Old 03-26-2009, 07:10 PM   #1
haywood2121
haywood2121 is on a distinguished road
haywood2121's Avatar
Default Electrical issues and rotten egg smell??
Hi all,
2003 Saturn LS300 160,000
Symptoms:
*****These all happen at the same time this morning******************
-Rotten egg smell in cabin
-High beams go on and off whenever they feel like it
-When I try to dim and brighten the cabin lights they "flicker"
My service engine light has been on and I had the codes read at lunch and it came up for a thermostat.
Also, this weekend I'm planning on replacing the thermostat, sparkplugs and rear coil pack, because of the service engine light (thermostat code) and preventive maintenance.
Anyone have any ideas?
2003 Saturn LS3 260000 miles and still rolling
Add to haywood2121's Reputation
Rate the quality of this post and help haywood2121 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
haywood2121 is offline   Reply With Quote
Old 03-26-2009, 08:50 PM   #2
Default Re: Electrical issues and rotten egg smell??
1-Rotten egg smell in cabin - Switched gasoline recently?
2-High beams go on and off whenever they feel like it - This may be the combination light/turn signal switch stalk. Search the threads about it.
3-When I try to dim and brighten the cabin lights they "flicker" - If you're describing the dimmer knob, this may be the rotary pot that's flaky and needs tweaking to stiffen it some, from its looseness that contributes to flickering. Exercising it several times sometimes helps. Threads about this too.
Read past threads of body control module (BCM) failures. Yours may have the beginnings of bcm problems.
Hopefully, you replaced the timing belt at 100,000 miles? And water pump? There are threads about replacing the thermostat and plugs as you know they're not easily accessible.
Old 03-27-2009, 09:50 AM   #3
haywood2121
I like your approach of taking one issue at a time. When it first happened I was thinking it may some kind of module gone bad.
I'm going to start with the combination light/turn signal switch stalk first.
1-Rotten egg smell in cabin - Switched gasoline recently?-My wifes been driving and she usually sticks to shell, when this happened the tank was 1/4 full.
Yes I had the timing belt, water pump, seals and idler replaced @ 120,000 miles. As far as the spark plugs and thermostat, there is a reason I've waited 170,000 to change them!!!
Old 03-27-2009, 12:38 PM   #4
SaturnTech122
SaturnTech122 is on a distinguished road
rotten egg smell can be a sign of soon catalytic converter failure
Certified Saturn Technician
Add to SaturnTech122's Reputation
Rate the quality of this post and help SaturnTech122 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnTech122 is offline   Reply With Quote
Old 03-29-2009, 08:30 AM   #5
Wolfc70
Wolfc70 will become famous soon enoughWolfc70 will become famous soon enough
The rotten egg smell could be from misfires. With a 160K on the plugs, they are very worn. Having plugs that worn is also very hard on the coil packs. Considering how the factory plugs looked in my car with 60k(electrode pretty worn), I am surprised that the car has any power.
The misfires are also a great way to kill the cat con.
"I tip my hat to the man who drives an Alfa Romeo" - Henry Ford
Add to Wolfc70's Reputation
Rate the quality of this post and help Wolfc70 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Wolfc70 is offline   Reply With Quote
Old 03-30-2009, 05:55 AM   #6
haywood2121
Thumbs Up Re: Electrical issues and rotten egg smell??
okay, problem solved
-Rotten egg smell in cabin -- I added one bottle of seafoam cleaner in the tank combined with the preventive maintenance (spark plugs, thermostat, and coil pack) seemed to have solved it, haven't smelt anything since and also my service engine soon light is off
-High beams go on and off whenever they feel like it-- Changed the switch stalk as suggested - Thanks!
-When I try to dim and brighten the cabin lights they "flicker" --Sprayed WD40 around the knob that controls the dimming
Thanks again
rotten egg smell saturncrzy S-Series Tech 6 05-10-2008 02:56 PM
Rotten Egg Smell SLAPSHOT Vue General 19 11-25-2006 02:38 PM
rotten egg smell greasynails L-Series General 24 07-09-2005 09:19 AM
rotten egg smell? Zorak S-Series Tech 13 02-05-2005 04:00 PM
Rotten Egg Smell? KI8GW Ion General 6 12-19-2003 12:52 AM
