Old 02-02-2009, 10:57 PM   #1
peter strawn
peter strawn is on a distinguished road
peter strawn's Avatar
2001 L-Series 2.2L Sedan
Roll Eyes cylinder head gasket replacement
got a 2001 l200 sedan w/ 153,000 on it and they say the head gasket goes out at 150,000 so i got an xtra 3,000 out of it! Any way i have all the directions from All Data and was wondering if the finding of the cams center line ups and all can be done without the expensive computer tool i will never own? I can pretty much follw directions but i don't want to get into this project and need something impossible for me to do.
Add to peter strawn's Reputation
Rate the quality of this post and help peter strawn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
peter strawn is offline   Reply With Quote
Old 02-02-2009, 11:44 PM   #2
Default Re: cylinder head gasket replacement
Welcome to the Board.
Which engine? Always nice to know.
As far as the head gasket going at 150k----who is they? The head gasket will last as long as it lasts. It is designed to last for the life of the engine. If there are no problems with the head gasket then don't touch it.
As far as lining the cams up for disassemble or assemble is is all done mechanically/visually. There is no computer or scan tool used to line everything up.
Add to ssicarman's Reputation
Old 02-03-2009, 10:09 PM   #3
peter strawn
sorry it's the 2.2 liter. it runs great and i was loosing water very slowly until last weekend it started to loose it faster. my wife drove it about ten miles home and it ran fine. I proceeded to look at the oil and viola there was my water. I read something that said the head gaskets only last 150,000 miles on the Saturn 2.2 liter motors. Any way i need to change the head gasket and printed out the all data stuff it looks like you said. manual settings, cool. I must have been tired of reading or something thanks for your input.
Old 02-03-2009, 11:07 PM   #4
When you have the head off check to see if it was warped. These are strong reliable engines so for a gasket to it may be more a warped head.
Old 02-07-2009, 03:25 PM   #5
Wolfc70
Wolfc70 will become famous soon enoughWolfc70 will become famous soon enough
The ecotec engine has no known head gasket problems. However, the water pump seal can go causing coolant to get into the timing chain area, which is where it enters the oil. I would check this first.
"I tip my hat to the man who drives an Alfa Romeo" - Henry Ford
Add to Wolfc70's Reputation
Rate the quality of this post and help Wolfc70 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Wolfc70 is offline   Reply With Quote
Old 02-07-2009, 09:40 PM   #6
born again
born again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of light
2000 L-Series 2.2L Wagon
Being an all aluminum block/head combination, the L61 is unaffected by the usual differential thermal expansion that shreds head gaskets.
Add to born again's Reputation
Rate the quality of this post and help born again reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-08-2009, 01:06 PM   #7
peter strawn
wow nice to know that.
i already tore into it. but i'm taking lots of pics.
i did not see a spot where the head gasket failed leading me to believe i could have saved a lot of money replacing the water pump gasket.my number three cylinder has a slight .005-.008 scratch in it and i think i will let it go. my timing chain was upgraded at the Saturn dealership at 50,000 miles or so i wonder if i should change this? i got the head gasket kit at Napa autoparts for 161.00 and the head bolt kit for 89.00. i was looking in the All Data web sight and there is a way to check for the automatic fluid levels on these Saturns. But it's a.p.i.t.a. i don't know if i can post it though. let me know. thanks for all your help.
Old 02-09-2009, 08:06 AM   #8
Wolfc70
Since you have the engine a part, replacing the timing chains again (and guides and tensioners) may not be a bad idea. The 2.2l engines are fairly durable. In the Ion section here, some salesman put almost 400K miles on his 2.2L. He never had a head gasket issue.
The engines in the L series cars are not known for head gaskets problems (thankfully). Coolant loss on the 2.2l is usually the water pump, on the V6 it is the oil cooler/cover plate and thermostat housing.
Old 02-09-2009, 02:33 PM   #9
Ex-GMtech
Ex-GMtech has a spectacular aura aboutEx-GMtech has a spectacular aura aboutEx-GMtech has a spectacular aura about
2000 L-Series 3.0L Wagon
Ad the water pump to the V6 cars.
OMG this car is easy to work on!
2000 LW2
2016 Impala
1986 GLHS
Add to Ex-GMtech's Reputation
Rate the quality of this post and help Ex-GMtech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ex-GMtech is offline   Reply With Quote
Old 02-09-2009, 03:26 PM   #10
Wolfc70
Uh oh! I take it the water pump won't make it to the 100k mark? At what mileage do they seem to fail? I thought it would last at least until the timing belt change. Something I may have to keep an eye on.
Old 02-09-2009, 07:06 PM   #11
Ex-GMtech
This is my opinion. I have seen or heard of enough to put it down as a place to watch. Wife's car only had 74K(IIRC) when hers died. I have seen others that get to between 70k-90k when they poop out.
2000 LW2
2016 Impala
1986 GLHS
Old 02-11-2009, 12:16 AM   #12
peter strawn
so far the head gasket does not appear to have failed i'm on to the front of the motor on Friday i have no garage and only a carport so it's cold out there.
I got 153,000 out of the waterpump gasket. I got the timing chain and guides changed at the factory at 50,000. do you think i should still change it? The wear on the guides is not really that bad. can i calibrate these guides for the wear? Also any ideas on how to clean out the motor from my milk shake look?
maybe drop the oil pan?
Old 02-16-2009, 04:53 PM   #13
peter strawn
how does one see that this has failed should i assume that since there is no failure spots on the head gasket that it is the water pump. everything's already apart now accept the water pump.
Old 02-19-2009, 04:25 PM   #14
autonoob42
autonoob42 is on a distinguished road
2000 L-Series 3.0L Sedan
You are so right about that, Quimosabe.
The water pump in my 2000 LS2 6Cyl 3.0 failed at about 75K.
It's been downhill ever since. (see later post by me).
AUTONOOB42
Add to autonoob42's Reputation
Rate the quality of this post and help autonoob42 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
autonoob42 is offline   Reply With Quote
Old 02-20-2009, 06:42 PM   #15
Wolfc70
It all depends on the gasket design. The newer MLS (multi layered steel) gaskets can be tough to find where it failed. Discoloration that leads away from a water jacket can be a slight clue. Some gaskets (like the paper/cellulose ones Alfa Romeo uses on their v6, which has wet liners) are easy to tell where they fail. I still have my doubts to the head gasket failing. If you have them, maybe post some pics of the gasket and related mating surfaces.
Old 02-27-2009, 10:45 PM   #16
peter strawn
Wrench Re: cylinder head gasket replacement
ok just got the head pressure tested and it failed the head is cracked and no good. i need to replace this it was a very slow water leak failure into my oil but the worst is done now i know what failed. i wanted to let everyone know i appreciate all your help thank you. Oh and buy the way always fix the check engine light feature. i took pics of the dismantling if i figure out how to upload them here maybe i can. I'm doing the water pump, timing chain, and head on this motor hopefully i'll get another 153,000 out of it.
1.9 SOHC Cylinder Head/Head Gasket..... Coolant Leak BRIAN41920 S-Series Tech 12 01-21-2014 02:40 PM
Cylinder Head Gasket Replacement... twhitney S-Series General 10 01-11-2009 08:20 PM
Questions on Cylinder Head Gasket Job xserver S-Series Tech 13 09-04-2008 06:52 PM
SW2 number 1 cylinder wet - Head gasket or Intake Manifold gasket? jcw S-Series Tech 4 05-09-2008 02:42 AM
Blown head gasket...vs....cracked cylinder head?? schultp S-Series Tech 1 06-25-2007 10:16 PM
