Old 02-19-2009, 08:52 PM   #1
adamscl
adamscl is on a distinguished road
Wrench SC2 Fog Light Replacement
Does anyone happen to know what the procedure is to replace an '02 SC2 foglight. This is the wife's vehicle, therfore I have not taken a close look at it yet to determine the necessary steps. Thought I would start here, for those who have already had to previously replace foglight bulbs. Also, is anyone using a bulb that seems to perform better than the stock bulbs? Thanks for any assistance!
2002 Cranberry Saturn SC2, 42,000 miles
2008 Toyota Highlander Limited AWD
Add to adamscl's Reputation
Rate the quality of this post and help adamscl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
adamscl is offline   Reply With Quote
Old 02-19-2009, 09:29 PM   #2
Low Saturn
Low Saturn's Avatar
2000 SC2
Default Re: SC2 Fog Light Replacement
Reach up from under the car, disconnect the electrical connector, twist and remove the bulb.
Install in reverse order.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 02-20-2009, 12:37 AM   #3
Scott Peterson
Scott Peterson is on a distinguished road
Scott Peterson's Avatar
I am curious also, as to what kind of aftermarket fog light assemblies you can buy for a SL2 ? what will fit in the small holes ?
1997 sl2, auto
I love the greaters too...you can't even tell who the *** he is greating. Both of his eyes are looking different directions. You only go to walmart for comic relief.
Add to Scott Peterson's Reputation
Rate the quality of this post and help Scott Peterson reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Scott Peterson is offline   Reply With Quote
Old 02-20-2009, 07:19 AM   #4
plasticoupe
plasticoupe is on a distinguished road
Scott Peterson asked, "I am curious also, as to what kind of aftermarket fog light assemblies you can buy for a SL2 ? what will fit in the small holes?"
A couple of years ago I put that question to lighting consultant Daniel Stern. His comment was something like 'without sticking them on the grille opening, I don't know.'
OTOH I'm wondering if a pair of the CIBIE "Tango" fogs Daniel sells could be adapted onto the rear of modified SC-2 fog light assemblies.(?)
J.R.
'01 SC-2
Add to plasticoupe's Reputation
Rate the quality of this post and help plasticoupe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
plasticoupe is offline   Reply With Quote
Old 02-20-2009, 10:08 AM   #5
Low Saturn
Low Saturn's Avatar
2000 SC2
If you can fab up a bracket, the possibilities are endless.
Mike
-2000 Saturn SC2
Old 02-20-2009, 12:50 PM   #6
For your '97? You can get aftermarket brackets that fit the OEM studs on the inside of the bumper via eBay. Or, if you get lucky, find a pair on a salvage car. With extremely modest fabrication (I'm a pretty crude fabber), they can accomodate the Pilot / Navigator brand 55W H3 driving lamps, which happen to be the same diameter as the OEM fog lamps, but considerably brighter, and with glass (or in some cases polycarbonate) lenses and steel housings.
Add to madpogue's Reputation
Old 02-21-2009, 01:13 AM   #7
eRic 02sc2
eRic 02sc2's Avatar
-- page 334 of the 2002 Saturn S-Series Owner's Handbook --
1. Turn off the foglamp switch and allow bulbs to cool before changing.
2. Reach through the opening in the fascia to the rear of the fog lamp.
3. Rotate the bulb socket counter-clockwise and remove it.
4. Remove the wire connector from the bulb by lifting the lock tab and pulling it away from the plastic base.
5. Remove the bulb and replace it with an appropriate bulb.
I've used Sylvania SilverStar 880ST bulbs in my 2002 SC2 standard fog lamps and they work great.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 02-21-2009, 02:19 PM   #8
Norseman
Norseman is on a distinguished road
I stopped replacing my fog light bulbs on my 1996 SC2 many years ago. Each time I replaced the bulbs, they would burn out in a few weeks. Probably some electrical problem that's not affecting any other electrical things other than the fog lamps.
Add to Norseman's Reputation
Rate the quality of this post and help Norseman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Norseman is offline   Reply With Quote
Old 02-21-2009, 02:28 PM   #9
Low Saturn
Low Saturn's Avatar
2000 SC2
Are you being careful not to touch the bulbs? What brand bulbs are you using? Is there any condensation on the housing?
Mike
-2000 Saturn SC2
Old 02-21-2009, 02:38 PM   #10
eRic 02sc2
eRic 02sc2's Avatar
wear gloves and don't lick them before pushing them into the socket. do you leave them "on" all the time? that burns them out sooner if they flash with the parking lights when you use the RKE to lock the door and set the alarm.
eRic 02sc2
2002 SC2 Fog Light problem phoenix02sc2 S-Series Tech 12 11-14-2014 11:19 AM
1996 SC2 Fog Light Install dnvoss S-Series Tech 2 02-26-2008 10:21 PM
Fog Light Replacement m98sl2 S-Series Tech 4 05-31-2006 05:50 PM
fog light bulb replacement 97SC2DOHC S-Series General 5 05-30-2005 10:36 AM
How to Install Fog Light '97 SC2 venusfan S-Series Tech 2 04-06-2004 05:29 PM
