Old 02-26-2009, 01:49 PM   #1
wolffboy
wolffboy is on a distinguished road
Default 2001 SL2 LOW power 2 codes
Replaced ACTS 3 weeks ago, car was running fine. Yesterday experienced loss of power and clicking noise when loading engine. Car has trouble reaching 60mph. Idling rough. Running a little warm as well.
Codes are P0172 and P0341. I know this car has no "Cam Position Sensor" Have read many threads regarding this code, and most did not have the poor performance issue I have.
Any help is greatly appreciated.
Add to wolffboy's Reputation
Rate the quality of this post and help wolffboy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wolffboy is offline   Reply With Quote
Old 02-26-2009, 02:15 PM   #2
rc1488
rc1488's Avatar
Default Re: 2001 SL2 LOW power 2 codes
Its ECTS.
If you read the threads on the Cam Position sensor then my next question would be did you do anything that was listed by other members regarding this code?
Check your ECTS connector. It needs to be clean and corrosion free.
Add to rc1488's Reputation
Old 02-26-2009, 02:19 PM   #3
wolffboy
I replaced the ECTS with a Saturn Brass one 3 weeks ago.
I have not replaced the spark plugs or wires, although the plugs were replaced in July 08.
Old 02-26-2009, 02:24 PM   #4
rc1488
rc1488's Avatar
The connector to the ECTS needs to be verified for lack of corrosion. A corroded connector is just as bad as having a bad ECTS.
Spark plug type?
Have you cleaned the mounting plate on the ignition module and tranny?
Clean the coil posts?
Age of the current wires?
Define "warm" operating temps. Normal is 3/8 read from the gauge.
Old 02-26-2009, 02:29 PM   #5
wolffboy
Would a bad connector indicate coolant temp at all?
Spark plug type? Bosch Platinum (i know this is not preferred)
No
No
Original as far as I know (bought the car with 98K
Its about 3/8, but higher than it was running before
Old 02-27-2009, 11:27 AM   #6
wolffboy
Took car into mechanic this morning, he told me:
Cylinder 4 is out
Need to remove heads to diagnose ($1100)
Is it time to retire this car?
TIA
Old 02-27-2009, 12:20 PM   #7
rc1488
rc1488's Avatar
Cylinder 4 is out
TIA
Compression numbers?
Old 02-27-2009, 12:28 PM   #8
wolffboy
Mechanic said the compression test would be another $44 plus he said the plug wires are "crackling" and would need to be replaced upon removal for the test (they will break)
So, no I do not ave compression numbers.
Old 02-27-2009, 12:39 PM   #9
So without a compression test, how did your mechanic determine that "cylinder 4 is out"? What does "out" mean? I'm skeptical of any diagnostic done with a known bad set of spark plugs and wires.
For $44, you can BUY a compression tester and a spark plug socket, and have money left over to go toward replacing those shot spark plug wires and the no-no platinum plugs. If it turns out compression is low on #4, a few more dollars, or a bit of ingenuity and fabrication, can get you a leakdown tester to determine why the compression is low without removing the cylinder head.
For $1200 you can buy a couple of engines, or a whole 'nother Saturn.
I would be leery of trusting any mechanic referring to the "heads" (plural) on your car.
Add to madpogue's Reputation
Old 02-27-2009, 01:09 PM   #10
wolffboy
Thanks madpogue, I will get my own tester, cables & plugs & let you know what I find.
BTW the "mechanic" is Precision Tune Auto Care
Old 02-27-2009, 01:18 PM   #11
rc1488
rc1488's Avatar
Ummm i wish i had his x-ray vision.
Get your car out of there. Get your money back. And do your own testing and we'll help you with a diagnosis.
Old 02-28-2009, 02:13 PM   #12
wolffboy
OK, I changed the plugs (put in NGK) and the wires (7.5mm)
No change, still very rough, kind of a chugging sound
2001 sl2 low fuel pressure kidinfamous S-Series Tech 5 04-02-2009 10:12 PM
Humming sound in low speeds in 2001 SL2 Splops S-Series Tech 1 01-03-2007 06:40 AM
Humming sound at low speeds in 2001 SL2 Splops S-Series Tech 0 01-01-2007 09:24 PM
Low End Power On '95 SL2 axe9 S-Series Mods 37 10-14-2006 12:12 AM
2001 SL2 - High Idle in Park only & Low Coolant light JMR S-Series Tech 6 02-16-2006 07:24 AM
