Old 05-15-2010, 11:25 AM   #1
Super 8
Super 8 is on a distinguished road
2004 VUE Red Line
Default Awd rdm?
Hi, the AWD on my 04 Saturn Vue will make a ratcheting noise in the rear rather then engage while front is spinning on ice, is this normal?
I read a topic earlier about the RDM having problems, what is this?
Thanks Les......
Add to Super 8's Reputation
Rate the quality of this post and help Super 8 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Super 8 is offline   Reply With Quote
Old 05-15-2010, 11:40 AM   #2
chillin05VUE
chillin05VUE is on a distinguished road
chillin05VUE's Avatar
Default Re: Awd rdm?
Thanks Les......
Sorry Les, not normal. Sounds as if it's a dead one. Some may suggest that you change the fluid and see it that helps. Mine was making a horrible noise during regular driving. When the system engaged, I would get this noise like a cat was in a grinder at high speed. Then would get a burning smell after using it. Smelled like burnt rubber. Took it to Saturn and they told me the RDM was dead and that a new one would be 2k installed. IIRC, wasn't there a recall on the '04 and older awd VUEs for the RDM?
"Remember, if the women don't find you handsome, they should at least find you handy" -Red Green
2005 VUE V6 AWD
Add to chillin05VUE's Reputation
Rate the quality of this post and help chillin05VUE reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chillin05VUE is offline   Reply With Quote
Old 05-15-2010, 12:19 PM   #3
Super 8
2004 VUE Red Line
Is there a post/topic, type of oil recommended on doing this?
Recall?
Thanks Les....
Old 05-15-2010, 11:49 PM   #4
XRL
XRL will become famous soon enoughXRL will become famous soon enough
XRL's Avatar
2004 VUE Red Line
I think it was a TSB, and it was to basically neuter the RDM so it didn't activate as quickly.
I put RP Synchromax in my RDM, others have used Mobil 1 synthetic stuff and Pennzoil stuff. When was the RDM fluid last changed? If it's been a while, you might want to consider doing a drain/fill/drive/drain/fill regiment a few times to make sure its nice and clean in there. I'd probably do the drain/fills with something cheaper (ie the Pennzoil, though I think someone mentioned gear oil could work for the RDM) and then put a nicer fluid in at the end (ie Mobil 1 or RP).
Add to XRL's Reputation
Rate the quality of this post and help XRL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
XRL is offline   Reply With Quote
Old 05-16-2010, 08:28 AM   #5
newbievueowner
newbievueowner will become famous soon enough
2006 VUE Red Line
If it makes the noise just when the RDM engages (ie: front wheels are spinning) then it is likely somewhat normal. Both the RDM's that I have had in my Vue have both made some sort of noise when the AWD engaged.
Add to newbievueowner's Reputation
Rate the quality of this post and help newbievueowner reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
newbievueowner is offline   Reply With Quote
Old 05-16-2010, 10:00 AM   #6
Super 8
2004 VUE Red Line
Thanks everyone, I gather this is trans type fluid.
What does RDM stand for?
Old 05-19-2010, 06:38 PM   #7
newbievueowner
2006 VUE Red Line
Rear Drive Module I believe (or something very close to that)
Saturn Vue: The 250 HP tupperware
