Old 01-14-2009, 01:18 AM   #1
WadeNKC
WadeNKC is on a distinguished road
Question Coil packs on 1998 Saturn SL2. Any body know?
I love this site Good people great and great advise!!
I have a 1998 Saturn sl2 5 speed manual transmission.
First I need to replace the coil packs. My brother in law replaced the ignition module a couple of weeks ago, but still coming up with OBD2 codes (Ie: PO302 and PO300) after replacing the spark plug for cylinder 2 it read the ODB 2 code 300 ( multiple cylinder missfire) anyway, the only other thing to do is replace the coil packs. I am looking to replace the coil packs with "accer" brand. My brother in law says they are the most durable. However I need to know if those brand coil packs are going to "bolt in a stock location" " his words not mine. Also need to know if a need two of these or just one for the entire system?. I do not know how to test the coil pack, so he says its best to replace both. If this doesn't work the next step is a dealership. My bro in law is in Louisiana and i am up here in Kansas City. He is going to walk me through replacing the coil packs on the phone. I do not want to go to a junk yard and pull a coil off of a scrap heap, I am going for maximum durability here! Also I do not have much information on the car, it was giving to me for free (Yaaa!!!) I do not have owners manual but i do have a Haynes repair book. I do know that the car is 4 cylinder single over head cam (? i think) and the vehicle Vin is a 1G8, can anyone tell me more specific info about the car, The Haynes manual just gives a general breakdown and all the cars of Saturn sl2 1998 and I don't know which is which? thanks!!
Add to WadeNKC's Reputation
Rate the quality of this post and help WadeNKC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WadeNKC is offline   Reply With Quote
Old 01-14-2009, 04:42 AM   #2
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Default Re: Coil packs on 1998 Saturn SL2. Any body know?
Replacing the coil packs is a piece of cake. In general the aftermarket coil packs fail more often than the OEMs on the S-Series, including aftermarket "performance" coil packs.
As easy as the coil packs are to replace, I'd order an OEM one from saturnparts.net, or pick one up from a local dealership, then swap it out with one of your coil packs. If that doesn't work, you can swap the new one over to the other coil pack location.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 01-14-2009, 09:33 AM   #3
Cheyne
Cheyne will become famous soon enough
2000 SL2
SL2 is a DOHC. What is the eighth digit of the vin?
Add to Cheyne's Reputation
Old 01-14-2009, 10:02 AM   #4
Low Saturn
Low Saturn's Avatar
2000 SC2
FWIW, I've have a set of aftermarket coil packs go from car to car to car for the past 11 years.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 01-14-2009, 12:39 PM   #5
paulo
paulo will become famous soon enoughpaulo will become famous soon enough
Richpin has a video on replacing as well as cleaning the ignition control moduole. You can find this video in the "How to Library". Much better than information over a telephone line. Sometimes the ignition control moduole looses it's ground due to corrosion and then begins to malfunction. These parts are not cheap. I would do the cleaning first- also a video by Richpin on this topic.
Add to paulo's Reputation
Rate the quality of this post and help paulo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
paulo is offline   Reply With Quote
Old 01-14-2009, 12:57 PM   #6
Low Saturn
Low Saturn's Avatar
2000 SC2
Keep in mind that the ignition control module gets it ground through the four mounting bolts and the wire harness. Not the plate at the bottom that makes contact with the transmisson casing. Thats used as a heatsink.
Mike
-2000 Saturn SC2
Old 01-14-2009, 08:23 PM   #7
No mention of the plug wires being checked or replaced, unless I am going blind. if there was a bad coil you would have a misfire on the mated cylinder as well.
Add to ssicarman's Reputation
Old 01-14-2009, 08:38 PM   #8
kevinss2001
kevinss2001 is on a distinguished road
2003 L-Series 2.2L Sedan
i just had the same problem with my 96-same code--my friend a saturn tech told me to replace coil 1--so i started to take it apart and there was some corrosion--i cleaned the bolts and the coils and the module and everything has been working great for 3 weeks now--my car would not start before christmas--i would try that--if you want to replace the coils i would do so with oem coils and change the plugs while you are at it--make sure you clean the bolts though--unless the new ones come with new bolts
by the way the richpin videos are great
Add to kevinss2001's Reputation
Rate the quality of this post and help kevinss2001 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kevinss2001 is offline   Reply With Quote
Old 01-14-2009, 10:08 PM   #9
Growser
Growser is on a distinguished road
Growser's Avatar
Start by cleaning the module and where it touches the transmission and replacing the hold down bolts. It doesn't take much to corrode them, and there's blue thread sealer on them. Replace all 4 spark plugs with NGK plugs and a medium price set of spark plug wires.
7 Saturn Car Family with + 900,000 miles.
2002 SL2, 2000 SL1, 1997 SC2, 1997 SC1, 1996 SC1, 1994 SC2, and now a 93 SC2 project car.
Add to Growser's Reputation
Rate the quality of this post and help Growser reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Growser is offline   Reply With Quote
Old 01-15-2009, 12:26 AM   #10
WadeNKC
Idea Re: Coil packs on 1998 Saturn SL2. Any body know?
The eighth digit in the the VIN is an "8".
Old 01-15-2009, 12:42 AM   #11
Dr B
Dr B is on a distinguished road
Dr B's Avatar
1992 SL2
1993 SL2
You have a S O H C multiport (8),the dual cam DOHC is (7) in vin.
Have A Great Day , it is YOUR choice !
Add to Dr B's Reputation
Rate the quality of this post and help Dr B reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dr B is offline   Reply With Quote
Old 01-15-2009, 01:30 PM   #12
Then your car is not an SL2. What is in the fifth position of the VIN?
Add to madpogue's Reputation
Old 01-20-2009, 11:43 AM   #13
WadeNKC
Question Re: Coil packs on 1998 Saturn SL2. Any body know?
The 5th position is an " F". The people at saturn told me that it was an sl2.
Hum, if its not i am going to have to get my insurance card changed. if its not an sl2 than what is it? maybe just an sl?
any thoughts?
Old 01-20-2009, 11:48 AM   #14
Low Saturn
Low Saturn's Avatar
2000 SC2
any thoughts?
Its an automatic SC1 if its a coupe, a manual SL if its a sedan.
E--SC1 (Man)
F--SC1 (Auto), SL (Man)
G--SC2 (Man), SW1 (Man), SL1 (Man)
H--SC2 (Auto), SW1 (Auto LHD), SL1 (Auto)
J--SW2 (Man), SL2 (Man)
K--SW2 (Auto 93-99), SL2 (Auto)
M--SW1 (Auto RHD)
N--SC1 (Man 3 Dr), SW2 (Auto 2000)
P--SC1 (Auto 3 Dr)
R--SC2 (Man 3 Dr)
Y--SC2 (Auto 3 Dr)
Mike
-2000 Saturn SC2
whys my '93 sl2 think its eating coil packs? fetchitfido S-Series Tech 1 07-31-2008 03:36 PM
coil packs paqrat S-Series Tech 3 06-02-2008 09:37 AM
coil packs quiksc2 S-Series Tech 3 05-28-2008 03:05 PM
Coil Packs and Throttle Body? d4rkf1ber S-Series Tech 2 10-02-2006 06:07 AM
coil packs wesley23 Mods and Performance 2 01-21-2004 09:50 AM
