Old 03-19-2009, 04:03 PM   #1
Pega_de
Pega_de is on a distinguished road
1994 SL1
Default Trunk is wet in my '94 SL1
Hy,
I've found last monday in my trunk a lot of water in the driver and passenger side. I donn't know where the water comes, because last summer I have seal some parts of the trunk with silicone on the outside.
I've removes all carped's in the trunk, and see that ALL seals in the inside are a little bit wet, anybody knows where the water comes in the inside?
Marco
Add to Pega_de's Reputation
Rate the quality of this post and help Pega_de reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Pega_de is offline   Reply With Quote
Old 03-19-2009, 04:08 PM   #2
Fox Slaughter
Fox Slaughter is on a distinguished road
Fox Slaughter's Avatar
Default Re: Trunk is wet in my '94 SL1
I have a problem of water on my passenger side on my SC. I will get a tiny lake back there and it pisses me off.
I'll be sitting at my desk
With a gun in my hand, wearing a bulletproof vest singing
"My, my, my, how the time does fly, when you know you're going to die
By the end of the night."
Add to Fox Slaughter's Reputation
Rate the quality of this post and help Fox Slaughter reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Fox Slaughter is offline   Reply With Quote
Old 03-19-2009, 04:16 PM   #3
Pega_de
1994 SL1
on both sides of my trunk was 3cm of water, that's sick
Old 03-19-2009, 05:04 PM   #4
KCdave
KCdave is on a distinguished road
KCdave's Avatar
3 CENTIMETERS? wow.
That's not a puddle. It's a swimming hole.
Is the water in the spare tire compartment or at the sides?
You need to put some newspaper down and line the floor of the trunk.
If it's warm enough, close the trunk and hose the rear window with a garden hose.
Check and then spray along the trunk lid.
I think the water is traveling under the outer panels, but you need to find the water track.
_______________
5 Speed Manual
Add to KCdave's Reputation
Rate the quality of this post and help KCdave reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KCdave is offline   Reply With Quote
Old 03-19-2009, 05:05 PM   #5
With the 2nd gen SC's it's a fairly well known & documented problem with the factory weld. Dunno if its the same type of problem or not on the OP's '94 but with the SC's you have to take the rear fenders off, scrape the black sealant crap off and put something else there. I used roofing tar (it was handy... lol) on my '97 SC2.
Old 03-19-2009, 05:46 PM   #6
saturncrzy
saturncrzy will become famous soon enough
1992 SL2
i had this same problem but only on the passenger side the way i found out was have someone lay in the trunk with it closed and a flash light and get the hose and spray the back end of the car and you will find it. Mine was leaking where the spot welds are in the gully by the seal. I ended up welding around the spot welds and then used clear rtv silicon and i have no more leak probs.
Add to saturncrzy's Reputation
Rate the quality of this post and help saturncrzy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturncrzy is offline   Reply With Quote
What caused my wet trunk f3qu3t S-Series General 20 01-21-2017 08:07 PM
My Wet Trunk Jsolts S-Series General 13 12-29-2013 07:38 PM
2000 sc1 - Wet trunk julibill S-Series Tech 6 04-27-2008 02:01 AM
Trunk problems (not wet though) fetchitfido S-Series Tech 2 06-05-2006 04:43 AM
Wet trunk anyone?? green_sc2man99 S-Series Tech 17 05-16-2006 10:13 PM
