttle cable from the engine....the part that is back a couple of inches and held by a bracket that attaches it to the intake (i believe)....thx, mike
Old 04-28-2009, 08:49 AM   #7
Unbolt the bracket from the intake. Or you have to squeeze all of the clips at once.
Old 04-28-2009, 02:38 PM   #8
mjm
I only glanced at it, but it looked like the bracket was actually a molded part of the intake manifold....I will take another look....
Old 04-28-2009, 03:05 PM   #9
Thats right, you have the plastic one and it just might be molded.
Old 04-28-2009, 09:25 PM   #10
velleguy73
2001 SL
2002 SL
Yikes! looks like you have a lot of reading to do. Hit the how-to section and get a manual. If you do your homework 1st your engine pulling project will go much smoother.
Old 04-28-2009, 09:51 PM   #11
Remove the cable from the throttle by by manually opening the throttle all the way. Hold it so you can take the slack in the cable and wind it of of the cam so that you can get the cable aligned with the slot in the cam. Slip it out of the cam.
To get the cable out of the bracket you need to squeeze the two side tabs together that lock the cable into the bracket. Slide the cable back and out of the bracket with the tabs squeezed.
Add to ssicarman's Reputation
Old 04-15-2012, 10:20 AM   #12
MikeIndiana
MikeIndiana is on a distinguished road
does anyone even know what they are talking about here?
The throttle cable is held in place by a bracket, that is molded to the freakin engine or something, and there are no tabs, or sliding parts, apparently a team of engineers has decided to create this convoluted means of fastening the throttle cable in place.
What a fantastic pain in the butt, you gotta remove this *&*^ thing to get the fuel rail out.
The instruction books act like this doesn't even exist and make no mention of it, the Richpin video totally ignores it also. I can't even find any reference to it in google searches, and yet it is blocking the removal of the fuel rail. weird.
Add to MikeIndiana's Reputation
Rate the quality of this post and help MikeIndiana reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MikeIndiana is offline   Reply With Quote
Old 04-15-2012, 10:28 AM   #13
MikeIndiana
well, I was tryin to remove the fuel rail very carefully, without removing this bracket holding the throttle cable in place, and of course, it snapped like it was a brittle twig, it's made out of fragile plastic. I swear it seems like they do this stuff on purpose to thwart you from servicing your car.
I'm pretty pissed, I replaced the fuel filter a week ago and the silly bolts break off, every says they break off everytime and sure enough, someone decided to use pot metal bolts on the fuel filter bracket.
I really wish they would just make a few models of cars and do them right instead of making hundreds of new ones every year, with every part changed and re-engineered to thwart you from comprehending your own car.
I really think if they just concentrated on doing a few models of cars, and doing them right, they would sell more cars, but apparently this is some kind of secret means they use to sell us more cars, by making them all different, so there's no cheap parts to fix them, so it's not worth it to fix and repair them, you go buy a new car.
These big companies ALL do this, it's scientific capitalism, they make 10,000 different models of computers, computer printers, dishwashers, refrigerators, so they can sell new models every year, because there's basically no parts for your old models, or they are so expensive it's not worth fixing them.
Old 04-15-2012, 11:01 AM   #14
"Designed obsolescence"
Old 04-15-2012, 11:09 AM   #15
MikeIndiana
I am very frustrated because
1) it defies all logic why they chose such a crazy get-up to fasten the throttle cable in place. There's a million easy, simple ways they could have done this.
2) No repair manuals ever mention this, even though you HAVE to remove it to remove the fuel rail.
3) It broke with there merest pressure, and I wouldn't even know how to repair it, remove it or replace it
Old 04-30-2012, 04:30 PM   #16
DocB
DocB is on a distinguished road
Molding the bracket as part of the manifold is a stupid, money saving move and just shows what happens when the bean counters take over a manufacturing company. I struggled with removing the cable on my granddaughter's 2001 SL2 which isn't out in the open like earlier engines. I finally managed to take this photo in situ which confirmed what I thought and what others have been saying. The two outer tabs need to be squeezed toward the center (arrows) but in my experience that was easier said than done. After exhausting every pair of pliers in my toolbox I finally was successful using a pair of vice grips to really crank the heavy tabs in enough that I could begin to slide the connector out of the bracket. Once it had moved an eighth of an inch and the tabs were held by the bracket, I removed the grips and pulled it out the rest of the way. I hope this may be of help to someone.
-Glenn
Add to DocB's Reputation
Rate the quality of this post and help DocB reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DocB is offline   Reply With Quote
Old 05-03-2014, 10:41 AM   #17
Notamechanic78
Notamechanic78 is on a distinguished road
Hate to resurrect an old thread, but does anyone have any further input on this? I have to get the fuel rail out of the way so I can replace some of the plastic garbage on the back of the motor (Dohc), and I have not a clue how to remove the throttle cable. My patience is starting to wear thin with this engineering marvel.
Add to Notamechanic78's Reputation
Rate the quality of this post and help Notamechanic78 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Notamechanic78 is offline   Reply With Quote
Old 05-03-2014, 10:53 AM   #18
Notamechanic78
Never mind, I had to be a registered user to see DocB's pic.....that helped a lot, thanks. Coming soon: 2000 sl2 for sale, complete with .308 holes to block and hood
Old 09-17-2017, 05:17 PM   #19
Sheila
Sheila is on a distinguished road
Hey... Im right there with ya. I'm about to smash my car!! So frustrating!
2000 Saturn SL2 Ugghh!!
Add to Sheila's Reputation
Rate the quality of this post and help Sheila reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sheila is offline   Reply With Quote
Old 09-18-2017, 02:14 PM   #20
So, were able to get your cable out?
Swapped a 2001 SC1 DOHC engine with a 2000 SL2 DOHC now have transmission issues knukklhead S-Series Tech 18 04-13-2009 06:48 PM
95 SL2 - Throttle cable routing needed gkainz S-Series Tech 1 09-02-2008 05:49 AM
Swap 2000 SL2 DOHC (auto) into a 1999 DOHC (manual)? kim_lombard S-Series Tech 3 02-22-2008 12:12 AM
2000 SL2 DOHC heats up Chukaikbi S-Series General 6 10-04-2005 03:49 PM
2000 SL2 pinging at light throttle SL2abuser S-Series Tech 4 09-27-2003 07:30 PM
