Old 02-16-2009, 08:55 AM   #1
scrapmedallord
scrapmedallord is on a distinguished road
Default my car wont stay running and idky
okay heres the details it is a 1998 saturn sl2 with about 180k miles,
about a year ago the service engine light came on, said p0446 which is the Evap system "vent controll malfunction".
havent had anyproblems untill last night when the car died while driving. we checked out the battery it was putting out enough power.
its got fuel pressure, put a pressure tester on the fuel line to check to see if there was pressure while running. it had enough pressue. when the car shut off; it still had enough fuel pressure.
i can hear the fuel pump whine before you start the car.
has anyone had this problem before? please post replys on advice or anythign that may help.
could it be the crankshaft position sensor?
Add to scrapmedallord's Reputation
Rate the quality of this post and help scrapmedallord reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
scrapmedallord is offline   Reply With Quote
Old 02-16-2009, 10:54 AM   #2
Default Re: my car wont stay running and idky
In one word, YEP! But to verify a failed cps you'll have to perform 'rocket science' ( ) involving the spark test; when the engine dies unexpectedly, remove the coil wires and observe for sparks across the coil towers while someone cranks the engine over. The lack of spark across the coils usually indicates a faulty crank position sensor (CPS). The second fault may be the ignition module but more cps' fail than ignition modules. The cps is located above and behind the starter, mounted with one 10mm bolt. Buy it from any auto store stocking it.
Rough Idle Wont Stay Running DankAllumni S-Series Tech 9 08-07-2009 07:27 AM
sl2 wont stay running, driving me nuts spare_change S-Series Tech 9 11-03-2008 08:30 AM
2000 sl2 dome lights stay on and car wont lock from outside bloody1 S-Series Tech 3 10-14-2005 03:20 PM
02 L300 fuel pump/car won't stay running problem MustangKatie L-Series Tech 2 08-11-2005 09:02 AM
car wont stay running pkuptrk Miscellaneous Tech 1 01-04-2003 10:06 PM
