Old 02-17-2009, 10:59 AM   #1
rotty john
rotty john is on a distinguished road
Default 2005 Saturn Ion Difficult to Start
Hello All,
Used to frequent this website when I had a 97 Saturn SL-2 it had over 250K when finally donated it.
Now I have a Saturn ION-3 has over 100K on it. Has the 2.2 ecotech engine. Have really never had any trouble with it. Only have had to do normal maintenance: oil changes, tires, brakes, plugs, fluids, etc...
Recently wife reports that car is difficult to start. No codes and no check engine light also reports that car stalled in traffic she needed to remove key and reinsert it to get it to start back up. She says that it also runs rough at times.
Just not sure where to jump in? Sure would appreciate any help thanks...
John
Add to rotty john's Reputation
Rate the quality of this post and help rotty john reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rotty john is offline   Reply With Quote
Old 02-17-2009, 11:22 AM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: 2005 Saturn Ion Difficult to Start
no fuel, no spark, or no crank, if your starting/charging circuit checks out (get it checked at advance auto or auto zone for free) then change your fuel filter (the cheapest part) if you still have problems, suspect plugs, if it still does it, suspect the ignition system. More cheap things you can do are clean the TB, the MAF, and the MAP, the MAF needs special cleaner, so don't be cheap.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 02-23-2009, 04:20 PM   #3
hrogi04
hrogi04 is on a distinguished road
I think the issue is much simpler...
There is a Known issue with Ions like this.
There is an ignotion control box in the steering wheel that needs to be replaced...
You should be able to search for it... it happen more when the Air temp is cold.
Add to hrogi04's Reputation
Rate the quality of this post and help hrogi04 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hrogi04 is offline   Reply With Quote
Old 02-23-2009, 05:04 PM   #4
2006 ion2
2007 ION-2 Sedan
read the problem, difficult starting (not a lack of) and stalling going over bumps. You might want to check your battery cable and all cables you can get your hands on, I had a loose battery cable from the factory that took some time to rear it's ugly head.
2007 Saturn Ion 2
2005 Ion Won't Start When Cold timb99 Ion Tech 3 01-01-2009 09:38 PM
Remote Start for 2005 Saturn Vue kitar77 Vue Tech 6 01-05-2006 09:21 PM
excessively difficult to start 1995 sl1 auto dp97sc2 S-Series General 13 12-20-2005 10:25 PM
2005 Saturn Ion rjamison Ion General 1 12-07-2005 07:56 PM
'97 SL2 difficult start MadAdam S-Series General 3 02-28-2005 04:39 PM
