Old 02-07-2009, 10:50 AM   #1
Steve-R
Steve-R is on a distinguished road
Default '06 Vue airbag light
The Airbag light on my wife's '06 Vue has been coming on for a while now. I'm pretty confident it is the clock spring in the steering wheel, as it will often come on or go off when the wheel is moved.
How do you remove the airbag or steering wheel to get to the clock spring?
Does anyone know where you can order Saturn parts online? The dealership told me the clock spring is $169 through them. Most GM parts can be ordered cheap from GMpartsdirect.com, but the part number they gave me doesn't show up on GMpartsdirect.
The dealership gave me this part number for the spring: 15849458
Add to Steve-R's Reputation
Rate the quality of this post and help Steve-R reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Steve-R is offline   Reply With Quote
Old 02-07-2009, 02:44 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: '06 Vue airbag light
PN 15849458 is listed on saturnparts.net for 107.89 and saturnparts.com for 88.33.
I've not dealt with either company.
I've attached steering wheel removal / install and airbag info for 04 Vue ... not sure its applicable for your year, but should give you an idea.
Be careful and good luck!!!
Old 02-10-2009, 10:50 PM   #3
Steve-R
Great, thanks for all the tips, I really appreciate it!
Old 02-10-2009, 11:09 PM   #4
Steve-R
On the back of the steering wheel, I don't see anything that even remotely resembles the triangle shaped openings. Is there some other type of airbag release on the '06 models?
Thanks!
Old 02-10-2009, 11:45 PM   #5
far2grumpy
far2grumpy's Avatar
My manual covers up to 05 Vue ... its too bad the data is not representative of the 06 but I've got nothing else to post. Sorry.
Old 02-11-2009, 12:02 AM   #6
Steve-R
No problem...thanks for the help. I removed the housing around the steering column behind the wheel, I can see the clock spring, but I can't get the wheel off to remove the spring.
06 VUE AWD airbag light VUEmaniac Vue Tech 13 08-22-2014 10:33 AM
Airbag Light? travisj027 S-Series Tech 1 11-10-2009 09:30 AM
'06 Vue with an intermittent airbag light Steve-R Vue General 1 01-31-2008 09:43 PM
2003 Vue problem with airbag light on and remotes work sometimes jimvue04 Vue Tech 0 06-11-2007 06:10 PM
Airbag light shurik S-Series General 2 11-15-2006 12:38 AM
