Old 03-24-2009, 09:57 PM   #1
mgordon1100
mgordon1100 will become famous soon enough
mgordon1100's Avatar
Default Seized Engine and MMO
I read in a message a while ago, that someone tried MMO on their seized engine. Here's my story. The guy who did my ex's oil change couldn't get the oil filter off, but he did something so that when she went to work, all the oil drained out. A couple of blocks away, the car died out. Engine is seized up. What kind of probability is there that a good MMO soak will get it moving again?
Oh, it's a 99 SL2 Automatic.
Add to mgordon1100's Reputation
Rate the quality of this post and help mgordon1100 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mgordon1100 is offline   Reply With Quote
Old 03-24-2009, 10:19 PM   #2
harley2003
harley2003 has a spectacular aura aboutharley2003 has a spectacular aura aboutharley2003 has a spectacular aura about
harley2003's Avatar
2002 SL1
2002
Default Re: Seized Engine and MMO
Slim to none.
2013 Hyundai Sonata new
2003 Harley Davidson FXDWG wide glide.
2015 Hyundai accent hachback
Add to harley2003's Reputation
Rate the quality of this post and help harley2003 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
harley2003 is offline   Reply With Quote
Old 03-24-2009, 10:54 PM   #3
westwind999
1999 SW1
+1 slim to none.
Probably what happened is the rubber ring from the first filter stuck to the block so there were two gaskets when the new filter was installed. One of the two gaskets shifted and allowed the oil to leak out. Always make sure the gasket is removed when you take the filter off.
Old 03-24-2009, 11:19 PM   #4
+1 for just none.
Old 03-25-2009, 12:51 AM   #5
amazinghl
This is what you will find.
Engine replacement time.
00 Insight 72mpg
Add to amazinghl's Reputation
Old 03-25-2009, 01:17 AM   #6
93SC2'in
93SC2'in is on a distinguished road
93SC2'in's Avatar
1993 SC2
ROFL i was lauging for a good 5 mins after reading that... not because of the oil draining out that's lame. but even the thought of MMO doing something for a seized engine is ridiculous... also don't let stupid people change your oil would be my suggestion to your ex
93 SC2, 5-speed, <dead and gone>
95 SL2 5-speed, oem header, gsi TB, sprint 2.0, kyb gr2's, wb02, SAFCII, CAI, 17"s
Speed Kills - save lives, Drive a honda
Add to 93SC2'in's Reputation
Rate the quality of this post and help 93SC2'in reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
93SC2'in is offline   Reply With Quote
Old 03-25-2009, 02:30 AM   #7
A co-worker once decommissioned an old '80s Mustang in her driveway. A year later, another friend needed a car. Engine in Jeen's Mustang was seized. For grins, we threw a couple ounces of MMO into each chamber, and a week later, the engine turned. Got it started, and Cindy drove that car for about a year before it blew up.
Add to madpogue's Reputation
Old 03-25-2009, 06:20 AM   #8
Squareback
Squareback's Avatar
2005 ION-2 Sedan
It will work on engines that don't turn due to non use. Usually a rust ridge forms in the cylinder walls and the MMO helps break it up and get the engine moving again. An engine that failed while driving due to lack of lubrication has zero chance of coing back with MMO.
Certified Saturn Technician
Old 03-25-2009, 07:35 AM   #9
wolfman
wolfman's Avatar
Perfect reply. The seizure in this case is most likely at the rod and or main bearings at the CRANKSHAFT. MMO will do nothing.
Add to wolfman's Reputation
Old 03-25-2009, 09:19 AM   #10
OnDaGround
OnDaGround's Avatar
1993 SC2
oh that's not so bad. nothing a bit of locktite can't handle. lol.
Saturnless...
Old 03-25-2009, 09:21 AM   #11
DonP
Well, maybe if the MMO is deep enough to float the car and is flowing in the direction you want it to go
Add to DonP's Reputation
Old 03-25-2009, 11:09 AM   #12
mgordon1100
Yeah, here's the backstory. He changed it "two" oil changes ago. I tried changing it again in the middle of the winter, but I could not get the filter to budge. It was fused on there real good. It was freezing, even in the garage, so I just drained out what was left of her crappy oil and refilled it. She drove another four months, and this time he tackled it again. He still didn't get the filter off, but he must have loosened it a little, or he put a hole in it and didn't know. She said he blamed me for it because "Mike was the last one to change your oil. It was his fault". She knows it wasn't my fault and blames him for losing her car.
She ended up getting another car on borowed money. I asked her why she doesn't just have another engine put in it, as it will be cheaper. She's got her mind set that the Saturn probably will only last another year. I coudn't convince her that the car is good. Here's the thing, no matter what she does with the car, my name is on the title and I have it sitting right here. She needs me to be able to do anything with it. I hope she pays for it to be towed to me.
Old 03-25-2009, 11:33 AM   #13
Carlr33
Carlr33 is on a distinguished road
More than likely if he put any stress on the filter with a filter wrench or other tool he put a small hole in the filter causing the leak.
206,000 MILES
Add to Carlr33's Reputation
Rate the quality of this post and help Carlr33 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Carlr33 is offline   Reply With Quote
Old 03-25-2009, 11:44 AM   #14
Sounds like he tightened it down to the "proper" 500 lb torque
I took my Breeze to the local Walmart oil change once, when they first opened up, because I was in a hurry. Next oil change, I drained the oil... then tried to remove the filter. I could not get that sucker off with cap wrenches, screwdriver stuck through, etc.
When I finally got it off with a big-*ss channel-lock type wrench around the base (no joke, I was underneath and I was pulling most of my 200lb body weight off the ground trying to turn it) I saw that the moron that put the filter on had tightened it until there was metal-to-metal contact - he gouged the outside of the engine block.
If this moron does her maintenance, she's probably right
Old 03-25-2009, 12:16 PM   #15
93SC2'in
93SC2'in's Avatar
1993 SC2
i had this same problem when i got my saturn and did my first oil change the filter was on so damn tight and it was to damn small for one of those filter strap wrenches so i put a strip of rubber around it until i could get a good bite with the strap and that worked like a charm but still it was on insanely tight probably a wal-mart special
yeah thats entirely different like stated above that engine was just frozen probably from rust on the rings as where the OP had no oil in there engine... MMO wont do squat to a properly seized engine...
oh and dont ever let people drive around in something thats in your name thats just asking for trouble
Old 03-25-2009, 12:16 PM   #16
amazinghl
Got AAA? If so, tow it back your place for free.
00 Insight 72mpg
Old 03-25-2009, 02:00 PM   #17
Fox Slaughter
Fox Slaughter is on a distinguished road
Fox Slaughter's Avatar
An engine that sits and builds up rust you can sometimes just crank it over long enough that it breaks free. This could cause scoring of the walls through. Thats what a good old cast iron block is for though ahaha.
I'll be sitting at my desk
With a gun in my hand, wearing a bulletproof vest singing
"My, my, my, how the time does fly, when you know you're going to die
By the end of the night."
Add to Fox Slaughter's Reputation
Rate the quality of this post and help Fox Slaughter reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Fox Slaughter is offline   Reply With Quote
Old 03-25-2009, 05:18 PM   #18
p-ROCK
p-ROCK is on a distinguished road
p-ROCK's Avatar
Originally Posted by westwind999 View Post
+1 slim to none.
"What the hell are you talking about, a monkey with a wrench could change oil"
"So what are the two things you want to make sure about that an average joe would have no idea about?"
"Take the oil cap off and tighten the hell out of the new filter"
WRONG
"Make sure the old gasket came off, and lubricate the new gasket."
1996 SL2 5-speed Silver Pearl
134,000 miles
204k as of 01/12
220k as of 08/12
2002 Jaguar XKR Coupe Black
42,000 Miles
50k as of 01/12
52k as of 08/12
Add to p-ROCK's Reputation
Rate the quality of this post and help p-ROCK reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
p-ROCK is offline   Reply With Quote
Old 03-26-2009, 07:39 AM   #19
DonP
Up to a point. The AAA free tow is typically for a limited distance and you pay for any extra distance. What distance, check with your local AAA. Still a good benefit for members.
Old 03-26-2009, 09:46 AM   #20
Fox Slaughter
I have free towing up to 500 miles.
Oh NO! my engine seized!! :( andy_95sl2 S-Series Tech 18 11-01-2006 05:48 PM
Engine Seized????? jagermachine S-Series Tech 24 02-24-2005 04:45 PM
Seized engine bolts:Removal?? Help! 1995SW1 S-Series Tech 17 02-04-2005 02:23 AM
