Old 01-20-2009, 09:16 PM   #1
jcono
jcono is on a distinguished road
Default SES light won't reset
Hello-
My SES light has been on for a while- usually this is the old gas cap thing, and after noticing cracks in the seal of the cap I replaced it. Unfortunately the light has not reset.
The low coolant light was coming on for a few seconds every once in a while, so I added a small amt. of coolant and it has not come on since. I figure because I added coolant if this was the cause the light should have reset itself by now?
Finally I had read on the forum that disconnecting the neg. battery cable for a few seconds would reset the SES. I tried this and it did not work either- the light never went off for a minute.
Can anyone make any suggestions?
Thanks for your help!
Jan
Add to jcono's Reputation
Rate the quality of this post and help jcono reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jcono is offline   Reply With Quote
Old 01-20-2009, 09:27 PM   #2
Default Re: SES light won't reset
Tried Autozone for a free reading? Then post the codes here for more help. Some codes cannot be reset (hard failures) unless the broken part is repaired/replaced so trying a reset just lets it pop up immediately. Our on-board diagnostics are run automatically each time the ignition key is turned to the ON position. The how-to library lists the codes too, on page 5 titled OBD II Powertrain Codes.
2002 SL1 - Which fuse do I pull to reset the SES light & computer? 2002SaturnMan S-Series Tech 5 08-30-2009 07:46 PM
How do I reset SES light? lucy0076 Vue General 2 08-20-2009 02:55 PM
Reset SES light 04Pacific Vue General 6 01-10-2009 03:00 PM
SES, not shifting out of 1st, reset PCM, all better. randall flagg S-Series Tech 5 10-12-2008 07:53 PM
How to reset SES on 97 SC1 katefan0 S-Series Tech 2 09-02-2006 02:05 PM
