Old 04-27-2009, 10:41 AM   #1
acamato
acamato is on a distinguished road
Default Main & Rod Bearing replacement?
The motor in my 02 SL2 seized due to lack of oil. This past weekend I dropped the oil pan to take a look. I spun the #3 Rod bearing. The main bearings look OK, some scoring. The other rod bearings showed signs of lack of oil. The journals look good, a little discolored, but cannot feel anything with my fingernail. The #3 piston journal need to be cleaned up. It has some melted bearing stuck to it. And advice on trying to get this clean? I was going to try a plastic scraper. Any other Ideas.
I want to replace the main & rod bearings.
Can I replace the main bearings with the crank in the car?
Do I need to replace the oil pump?
I have post photos in my gallery.
Thanks in advance.
Add to acamato's Reputation
Rate the quality of this post and help acamato reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
acamato is offline   Reply With Quote
Old 04-27-2009, 11:34 AM   #2
Highmile
Highmile will become famous soon enough
Highmile's Avatar
Default Re: Main & Rod Bearing replacement?
This is not a job I'd attempt with the motor in the car.
The biggest problem I see is that the rod in which the bearing spun should be replaced. To do it you will have to pull the head, at that point you'd be time ahead to pull it. I'd also have the crank polished/checked by a machine shop.
Since this was an oil issue, you should also check the cam and cam journals. Cast iron spinning in aluminum without oil gets ugly pretty quick.
Oil pump replacement, depends on what it looks like. Your repair manual will show you how to check it. It's worthwhile to replace the pressure relief valve too. It's a cheap part and best installed by a machine shop or dealer.
Above and beyond anything you need to identify why the oil issue to begin with. Otherwise you'll be right back in this boat.
Good luck
Highmile
95 sl1 496k (rebuilt engine)
Add to Highmile's Reputation
Old 04-27-2009, 01:08 PM   #3
acamato
I don't think the bearing spun for a long time. The motor never knocked. It just died. There were very little shavings in the oil pan. There were some on the windage tray. I cannot tell a difference in surface finish between the connecting rod caps. So, I think the damage to the rod is minimal.
The oil level dropped from burning and leaking from the oil pan. I don't drive this car. My wife told me we need to change the oil because the oil light is on. I thought she meant the change oil light. I was wrong.
My plan is to clean the journal and install new bearings. I can do this for less that $100 vs. $875 for a used motor.
Old 04-27-2009, 01:19 PM   #4
OldNuc has a brilliant futureOldNuc has a brilliant futureOldNuc has a brilliant futureOldNuc has a brilliant futureOldNuc has a brilliant futureOldNuc has a brilliant futureOldNuc has a brilliant futureOldNuc has a brilliant futureOldNuc has a brilliant futureOldNuc has a brilliant futureOldNuc has a brilliant future
Any shavings means the engine should be removed and rebuilt after being dipped. Any less than that is risking a prompt catastrophic failure after reassembly.
Old 04-27-2009, 01:54 PM   #5
acamato
I am well aware of the risk of not tearing down the motor. I want to spend minimal $$ of this car. I don't want to invest the $1000+ it would cost to rebuild the motor or replace it with a used motor. I can replace the bearings for under $100.
If the spin another bearing, It was a $100 gamble. The car is used to get back and forth to the train station which is 1 mile from my house.
Old 04-27-2009, 03:05 PM   #6
You can roll the upper shell in if you loosen all the caps. Plastic scraper is probably what it will take to get the fused lead off of the rod journal. Oil pump is in the timing cover so unless you want another mean job better hope its chip free.
Old 04-30-2009, 09:51 PM   #7
acamato
Today, I got the car running. I replaced the rod & main bearings with the motor in the car.
Cleaning the the melted aluminum from the bearings off the crank journal for the #3 rod was time consuming. I tired a plastic scraper (did not work), I razor blade worked pretty good the get some of the metal off. I had to keep it at a sharp angle to ensure that I did not mark up the journal. I also used a fine brass wire wheel. That worked the best, it got the journal nice & clean. I also used green scotchbrite of remove some of the discoloration & to ensure that there was no metal buildup on the other rod journals.
After I had the journals clean I sprayed the whole area with brake cleaner to wash away any metal particles that may be in the bottom end.
I installed the new bearings using assembly lube. I also had the valve cover off and poured the oil over the cams before I put the cover on. I cranked over the motor with the plug wires off until the oil light went out. I then put the wires on and started it up. It sounds great, no knocking...
I will change the oil & filter after a few hours of running.
Old 05-21-2009, 11:49 AM   #8
almoore
almoore is on a distinguished road
1994 SC2
I have to do the same thing.Do you have any advice you can share?
Add to almoore's Reputation
Rate the quality of this post and help almoore reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
almoore is offline   Reply With Quote
Old 05-21-2009, 12:57 PM   #9
rc1488
rc1488's Avatar
He was lucky. When the rod bearing goes, it creates alot of heat on the crank...and can thus warp the crank.
Its best to remove the crank and have it inspected. If it checks out ok, have the machine shop clean it and tell you what bearings to get. The rod that had the spun the bearing should also be replaced.
Again...he was lucky. If i did what he did I would have put a warped crank back into the engine....and Failed.
Add to rc1488's Reputation
Old 05-21-2009, 01:10 PM   #10
bjcart
bjcart is on a distinguished road
Yep, extremely lucky. Previous owner spun the #2 rod bearing on my '94. Crankshaft and #2 rod are completely destroyed.
By the way, anybody have a good crank they want to sell me?
'99 SL2
Add to bjcart's Reputation
Rate the quality of this post and help bjcart reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bjcart is offline   Reply With Quote
Old 05-21-2009, 01:16 PM   #11
rc1488
rc1488's Avatar
I bought mine from C&P Machine. They sent a remanned cranked with bearings (rod and main) ready to be dropped in. About $200. I went this route bc i wouldnt have to worry about what bearings to get and such. It all came matched up. GREAT customer service. Just ask for Brian.
Otherwise Lowsaturn has some. But they need to be inspected, cleaned, and then the machine shop will need to tell you what bearings to get.
I also have an extra rod if you need it
Old 05-22-2009, 05:41 PM   #12
skii33
skii33 is on a distinguished road
100% chance that if you spin a rod bearing it oblongs the rod journal . It may look good but we are talking just a couple of thousands of an inch that the rod bearing goes out of round. You can have it resized at a machine shop for just 8-10 dollars. I'll bet the crank needs grinding also.The extra work pulling the head to remove the rod and piston would have been good insurance....My advice to anyone who spins a rod .....DON"T shortcut , it will just bite you in the end ......TRUST ME , i have built plenty of saturn (and other engines) thanks Glenn
Add to skii33's Reputation
Rate the quality of this post and help skii33 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
skii33 is offline   Reply With Quote
Old 05-22-2009, 09:15 PM   #13
+1^^^^^You are not going to get away with just stuffing in another bearing.
Old 07-31-2014, 06:41 AM   #14
medarwin
medarwin is on a distinguished road
Hi, Following up to see if there was any long term downside to the bearing repalcement job with the engine still int he car. Looking at doing a similar, I have a 99 SW that needs new crank bearings. I want to give it to my 16yo for a starter car and egngage him in the project.
Thanks, Darwin
Add to medarwin's Reputation
Rate the quality of this post and help medarwin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
medarwin is offline   Reply With Quote
Old 07-31-2014, 07:00 AM   #15
Thanks, Darwin
There is no easy way to accurately measure the crank and rod clearances with the crank in the engine. If the engine runs now without any unusual noises you can try it but do not be surprised if it is a failure.
Old 07-31-2014, 07:44 AM   #16
SL19302
SL19302's Avatar
2002 SL1
I would think with even cleaning the failed journal, The finish on the crank would be all scored up from lack of oil, Installing a new bearing over a scored journal wont last, Along with that low oil levels starved the entire engine not just number 3 rod bearing, The oil pump im sure at this point would have excessive clearances causing low oil pressure at idle when the engine is hot...
CHECK YOUR OIL!
Add to SL19302's Reputation
Old 07-31-2014, 09:57 AM   #17
billr
billr is a jewel in the roughbillr is a jewel in the roughbillr is a jewel in the roughbillr is a jewel in the rough
"Medarwin", you scabbed-on to an old thread; did your engine also get low on oil and spin bearings??? Or is it just old, and you have some symptom like noise or low oil pressure or crank end-play that makes you suspect the bearings? If a bearing didn't get spun, then you are much more likely to have success just changing the bearings in the car. Plasti-gauge has been used quite successfully for many, many years to check bearing clearances; you can use that with the engine in the car. Tell us what symptoms you have here...
Add to billr's Reputation
Old 07-31-2014, 01:28 PM   #18
You are not going to measure for out of round, taper or flat spots with plastigauge easily. You can get an idea of the general clearance.
Old 07-31-2014, 04:49 PM   #19
billr
^^^ True enough, plastigauge is not nearly as good as having the crank out for full inspection. That's why I hope the OP gives us more of the story. If the bearings are just worn, no reason to suspect damage to the crank, the taper and out-of-round are probably not going to be an issue. OP would just need to check clearance. It think the OP is looking for a practical approach here, no intent to "blue-print" the engine (or even a true rebuild).
Old 07-31-2014, 05:05 PM   #20
DJKrohn
DJKrohn is on a distinguished road
DJKrohn's Avatar
I've tried the in-car method once. I cleaned everything up and plasti-gaged it, and got a new bearing from Saturn that was slightly bigger to fit (according to the plasti-gage measurements). I can't remember if it was under-sized, over-sized, or both, but I think it was .002". I installed it, and the clearance looked good, along with the other bearings. Started up the engine and drove awhile and the same rod started knocking again. Crank was probably out-of-round. For that reason, this method is probably never likely to succeed. But feel free to try it.
I hate taking off nasty oil pans in-car. And it's impossible to get them to seal perfectly, no matter how much time you spend and how much brake cleaner you use. There's always going to be a small drip of oil coming down inside the engine block to contaminate the RTV.
Add to DJKrohn's Reputation
Rate the quality of this post and help DJKrohn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DJKrohn is offline   Reply With Quote
rod & main bearings doublemm S-Series Tech 0 12-11-2009 11:09 PM
Lubing new main and rod bearings? jamie930 S-Series Tech 3 08-13-2009 06:06 PM
Main & rod bearing photos at 200k+ miles MINICooperS S-Series Tech 3 05-24-2008 10:30 PM
main/rod bearings andrewhuffman S-Series Tech 4 02-17-2008 04:24 PM
Is it possible - Main shaft bearing kickarse S-Series Tech 5 04-23-2005 12:36 AM
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
