Old 01-27-2009, 02:43 AM   #1
dorisSL
dorisSL is on a distinguished road
dorisSL's Avatar
1995 SL
Default watching Richpin's GPS video
so i just watched Richpin's GPS install video. he showed using the power window relay spot for a switched ignition power.
does that mean that the power wire is there even on cars without power windows?
can i use that wire for other things? how much power can i run through there?
semi-sorta-kinda-just barely related question - the three little buttons above the radio (where the defrost button is) - my car only has the defrost button, can i grab one od those from a j/y and its harness, and use those buttons for other things? are they click on/click off buttons, or something different?
1995 SL, born 12/23/94, manual, WAI 190,500, "Doris"
(I'm Ben, the car is Doris)
you can't mulch at those speeds man, that's too fast
Add to dorisSL's Reputation
Rate the quality of this post and help dorisSL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dorisSL is offline   Reply With Quote
Old 01-27-2009, 11:23 AM   #2
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
Default Re: watching Richpin's GPS video
Yes the power wire is there even on cars without power windows.On a 98 it is routed through the IGN 3 fuse which is rated at 10A.Now on your 95 it is routed through the same fuse but is rated at 7.5A so don't put a amp or wide widescreen tv on there................
Add to richpin06's Reputation
Rate the quality of this post and help richpin06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-27-2009, 02:04 PM   #3
Thoroughly OT, but a big THANK YOU to you, richpin.
I spent a few hours at the local library downloading youtube videos; got them all on DVD now
I'm ready for just about anything (once it gets warm )
Old 01-27-2009, 03:01 PM   #4
richpin06
richpin06's Avatar
Just to let you know i have all my videos in DivX format which look great. Youtube does not do them justice,for any one who wants them.How you are going to get them is a different story...........
Old 01-27-2009, 05:34 PM   #5
Ooooh....
Assuming you are running WinXP, select the folder your videos are in and right-click, select "send to compressed folder". This will zip them into a single file in the same folder. (you don't really get much additional compression, it just makes it easier to upload as a single file than a bunch of small files)
Next, upload them to a free file-hosting site. Some ideas:
www.yousendit.com <- This has a 2 gb limit
www.filedropper.com <- I think this has a 5 gb limit
Then post links for us lunatics who want better vid than YouTube
Seriously, for 99% of the stuff, YT works fine. I'd think you would only want better quality to show certain parts, like where a crack on a circuit board is, a resistor that burns out a lot, or something like that.
Old 01-29-2009, 01:55 AM   #6
dorisSL
dorisSL's Avatar
1995 SL
any thoughts here?
i was thinking of using one of these switches for my foglights
Richpin's How To Videos Sticky 1994Saturn How-To Library 68 08-21-2018 10:38 AM
So I was watching "Teen Mom" on MTV earlier and... adventureoflink S-Series General 5 12-30-2009 07:34 PM
motor mount question after watching richpin video saturnsl293 S-Series General 3 04-11-2009 08:54 PM
richpin's video - battery hold down removal bez S-Series Tech 14 10-15-2008 11:51 AM
