Old 02-10-2009, 10:31 PM   #1
Ice Racer
Ice Racer is on a distinguished road
2007 ION-2 Sedan
Default Why is my transmission fluid black?
I changed the fluid in my 2001 sl 5 speed manual at 125,000 miles. I noticed that the fluid was awfully dark but thought it was because the fluid probably had never been changed. When I checked the fluid level at 140,000 miles, I noticed dark fluid on the dip stick. I drained it again, and sure enough, the fluid had changed in color to look almost like used motor oil.
Does anyone have an idea what is causing my fluid to turn from red to black?
Add to Ice Racer's Reputation
Rate the quality of this post and help Ice Racer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ice Racer is offline   Reply With Quote
Old 02-11-2009, 12:54 AM   #2
fishmed
fishmed is on a distinguished road
Default Re: Why is my transmission fluid black?
okay i could be wrong here but i dont believe you are using the right stuff in your trans you say you have an manual... but i believe you dont use the red stuff in a manual trans... i could be wrong but i am not sure... i would ask at your local auto parts store
Add to fishmed's Reputation
Rate the quality of this post and help fishmed reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fishmed is offline   Reply With Quote
Old 02-11-2009, 01:03 AM   #3
tehSaturn
tehSaturn will become famous soon enough
2001 SW2
I thought both auto and manual Saturn transmissions use Dex III Auto Tranny Fluid...
2001 SW2: 60k Miles @ 8/11
Add to tehSaturn's Reputation
Rate the quality of this post and help tehSaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tehSaturn is offline   Reply With Quote
Old 02-11-2009, 01:43 AM   #4
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
Oh, yeah, the same folks who try to sell you a crankshaft position sensor when you throw a P0341 code for the (we all know non-existent) CAMshaft position sensor. The same guys who will sell you platinum, iridium, kryptonite, plutonium, etc. spark plugs.
Um, NO! They might know what scent of pimp oil is apropos for impressing neighborhood girls, but even that says maybe.
As stated in EVERY owner's manual placed in EVERY glove box of EVERY S-Series car that rolled out of Spring Hill, the 5-speed transmission takes ATF. 'Course, as long as disinformation persists (as it evidently does) that it takes gear oil, as if it were a 1908 Apperson-Jackrabbit, there's the chance that some MENSA non-candidate indeed put gear dope in it. Iceracer, did you buy the car new?
Add to madpogue's Reputation
Old 02-11-2009, 05:42 AM   #5
Fox Slaughter
Fox Slaughter is on a distinguished road
Fox Slaughter's Avatar
Our transmissions take ATF. End of story. There is a clutch material in there that the gear lube likes to eat. Nom Nom Nom. 80w-90 gear dope, bad ideal in our Transmissions.
Add to Fox Slaughter's Reputation
Rate the quality of this post and help Fox Slaughter reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Fox Slaughter is offline   Reply With Quote
Old 02-11-2009, 07:01 AM   #6
Ice Racer
2007 ION-2 Sedan
I used ATF Dexron III when I replaced it the first time at 125,000. I don’t believe anyone had changed it to gear lube prior to this because the dip stick had so much dirt on it and the fluid smelled like ATF but was really dark.
Old 02-11-2009, 07:10 AM   #7
2NDSOUT
2NDSOUT has a spectacular aura about2NDSOUT has a spectacular aura about2NDSOUT has a spectacular aura about
2NDSOUT's Avatar
1997 SW2
If you have a Manual trans, as Madpogue stated; it takes ATF.
Most likely is that the previous owner had put Gear Oil in the box. Not unheard of...
When I bought my 94 SL2 back in Sept/Oct. 2007; it is a 5 speed. When I changed the manual trans fluid out, it was like really heavy dark chocolate milk looking. I drained it all out and put the regular reccomended ATF fluid in there.
You only need to use 2.6 quarts of fluid in a Manual Trans.
The Auto Trans takes, iirc; 6-7 quarts of ATF.
Bryan
94 SL2 215K Miles
97 SW2 246K Miles
Garaged
94 SL2 HCE, "Pearl"
Never Forget
94 SC1 340,501 Miles
Original Engine/Auto Trans
02/97-10/08
Gone 03/12
92 SL1
05 VUE
91 SC
Add to 2NDSOUT's Reputation
Old 02-11-2009, 02:05 PM   #8
tehSaturn
2001 SW2
Originally Posted by 2NDSOUT View Post
If you have a Manual trans, as Madpogue stated; it takes ATF.The Auto Trans takes, iirc; 6-7 quarts of ATF.
5.2 if you don't drain the torque converter. (Which I have NO idea how to do)
How to change transmission fluid in VUE with manual transmission David 93 SL2m Vue Tech 12 09-10-2012 04:35 PM
5spd Transmission Fluid Change - Fluid? Satsational S-Series Tech 17 10-20-2008 05:57 AM
122,000 miles on transmission with no transmission fluid change in car's history. foo General Saturn Discussion 10 04-22-2008 05:04 PM
Black Brake Fluid VEGAS_SATURN S-Series Tech 23 05-25-2006 10:12 AM
Brakes & Black Fluid cazzylee S-Series Tech 18 08-19-2005 12:01 PM
