#1 | ||||
![]() Join Date: Mar 2009
I was admiring the How-to forum, but this seems to have gotten missed. If you have a Mity Vac, I have found it to be very useful on the sealed hydraulic unit, and it is easier than using the bleeder screw on other cars.
1. Verify that all the lines and fittings are dry and secure. 2. Clean the dirt and grease from the reservoir cap in order to ensure that no foreign substances enter the system. 3. Remove the reservoir cap. 4. Fill the reservoir to the proper level with the required fluid. 5. Attach the J 43485 (Adapter) to the J 35555 (Mity Vac), or equivalent. 6. Place and hold the adapter on the reservoir filler neck to ensure a tight fit. In some cases, the adapter will fit into the reservoir opening. 7. Apply a vacuum of 51-68 kPa (15-20 hg) and remove the adapter. 8. Refill the reservoir to the proper level. 9. Repeat Steps 6 and 7. 10. If needed, refill the reservoir and continue to pull a vacuum until no more bubbles can be seen in the reservoir or until the fluid level no longer drops. *Caution: The vehicle will move if started in gear before the Actuator Cylinder is refilled and operational. Start the vehicle the first time in neutral to help prevent personal injury from vehicle movement and see if the transmission will shift easily into gear.* 11. Pump the clutch pedal until firm (to refill actuator cylinder). 12. Add additional fluid if needed. 13. Test drive vehicle to ensure proper operation.
#2 | ||||
The problem with that is you will suck air past the seals and it will still be air bound. There is a TSB with that updated method also. If you draw several inches (about 5 inches) of vacuum and then manually push in the operating rod while maintaining the slave cylinder with the operating rod pointed straight down and below the master cylinder it might work. Release teh vacuum before releasing the operating rod and then allow it to slowly extend.
If it works you save the cost of a replacement. But even the TSB did not offer much hope.
#3 | ||||
I suppose, if the seals are weak, you'd probably need to replace it regardless. But if they were that bad, surely they wouldn't hold fluid worth a darn under that pressure anyways.
#4 | ||||
The seals are designed to hold against internal pressure. They are not designed to stop air intrusion when the hydraulic system is placed into a vacuum. The seals are cup seals and the lips are facing the fluid.
... A lousy day in paradise is still a day in paradise.
#5 | ||||
Makes sense. Well, they must be able to withstand 15-20 hg at least, because it worked for me. Revived a hydraulic unit that I had lost pressure. Brought the fork travel back to spec
#6 | |||||
![]() Join Date: Jun 2009
Bleed Sealed master/slave in-car with no mess!
| Thread Tools | |
| Display Modes | |
| How to bleed clutch | Geego | Ion Red Line | 4 | 03-14-2013 10:47 AM |
| How do you bleed the clutch? | Carlyle | S-Series Tech | 6 | 08-01-2010 08:52 AM |
| Bleed Clutch | Brock4u | Vue General | 0 | 04-17-2008 01:54 PM |
| Anyone know how to bleed a clutch? | Brock4u | Vue Tech | 0 | 04-16-2008 01:09 PM |
| clutch bleed | redsput | L-Series General | 11 | 02-02-2005 09:36 PM |
