Old 04-21-2009, 07:28 PM   #1
Redlined
Redlined is on a distinguished road
Default 1997 Saturn Sl Head Gasket
Hi everyone, I'm new here and was wondering your thoughts.
I'm looking at purchasing a 1997 Sl with a blown head gasket. Are these models known for head gasket failures? If not, what could some probable causes be? For a do-it-yourself mechanic with better then average abililty, is this an overly difficult task? And finally, what would the approximate cost be doing the labour myself?
I appologize for the many questions, just trying to make the best informed descision I can.
Thanks for any help, great site!
Red.
Add to Redlined's Reputation
Rate the quality of this post and help Redlined reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Redlined is offline   Reply With Quote
Old 04-21-2009, 07:46 PM   #2
My95Sl2
My95Sl2 is on a distinguished road
My95Sl2's Avatar
1998 SL1
Default Re: 1997 Saturn Sl Head Gasket
Extreme overheating could be one possibilty, preignition and detonation problems have also been known to lead to head gasket failure on some automobile models.
1995 Saturn SL2 136,094---->> 152,000 (12/2010 ) Gone but not forgotten
1998 Saturn SL1 160,000
Add to My95Sl2's Reputation
Rate the quality of this post and help My95Sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
My95Sl2 is offline   Reply With Quote
Old 04-21-2009, 07:52 PM   #3
Cracked head is the more likely scenario. Who diagnosed the blown head gasket?
Add to madpogue's Reputation
Old 04-21-2009, 08:01 PM   #4
Redlined
The guy who is selling it 'diagnosed' the problem by telling me he saw coolant running down the side of the engine. He also informed me the car had 301,000 kms which is more than I would like for something I'm going to invest my time and money in. Asking price is $500.
Old 04-21-2009, 08:07 PM   #5
My95Sl2
My95Sl2's Avatar
1998 SL1
Coolant running down the side of the engine could be coming from a few different places such as the water pump weephole or in my case a bad clamp on one of my hoses was shooting coolant all down the side of my motor.....
Can you tell if you have water(coolant) in the oil or vice versa,,,seems to me that would surely be a giveaway the head gasket is blown for sure.....
Old 04-21-2009, 08:33 PM   #6
^^^^ +1. There are a LOT of ways that coolant can leak externally, most of which aren't even close to a blown head gasket.
300,000 km (180,000-ish mi) is either "middle-age" or "way over the hill" for these cars, dependent ENTIRELY on maintenance. Alas, a car coming from someone who (1) allows an external coolant leak, and (2) probably has no idea where it's coming from, and is pulling ideas for it out of his tailpipe, probably means it fits the latter category.
Thing is, it could be a simple fix, but if it hints at the car's provenance in general, it could be the start of a very long list of surprises. If you feel like a project, explain how major a project that coolant leak / "head gasket" issue is gonna be, and you're gonna have to pour a lot of money into it, yada yada. Bring two or three engravings of Mr. Franklin, and.. oh, wait, you guys have Maurice Richard and the guy who invented the Thermos on your money, or some such. Well, bring 200-300 of whatever you're printing/minting these days (is that Gordon Lightfoot on the tenner?).
Coolant and oil commingling doesn't always mean a blown head gasket. And the converse isn't always true as well. For example, if it blows between a coolant jacket and a combustion chamber, you'll get coolant in the exhaust, and possibly exhaust gas in the coolant, but no impact on the oil. If it blows between adjacent cylinders, compression in those two cylinders will be lower, but there's no other symptoms. The head gasket separates coolant passages, oil passages, combustion chambers and "the outside world". Depending on how/where it blows, it could commingle any two or more of these, each with its unique suite of symptoms.
Old 04-21-2009, 08:34 PM   #7
Have him point out where on the side the coolant was running. The head gasket can seep and the manifold gasket can leak. Look inside the neck of the coolant reservoir see a nasty bathtub ring in there? Is the rest of the coolant clear and clean looking? Does it run and idle smoothly? If its a real blown gasket it will not idle smoothly as you will have one or more weak cylinders. And I agree with Madpouge, 1/2 to 3/4 ther asking price and be prepared for a bit of a project. A cracked head or a real blown head gasket is an excuse for an engine swap or overhaul. And neither of those is cheap. However, when you are done you art through with engine problems. What does the rest of the car look like? Manual or automatic?
anyone know how to replace the head gasket in a 94 Saturn SL 1 SOHC?? spiderpig24 S-Series Tech 1 10-13-2009 12:49 PM
1997 SC1 Chocolate Milk coolant after a head gasket swap. redquestron S-Series Tech 14 07-04-2009 07:17 PM
1997 sc2 head gasket question dacchef S-Series Tech 11 07-14-2008 12:30 PM
Head gasket, head bolts and other head related foolishness… Quagmire S-Series Tech 9 09-12-2007 09:08 PM
Saturn head gasket??? between5and7 Classifieds 11 08-04-2005 05:35 PM
