#1 | ||||
![]() Join Date: Nov 2008
2004 VUE 3.5L
![]() The SES light came on in my Vue. The one with the car with the wrench inside of it. I called my shop and they told me it just needed to be reset.
What's the manual way to do this without a scanner?
#2 | ||||
![]() Join Date: Jan 2009
1996 SL1
![]() Don't know 100% if this will workon your car but on a lot of cars if you unhook the battery for and hour or to it will reset the ECU.
#3 | ||||
1993 SW1
![]() Are you sure you don't want your shop to read the code to see what's wrong?
I think that the light will turn off automatically after a certain number of driver cycles. My SES light did. Maybe drive it for a week. I will admit. Having a code reader really ROCKS! You can find them under $30. You can clear the code and see if it comes back.
#4 | ||||
![]() ![]() ![]() Join Date: Apr 2002
2002 VUE 2.2L
![]() The wrench light isn't an SES light.... it's completely different.
A code that is non-emissions related has been set - it could be anything from a short somewhere to a failing component in the body systems, transmission - anywhere. Why not spend a little bit of money, take it to a dealer to get it read (places like Autozone can't read wrench lights), and potentially save yourself more money down the road from something failing that could have been fixed early on? ~D.J.~ ... 2012 Mercedes Benz C250 Sport Sedan 2008 smart fortwo Passion Coupe 8/28/2008 - 3/12/2012 2002 VUE FWD4m - Gone but not forgotten. 5/14/2002 - 10/31/2011
#5 | |||||
![]() Join Date: Nov 2002
![]() Quote:
#6 | ||||
![]() Like previous posters have said, this is not a powertrain fault so it could be anything else, but not the engine and probably not the transmission. Ours came on when we had low brake fluid (pads were worn down)... about a week later the brake light also came on which alerted me to the problem. Changed the pads which re-filled the reservoir and it is off. It will also come on if you have a blown fuse or something (or an "intentionally blown" fuse due to the horn switch failed on)
... 2001 F-150 XL, 4.2 V6 5M 2002 Camaro Z28, 5.7 V8 6M, SLP Lid, Pacesetter LT's, Z06 wheels 2003 Vue FWD, 3.0 V6 5A RIP 1994 Civic DX Hatchback
#7 | |||||
![]() Quote:
Ditto on the comment. Trying to save a few bucks and not find out what the fault is may cost you big time if the problem fully manifests itself.
2002 SL1 - Which fuse do I pull to reset the SES light & computer? | 2002SaturnMan | S-Series Tech | 5 | 08-30-2009 07:46 PM |
How do I reset SES light? | lucy0076 | Vue General | 2 | 08-20-2009 02:55 PM |
SES light won't reset | jcono | Vue Tech | 1 | 01-20-2009 09:27 PM |
SES, not shifting out of 1st, reset PCM, all better. | randall flagg | S-Series Tech | 5 | 10-12-2008 07:53 PM |
How to reset SES on 97 SC1 | katefan0 | S-Series Tech | 2 | 09-02-2006 02:05 PM |
