what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn Astra > Astra General
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Astra General Photos
by m100
Astra - Member Photos
191 photos
68 comments
by Digency
191 photos
68 comments
by Charlie
2008 - Media Photos
43 photos
7 comments
by Charlie
2008 - Astra Road Test
86 photos
7 comments
Old 04-10-2009, 01:16 PM   #1
Layoira
Layoira is on a distinguished road
Layoira's Avatar
2008 Astra XR
Default Glovebox Cooling
Im sure some of you have already done this, but I got a PM asking for the parts used for my glovebox cooling, and since its the absolute easiest and cheapest mod you could do, I thought I would post it up for anyone who doesnt have it who would like to, since I had to write it up in a PM anyways. Im just copying and pasting the message I sent off pretty much.
First you need to look in your car to see for sure what you have. we should all have the same parts but sometimes factories make changes in installing parts for options not installed so its best to check if you have it so you can order both parts if needed.
Open your glovebox and peek thru the hole on the left side this is where the cooling adjuster attaches. you should see a black pipe with a grey rubber cap on it and the rubber cap will be in line with the hole. not right up to it, but you will see it right in front when you look in. that is the pipe part and it goes off to the side if you look well. if its there all you need is the switch, which is the cheapest part. (around 3 dollars) the part number is 13115964 and is called an air slider.
The air slider simply clips into that hole. You remove the grey rubber cap on the pipe first. You can take out the glovebox to do it, but you dont need to if you have a needle nosed plyers and grasp the rubber cap and pull it off thru the hole. Then clip on the switch. What it does is direct cold air into the glovebox making it a "chilled" area good for drinks in the summer etc. When you close the switch it closes off the airflow through the pipe going into the glovebox. Pretty simple but actually works.
If the pipe is already in place this is one of the cheapest and quickest mods you can do.
Now pictures so you know what you will be looking at.
The rubber cap you want to see, to show the pipe is already there you will see this through the hole if you dont remove the glovebox, and theres really no need to at all:
and the slider part you need to buy:
and I will grab a pic of my glovebox later to show you what it looks like clipped in, but its pretty straight forward. You can find that part on ebay if you dont have a contact to get it from Europe or the UK for you.
So there it is as a thread Simple, easy, Glovebox cooling for all
Christina
~Christina~
Astra XR5: 3M Film,GID, Arm Rest, SRi Wheel, Tints (50/35/13), Pioneer Nav Unit, Debadged, Glovebox Cooling, VXR Surrounds, Painted Grill, XP Spoiler, HIDS, Footwell Lighting. Pics Up :)
Add to Layoira's Reputation
Rate the quality of this post and help Layoira reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Layoira is offline   Reply With Quote
Old 04-10-2009, 01:53 PM   #2
internetjunkee
internetjunkee is on a distinguished road
internetjunkee's Avatar
2008 Astra XE
Default Re: Glovebox Cooling
Wow that is an easy mod, but useful mod. Thanks for the writeup. Did a quick search on eBay but wasn't able to find the part. Know of any other places to get it?
Current Mods: 45% Front Tint, 18% Back, Blacked Out Badges, Silverstar Ultra Headlights, Rear Spoiler, Eibach Pro Springs, Koni FSD Shocks, VMR VB3 18" Wheels, FM-RDS Modulator for iPhone
Add to internetjunkee's Reputation
Rate the quality of this post and help internetjunkee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
internetjunkee is offline   Reply With Quote
Old 04-10-2009, 01:58 PM   #3
Adam Opel
Adam Opel is on a distinguished road
I have been thinking about trying this, but I have been waiting for the summer, I hope it falls on a weekend this year (Canadian humour)
Even if you only uncap the pipe, you will get the same effect, but the slider is better to have, of course.
Where do you order the part from?
Add to Adam Opel's Reputation
Rate the quality of this post and help Adam Opel reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Adam Opel is offline   Reply With Quote
Old 04-10-2009, 02:00 PM   #4
Layoira
Layoira's Avatar
2008 Astra XR
Just ebay or if you know someone in the UK/Europe. They do pop up on ebay.co.uk and german ebay. Its easy enough to get someone to send one over though I would imagine if you ask nicely. Or you could ask Mcddxxvi I know thats probably not spelt right, but the US Astra Guy has a supplier he can get parts from, he might be able to set up a group buy for you guys.
I paid 1.66 gbp for mine so they are super cheap.
Good Luck with it! and yeah it really is a good simple mod, and it actually works which is what I was skeptical about but it does.
~Christina~
Old 04-10-2009, 02:15 PM   #5
mdcclxxvi
mdcclxxvi is on a distinguished road
mdcclxxvi's Avatar
2008 Astra XR
If anyone is interested I could get you the part on a individual basis, or as a group buy (so as to whittle down that $3 price tag )
Project 8888
www.usAstra.com
Add to mdcclxxvi's Reputation
Rate the quality of this post and help mdcclxxvi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mdcclxxvi is online now   Reply With Quote
Old 04-10-2009, 02:22 PM   #6
Layoira
Layoira's Avatar
2008 Astra XR
pretty much, but the slider helps cause it joins the cap between the pipe and opening a little better, and then closes off the air when you dont want it in there. and for 2 dollars ish cant go wrong.
And yeah, summer on a weekend this year would be great haha
~Christina~
Old 04-10-2009, 02:22 PM   #7
Adam Opel
Sign me up (for three easy payments of 1 dollar
Old 04-10-2009, 02:23 PM   #8
Layoira
Layoira's Avatar
2008 Astra XR
I got your name close, but not quite right. I tried tho lol
~Christina~
Old 04-10-2009, 09:49 PM   #9
nicolas_p
nicolas_p is on a distinguished road
nicolas_p's Avatar
2009 Astra XR
2008 Astra XE
Who would ever have figured they wouldnt just put the adapter when the build the car, they save 50 cents on each car, lol. But I think i will add this to my glovebox since I love to keep drinks in my car and it could be useful if we go camping or to a party
2008 Saturn Astra XE 5 doors/ Manual Transmission, 16" SSW rims (Gone to brother)
2009 Saturn Astra XR 3 doors/ Manual Transmission, 17" Mini-VXR rims, sports suspension, MP3 Audio
Add to nicolas_p's Reputation
Rate the quality of this post and help nicolas_p reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nicolas_p is offline   Reply With Quote
Old 04-11-2009, 12:25 AM   #10
DraconianAC
DraconianAC is on a distinguished road
2008 Astra XR
3 dollars sounds reasonable. Will that include the shipping to me in CA, USA? Or is it extra?
Add to DraconianAC's Reputation
Rate the quality of this post and help DraconianAC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DraconianAC is offline   Reply With Quote
Old 04-11-2009, 03:15 AM   #11
OPEL Blitz
OPEL Blitz is on a distinguished road
OPEL Blitz's Avatar
Check your cars first, you may need the pipe too, they are not fitted to all cars. Mine does not have any.
2007 OPEL Astra Diesel
Add to OPEL Blitz's Reputation
Rate the quality of this post and help OPEL Blitz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OPEL Blitz is offline   Reply With Quote
Old 04-11-2009, 05:17 AM   #12
cschmidt1956
cschmidt1956 is on a distinguished road
This looks like an obvious GROUP Buy to be sure! Count ME in on this one!
2010 Chevrolet Camaro LT2/RS V6
2008 Saturn Astra XR 3 Door - Sapphire Black (Gone but NOT forgotten!)
2003 Jeep Grand Cherokee, Brilliant Black Metallic
1999 Oldsmobile Intrigue GLS, Black
Add to cschmidt1956's Reputation
Rate the quality of this post and help cschmidt1956 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cschmidt1956 is offline   Reply With Quote
Old 04-11-2009, 10:39 AM   #13
Layoira
Layoira's Avatar
2008 Astra XR
yep you need to check for sure if you have the pipe. If not, its about 15 dollars for the pipe itself. Mine had it.
~Christina~
Old 04-11-2009, 06:54 PM   #14
marx404
marx404 will become famous soon enough
marx404's Avatar
2008 Astra XE
I noticed that the pics are of the glovebox removed? Heres are more shots from the inside of my glovebox. Layiora, if this involves no disassembly other than reaching inside and removing the rubber cap then plugging in the new fitting to the glovebox wall, I am in!
I wonder also, what effect will this mod have on the A/C air flow?
marx404
Saturn Infinitum.
We Are Saturn and We Love our Cars.
2007 ION.3
2008 Astra XE
Add to marx404's Reputation
Rate the quality of this post and help marx404 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
marx404 is offline   Reply With Quote
Old 04-11-2009, 07:04 PM   #15
Layoira
Layoira's Avatar
2008 Astra XR
Yep thats right, no disassembly, not that its hard to remove the glovebox but you dont even need to. I didnt. Stick a needle nosed plyers in there grasp the edges then pull it off and back out thru the hole. Snap on the air slider and thats it
I doubt it effects the air flow too much, if at all, because the air still went in the pipe with the rubber before, and now it just goes to the air slider which you can close off. I havent had any problems. Super quick, super easy, and actually functional.
I Posted the pics of the glovebox removed just to explain the pipe I was talking about, since they were readily available at the time I was sending my message, but its 100% not needed to remove.
~Christina~
Old 04-11-2009, 07:50 PM   #16
cschmidt1956
My XR-3 has the rubber plug ting right where the other pictures show. So I guess I am good to go!
YES! I WANT ONE!
Old 04-11-2009, 07:56 PM   #17
Layoira
Layoira's Avatar
2008 Astra XR
Im gonna run out now and snap a quick pic of what the slider looks like in, for those who dont know.
~Christina~
Old 04-11-2009, 08:15 PM   #18
Layoira
Layoira's Avatar
2008 Astra XR
I hate that this forum doesnt let you edit after so long. Oh well. Here we go, mine closed and opened:
~Christina~
Old 04-11-2009, 08:22 PM   #19
OPEL Blitz
OPEL Blitz's Avatar
Glove box is easy to remove, four torx, give it a sharp pull like you intend to break it and disconnect the wire to the lamp.
Old 04-12-2009, 07:49 PM   #20
marx404
marx404's Avatar
2008 Astra XE
I'm in, sending you a PM. Thanks all for the info and pics.
marx404
Saturn Infinitum.
2007 ION.3
2008 Astra XE
Plug in the glovebox jhoward321 Astra Tech 4 10-20-2009 01:25 PM
Glovebox cooling group buy mdcclxxvi Astra General 70 10-07-2009 01:08 PM
Glovebox Latch Nocturnal One S-Series General 2 07-10-2007 01:54 PM
Removal of Glovebox SlimSaturn Ion General 3 07-30-2005 09:19 PM
Lockable glovebox SlimSaturn Ion General 11 04-16-2004 04:25 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
