Old 11-13-2002, 05:51 PM   #1
unkle bik
unkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the rough
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
Default need a sixth gear
as a current owner of a 2002 l200 manual, i notice that the 2.2 ecotec engine seems like it needs a sixth gear. my previous car, a 96 sl2 manual, turned less than 3 grand when running around 70 mph. however, the l200 seems to run much higher (200-300 rpm) at that speed. i always thought that the larger motor would would turn slower at any given speed (vehicle) compared to the smaller displacement engine. does anyone know why saturn engineered it this way? was it because of the fact that the had few SAAb trannys that would come close to doing the job, or is it for other reasons. would like some insight on this
Add to unkle bik's Reputation
Rate the quality of this post and help unkle bik reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
unkle bik is offline
Old 11-14-2002, 10:30 AM   #2
eRic 02sc2
eRic 02sc2's Avatar
Default
the L is about 600 lbs heavier than the S. the bigger 2.2L could be geared to turn slower than the 1.9L if it was installed in the S. a better comparison would be between the gearing used with the 3.0L in the L compared to the 2.2L in the L.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 11-14-2002, 12:54 PM   #3
Gerry Proctor
2008 Astra XR
2008 SKY Red Line
Default
The problem with deep automatic overdrives in engines that don't make mountains of torque is that they are only useful on the flatest of flat roads where you are entirely in the cruise mode (no accelerating, fighting headwinds, gentile rises in the terrain, other traffic). Otherwise, the trans will be hunting between gears, which will drive you crazy. Even with a manual, you would constantly be rowing gears. It would be almost useless.
Gerry Proctor is offline
Old 11-14-2002, 01:38 PM   #4
L300Boy
L300Boy is on a distinguished road
L300Boy's Avatar
Default
FYI, The auto V6 revs lower than the 2.2L (i think both manual and auto?) at highway speeds. 2000 rpm at 60 and 2200 at 70.
Add to L300Boy's Reputation
Rate the quality of this post and help L300Boy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
L300Boy is offline
Old 11-14-2002, 01:39 PM   #5
eRic 02sc2
eRic 02sc2's Avatar
Default
D'oh. forgot they don't have a manual equipped 3.0 in the L. only automagics. my point was to compare the gearing in a manual 3.0 to a manual 2.2 L.
eRic 02sc2
Old 11-14-2002, 04:01 PM   #6
Xanatos
Xanatos is on a distinguished road
Xanatos's Avatar
Default
Yeah, I love my 3.0 with the Auto. But I would love to see a 6 speed, with an aggressive shifting ratio. Say a 1.0 5th, and a .82 6th... and start it out around 4.1 for the 1st *drools*
That would be so fun
Add to Xanatos's Reputation
Rate the quality of this post and help Xanatos reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Xanatos is offline
Old 11-14-2002, 04:06 PM   #7
SCDYNE
SCDYNE is on a distinguished road
SCDYNE's Avatar
2007 SKY
Default
Great News!
There is a 6 speed gear kit for the L200 Manual. Any ECOTEC with the F25 Transmission can purchase a 6 speed gear kit from Quaife. This is limited to the SAAB 9-3 and Saturn L series with the F25.
Sorry not the GETRAG in the ION.
It's $3875 for the complete gear kit and it comes with an LSD also.Quaife USA SAA (GM F25) Gear Kit
-Adam Chant
2007 Saturn SKY - Supercharged
1997 Saturn SC2 - Stock Rebuild
Add to SCDYNE's Reputation
Rate the quality of this post and help SCDYNE reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SCDYNE is offline
Old 11-14-2002, 05:29 PM   #8
hugh
hugh will become famous soon enough
Default
L300Boy;
Are you sure about those figures? My LS2 is up around 2400 at 70.
Add to hugh's Reputation
Rate the quality of this post and help hugh reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hugh is offline
Old 11-15-2002, 12:58 PM   #9
unkle bik
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
Default
my point was to compare the gearing in a manual 1.9 to a manual 2.2 L. (not the 3.0l v6)
Old 11-15-2002, 02:50 PM   #10
jmatero
jmatero is on a distinguished road
jmatero's Avatar
Default
$4,000 + labor to lower your RPM's a few hundred? Are you out of your mind?
The L-series and VUE both rev higher in the 5-speed models than in the automatics. In fact, you'll notice the L200 Auto gets higher MPG because of this. However, this is done for a reason. It allows the engine to turn at it's sweet spot on the highway so when you give the car gas in 5th, it actually moves. The downside is the noise level coming through the firewall. It's a trade-off. But spending upwards of $4g's to add another gear.....? Why not just trade it in on another car?
Add to jmatero's Reputation
Rate the quality of this post and help jmatero reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jmatero is offline
Old 11-15-2002, 03:26 PM   #11
unkle bik
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
Default
i had a spare 4 grand laying around here somewhere....
sixth sphere bendover817 S-Series General 18 03-26-2010 11:21 AM
auto 95sw2 2nd gear doesnt fully engage until right before 3rd gear shift? kaptnjack S-Series Tech 4 01-06-2010 07:10 PM
Sixth Planet Used Parts Survived Hurricane Charley BobL General Saturn Discussion 0 08-17-2004 12:47 PM
