Old 02-26-2009, 11:28 AM   #1
Timguy1008
Timguy1008 is on a distinguished road
Default Faulty switch??
My roommate has an early 00's L-200 I believe.
When she turns her turn signal on, her high beams come on... however, in the past few days, when she turns off her car, her high beams will randomly come on. This has led to her having to jump her battery at least once.
Is this a common problem? Is it a shorted wire, or will she need a whole new "headlight arm".
Add to Timguy1008's Reputation
Rate the quality of this post and help Timguy1008 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Timguy1008 is offline   Reply With Quote
Old 02-26-2009, 05:06 PM   #2
Default Re: Faulty switch??
You may be describing the combination switch stalk that sometimes fail. Check the threads from the past, in particular the model. There may be similar posts at the bottom of this page.
Faulty Lifter? mfedenko S-Series Tech 3 01-05-2010 11:34 AM
Workaround fix for faulty ignition switch mjkiefer General Saturn Discussion 0 01-19-2009 06:00 PM
Faulty Door locks and Dimmer Switch ldawsonAura Aura General 3 06-01-2007 02:30 PM
Faulty rear defrost switch? I don't think so now! SpaceFrame Miscellaneous Tech 4 02-12-2003 11:40 PM
Faulty Blinkers???? joshc L-Series Tech 11 07-18-2002 07:59 PM
