Old 01-30-2009, 01:16 PM   #1
jonus311
jonus311 is on a distinguished road
Default check engine light and antitheft light 2004 L300
Here I am again folks,
On the 2004 Saturn L300 (4cyld), I just recently replaced a bad engine control module. Now the car has its emmisions light on, check engine light on, and antitheft light randomly comes on 2 weeks after the module replacement. This just started happening today, but when I took the car in earlier to autozone for a diagnostic, it was saying random misfiring piston and catalatyic problem. But these were two previous codes that (I thought) had been resolved. I put in a new catalatyic converter and a new engine control module.
I read on other threads that it could the Body Control Module (BCM).
Does anyone have any suggestions before I take it to a mechanic?
Thanks for your help!
jonus311 is offline   Reply With Quote
Old 01-30-2009, 02:50 PM   #2
Default Re: check engine light and antitheft light 2004 L300
I read your other posts about the ignition control module failure so this new problem may be related or a new one as far as the check engine and anti-theft light turning on. Emissions light? Where?
If the check engine light flashes, it indicates damage may result to your converter if you continue driving. Some members lose their converters in as little as 10 miles. The factory anti-theft system, if I'm not mistaken, will flash its security light if a theft attempt is made (no engine run possible because the fuel pump's disabled) but light up if there's a fault in the system to alert you that its disabled leaving the car without protection. The security light going on and off may light up the check engine light. Same problem but only one can be read by Autozone when the SES light remains on.
Is the random misfiring from the ignition control module problem or an assumption of continuing problems?
BTW, update your info as the L300 has the 3.0L V6 engine while yours is the L200 2.2L 4-cyl. engine. The BCM causes other problems as the car acts "possessed" with lights, horn, and wipers going at random. Check past threads about expensive BCM replacements. Only Saturn can program replacements.
VCX NANO
Old 01-31-2009, 09:55 AM   #3
s3nfo
s3nfo's Avatar
2001 L-Series 3.0L Wagon
In the last year of production Saturn in their infinite wisdom decided that a designation change would help sell cars. So, they made everything an L300 followed by a .X to designate engine and trim.
L300.1 = L100
L300.2 = L200
L300.3 = L300
Technically you can have an L300 with a 2.2 engine, but technically it would be a L300.1 or L300.2
Jerry N
Groucho Marx
2004 Saturn ION 'Check Engine Light' JunkYardSaint Ion General 15 12-12-2015 03:06 PM
Flashing Check Engine Light - 2004 Vue addicted2mickey Vue Tech 19 01-07-2014 11:21 PM
2004 L300 V4 antitheft lights randomly, no start jonus311 L-Series Tech 1 09-16-2009 11:53 AM
L300 V6 Check Engine light Razzor19 L-Series General 4 10-30-2008 04:27 PM
Check Engine Light W/ Reduced Power light saturnfreak01 L-Series Tech 5 01-25-2004 12:04 AM
