Old 02-17-2009, 09:32 PM   #1
banana944
banana944 is on a distinguished road
Default All gears are forward gears?!
Well my sisters 95 SL had the reverse slam. Tried the cure, didnt work and I ordered a rebuilt valvebody from Wolfman. Finally got around to putting it in yesterday and now all hell has broke loose.
The new valve body looked slightly different, and I wonder if the old body which had 94 & 95 stamped on it was different for those 2 years?
But the real issue is that I put the rebuilt valve body in and now all the gears P R N D 3 2 all make the car go forward. There is no neutral in any spots and when it is in park it is deffinatly still trying to go forward. What the hell happened?
I took it all apart to make sure I didnt mess anything up and too make sure the arm on the VB was positioned correctly and it was. I then put the old VB back in to see if it was an issue with the rebuilt VB and now the old valve body is acting the same, all gears make it go forward?
HELP?!
Add to banana944's Reputation
Rate the quality of this post and help banana944 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
banana944 is offline   Reply With Quote
Old 02-17-2009, 10:26 PM   #2
heavyd10000
heavyd10000 is on a distinguished road
heavyd10000's Avatar
Default Re: All gears are forward gears?!
HELP?!
I had this problem before, but not sure the same, my problem was that the clutch plates seized together.
not sure what u mean by "had the reverse slam".
but if the clutches are seized together, put it in drive hit about 25 mph and through it in reverse, should release them, but if they are seized the tranny needs a rebuild, even if that procedure works.
1996 Saturn SL2 1.9L DOHC 5 spd 184K miles (bought 02/09 - Sold 08/2010).
Bought 92 Olds 88 Royale LS - 3800 V6
Add to heavyd10000's Reputation
Rate the quality of this post and help heavyd10000 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
heavyd10000 is offline   Reply With Quote
Old 02-17-2009, 10:26 PM   #3
ssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to all
Did you put the linkage from the shifter cable (a rod in side the trans) into the manual shift valve in the valve body?
Add to ssicarman's Reputation
Old 02-17-2009, 11:21 PM   #4
banana944
Could you elaborate on this a little more? I think you may be onto something. When I first took apart the VB there was a little rod in the tranny that seemed to be in a different orientation when I took it apart second time around. Is that arm supposed to fit onto the VB somehow?
Old 02-18-2009, 07:51 AM   #5
OU812
OU812 is on a distinguished road
1996 SL1
That arm that kinda looks like the tremelo bar on a guitar slides into a tube like
looking thing called the manual valve.
Add to OU812's Reputation
Rate the quality of this post and help OU812 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
OU812 is offline   Reply With Quote
5 gears or 4 gears? IVIYTH0S S-Series Tech 7 05-17-2009 04:45 PM
sc2 reverse fine, no forward gears or neutral diy by default S-Series Tech 12 03-08-2009 07:11 PM
Gears agoldslsaturn S-Series Tech 9 05-17-2006 05:00 PM
No forward gears 94stoner S-Series Tech 21 03-27-2005 02:45 PM
Do you go thru all the gears? joew44 Ion General 19 09-22-2004 09:46 PM
