Old 02-15-2009, 11:53 PM   #1
Usumgal
Usumgal is on a distinguished road
Question How do I replace the Headlamp assembly in a 2001 SC2?
Hey folks. Got whats probably a stupid question for you. Its about my 01' SC2.
The clear plastic part of my drivers side headlight assembly is busted due to my drunken neighbors not knowing how to parallel park. Can anybody tell me how to replace it? I know on the older S Series models (without pop-up lights) it was a simple removal of two or three bolts. Is it the same with the 01 SC2?
Also, does anybody know of a good ( meaning reputable yet inexpensive) Saturn parts site that would have what I need?
Thanks all.
Add to Usumgal's Reputation
Rate the quality of this post and help Usumgal reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Usumgal is offline   Reply With Quote
Old 02-16-2009, 10:49 AM   #2
2NDSOUT
2NDSOUT's Avatar
1999 SL
Default Re: How do I replace the Headlamp assembly in a 2001 SC2?
Go to your nearest pick and pull yard and pull a Headlight cover yourself. Buying a new headlight cover will be more expensive.
Also check out www.car-part.com They are a national website that has links to hundreds of salvage yards across the U.S. that may have a good used headlight cover.
Doing it this way is alot less expensive on your wallet.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Old 02-16-2009, 12:58 PM   #3
Low Saturn
Low Saturn's Avatar
2000 SC2
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 10-10-2009, 03:22 PM   #4
saturnsctwo
when the headlamp pod is replaced does this mess up the aim, or do you not mess with the aim when removing the old light?
Old 10-10-2009, 03:39 PM   #5
PurdueGuy
PurdueGuy's Avatar
1999 SC1
It should have a bubble level to make aiming pretty easy, as long as you have the proper socket.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 10-10-2009, 03:55 PM   #6
saturnsctwo
what i mean is do you have to undue the aiming screws to get the old headlamp off, or can the old headlamp be removed without changing the aim? i know there is 2 aiming screws & when the headlamp pod is removed does the aiming hardware come off with the old headlamp pod or does the aiming hardware stay on the car & you simply unbolt the headlamp from the aiming hardware & that stays untouched? i forgot how that works...
my headlamp on ther now has perfect aim & i want to change the headlamp pod & leave the aim alone. dam that headlamp water already!
Old 10-10-2009, 05:17 PM   #7
PurdueGuy
PurdueGuy's Avatar
1999 SC1
aiming hardware is part of the headlight assembly. Assuming it's like my '99, you take out 2 bolts, undo the wiring harnesses, and pop it out of place vertically.
Old 10-10-2009, 10:46 PM   #8
eRic 02sc2
eRic 02sc2's Avatar
aim should not change when you replace the headlamp assembly (minus the bulbs) the 2 bolts you need to remove do not affect aim.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 10-10-2009, 10:47 PM   #9
saturnsctwo
Originally Posted by eRic 02sc2 View Post
the aim should not change if you replace the entire headlamp assembly (minus the bulbs) the two bolts that you have to remove do not affect aim.
what i'm doing is replacing the whole headlamp pod assembly. the old one is leaking as usual...
Old 10-11-2009, 12:47 PM   #10
Signmaster
I can't speak for the newer mounts, but on our '95 the lamp aim almost always changes. Why I don't know, but I guess it's sensitive to the exact mount location.
Our '95 has the older style mount with the metal brackets, so it could just be the extra leverage on the aim point and having it exact.
Signmaster is online now   Reply With Quote
Old 01-18-2010, 10:49 PM   #11
AndreasChen
AndreasChen is on a distinguished road
I used the search of forum and located this nice thread with a perfect illustration.
Now I am avaricious
where can I find a collection of these assembling charts? Thanks a lot!
02 Saturn SC2, noisy, trying to quiet it down...
Add to AndreasChen's Reputation
Rate the quality of this post and help AndreasChen reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AndreasChen is offline   Reply With Quote
Old 01-19-2010, 12:23 AM   #12
Low Saturn
Low Saturn's Avatar
2000 SC2
Default
Now I am avaricious
The factory service manuals.
Old 01-19-2010, 02:09 PM   #13
AndreasChen
Should I buy them somewhere or are there downloads?
Thanks!
Old 01-19-2010, 02:35 PM   #14
Low Saturn
Low Saturn's Avatar
2000 SC2
Thanks!
http://www.helminc.com/helm/product2...SET&itemtype=N
Mike
-2000 Saturn SC2
Old 01-19-2010, 02:47 PM   #15
AndreasChen
Thanks! But the price
Old 01-19-2010, 02:54 PM   #16
Low Saturn
Low Saturn's Avatar
2000 SC2
Its worth every single penny.
I have volumes for every year S-Series, one model year of the ION, one year of the VUE, 2008 Aura, 2001 Suburban, plus the DVD that covers every GM vehicle from 1998-2005.
You'd save that amount of money or more the first time you use those manual's to complete a repair that you'd otherwise have to go to the dealer for. Heck, the price of that set of manuals is just a few bucks more than the one hour labor rate around here.
Mike
-2000 Saturn SC2
Old 01-19-2010, 02:56 PM   #17
Derek McNelly
Derek McNelly is on a distinguished road
Derek McNelly's Avatar
I do have to agree with you on them being worth every penny. So much information, and none of the tomfoolery of the Haynes' manuals.
2002 Saturn SC2
DOB: 9/11/2001
Date Obtained: 10/28/2009
Add to Derek McNelly's Reputation
Rate the quality of this post and help Derek McNelly reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Derek McNelly is offline   Reply With Quote
Headlamp issues. Time to replace them anyway! Seņor Ramos S-Series Tech 3 10-28-2009 07:59 PM
cooler fan shroud assembly 2001 l200 2.2 peter strawn L-Series Tech 2 03-23-2009 11:55 PM
2001-2002 SC2 headlight assembly removal greencoupe02 S-Series General 1 08-11-2006 08:59 AM
Looking for 2001 sc2 headlight assembly... etbardensc2 Classifieds 1 06-17-2005 06:03 AM
2001 SC2 Headlamp Condensation Dave2001SC2 S-Series Tech 5 03-13-2002 03:07 PM
