Old 01-21-2009, 06:38 PM   #1
knox
knox is on a distinguished road
2002 L-Series 3.0L Sedan
Default O-rings for heater core?
Hello I read on here about using O-rings from a hardware store to fix a leaking heater core. The size I have is 1" O.D. 3/4" I.D. and 1/8" thick. And I can't get the pipe to fit with the new O-rings. They are too big! Were do I find the correct size? Now I seen that I need 1" O.D. 9/16" I.D. and 1/8" thick. Is this the right size? I have went to Ace, Lowe's and Auto Zone. Any help would be appreciated.
Add to knox's Reputation
Rate the quality of this post and help knox reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
knox is offline   Reply With Quote
Old 01-22-2009, 12:47 PM   #2
GregS&L
GregS&L is a jewel in the roughGregS&L is a jewel in the roughGregS&L is a jewel in the rough
GregS&L's Avatar
2001 L-Series 3.0L Sedan
Default Re: O-rings for heater core?
Welcome to the board.
When you say the pipe will not fit, is it because the inside diameter of the o-ring is too small for the pipe or is the outside diameter of the o-ring too big for the heater fitting? Believe 1" O.D. 3/4" I.D. and 1/8" thick is the correct size. I measured my old o-rings and that was the correct size, although the OD was closer to 15/16" - probably smaller due to compression.
Did you lube the o-rings, the pipe and the fittings with Teflon paste or silicon grease before installing? It is a tight fit. When I did mine a year or so ago, I could not get the pipe, the o-rings and the clamp to bottom out in the heater fitting without lubrication. Once I got it all (with some wiggling and pushing) it has not leaked a drop.
Add to GregS&L's Reputation
Rate the quality of this post and help GregS&L reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GregS&L is offline   Reply With Quote
Old 01-24-2009, 10:25 AM   #3
knox
Ok, well I guess I'll lube the pipes and try again. Thanks for the help!
Great deal on heater core "O" rings s3nfo L-Series Tech 2 03-27-2008 10:46 AM
Used Heater Core Okay? Burgertime631 S-Series Tech 4 02-21-2007 12:46 PM
Help please...heater core? lcdrgas L-Series General 7 02-04-2007 09:17 PM
Heater core help Burgertime631 S-Series Tech 1 02-04-2007 06:32 PM
Heater core justin_zink S-Series Tech 2 12-08-2006 09:23 PM
