Old 01-15-2009, 04:58 PM   #1
strongmad
strongmad is on a distinguished road
Default CAN-bus / GMLAN
Anybody know if all VUEs made after a certain year use either the CAN-bus or GMLAN protocol? If so, what year did they make that switch?
Also, does the instrument cluster for the VUE (assuming CAN-bus or GMLAN is used) connect directly to the bus? or if not, how is it connected to receive its speed, tach, fuel, and temp information?
Thanks for your help.
strongmad is offline   Reply With Quote
Old 01-16-2009, 01:05 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: CAN-bus / GMLAN
This data bus stuff is over my head ... but I've got nothing better to do until temp climbs above zero and I can go outside and throw a frozen Frisbee to my idiot brain dog.
I've attached extract from 05 Vue FASM with data-bus information as well as BCM data related stuff.
I had a copy of IPC schematic but it continues to elude.
Old 01-16-2009, 02:53 PM   #3
MaxSL2
MaxSL2 is on a distinguished road
MaxSL2's Avatar
2003 VUE 2.2L
It looks like any '02-'07 uses the class 2 data bus to communicate between the BCM and the cluster. '08+ is low-speed GMLAN.
MaxSL2 is offline   Reply With Quote
Tags
can bus, can-bus, canbus, gmlan, instrument cluster
GMLAN Version in 2009 Aura XE SpohnSoftware Aura General 1 09-29-2009 07:22 PM
Greyhound Bus turn 3 greyhound bus Vue General 1 08-30-2009 10:58 PM
Taking the bus to work. Low Saturn General Saturn Discussion 5 06-20-2008 12:51 PM
'03 L300 L81 w/or w/o CAN bus? fdryer L-Series Tech 2 02-03-2006 12:57 AM
OBDII and CAN bus jeffb S-Series Tech 9 10-02-2003 09:59 AM
