Old 02-25-2009, 05:53 PM   #1
TIMSPEED
TIMSPEED is on a distinguished road
TIMSPEED's Avatar
1998 SW2
Default New Saturn: OBD Code P0507 ??
So I got the code reader on my 97 SL2 and it showed a P0507...
Now, this has only been since I changed the thermostat yesterday...I'm thinking perhaps because it's finally running at the correct temp, a vacuum leak has shown up somewhere...
I'll replace the tubing for the PCV (PCV is brand new from Saturn), as well as the little tube that runs from the Valve Cover to the Air Intake.
Any other ideas?
Add to TIMSPEED's Reputation
Rate the quality of this post and help TIMSPEED reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TIMSPEED is offline   Reply With Quote
Old 02-25-2009, 06:53 PM   #2
saturncrzy
saturncrzy will become famous soon enough
1992 SL2
Default Re: New Saturn: OBD Code P0507 ??
po507 is Idle Control System RPM High
check your IACV=(idle air control valve)
Add to saturncrzy's Reputation
Rate the quality of this post and help saturncrzy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturncrzy is offline   Reply With Quote
Old 02-25-2009, 07:01 PM   #3
TIMSPEED
TIMSPEED's Avatar
1998 SW2
My IACV is clear/clean. I took the Throttle Body off the other day and gave it a good cleaning. This has only started happening since yesterday.
I'm thinking, while I was changing the thermostat, I may have bumped the PCV tubing or something, to cause an intermitten vacuum leak.
It only does it when it's fully warm though. Because after I changed the thermostat, I let it run for about 10 minutes in the driveway, to check for leaks, then like after 10 minutes, just out of the blue, the idle jumped up to 1500rpm and sat there.
This happened again after driving it to dinner last night, when we came back home and pulled in the driveway...
Old 02-25-2009, 07:05 PM   #4
saturncrzy
1992 SL2
i would check your ECTS. as this could be a cause of your idle being high the ECTS is the hart of these engines. How did you determin that you have a vacumm leak?
Old 02-25-2009, 07:23 PM   #5
TIMSPEED
TIMSPEED's Avatar
1998 SW2
I should probably link the other thread...
New Parts include:
Plugs, Wires, ECTS/Harness, Thermostat, PCV Valve, Cleaned Throttle Body, Air Filter, Oil/Filter, Trans Fluid/Filter, CPS, Upper/Lower Engine Mounts.
Basically, every part that is a wear item, was replaced.
Old 02-27-2009, 06:05 AM   #6
BarnOwl
BarnOwl's Avatar
One obvious question is what is the idle speed? I'll also add did you screw with the idle adjustment screw? You aren't supposed to mess with that.
Lastly, if you suspect a vacuum leak, spray some carb or brake cleaner around the manifold and hoses with the engine running. If you hear a change in idle, you've found it. Given what you've done, it might be the throttle body gasket.
Add to BarnOwl's Reputation
Old 02-27-2009, 10:36 AM   #7
TIMSPEED
TIMSPEED's Avatar
1998 SW2
Damn good guess...that was it!
Code p0507 in warm weather hydromech S-Series Tech 5 06-08-2007 10:39 AM
OBD II Code? autiger S-Series Tech 15 01-22-2007 09:51 PM
Code p0135, p0303, P0507 Fortigan S-Series General 9 02-22-2006 01:31 PM
OBD Code gags61 S-Series Tech 4 01-23-2006 02:10 PM
OBD 1 Code 11 KPot2004 S-Series General 2 03-23-2005 01:09 AM
