Old 01-08-2009, 10:38 AM   #1
dabatman99
dabatman99 is on a distinguished road
Default 1999 Saturn SL2 Fuel Filter
Has anyone ever changed their fuel filter? Where is it located on this beast and how hard is it to change. What tools (special or not) will I need? Is the regulator built into these?
Add to dabatman99's Reputation
Rate the quality of this post and help dabatman99 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dabatman99 is offline   Reply With Quote
Old 01-08-2009, 10:45 AM   #2
1995sl1sohc
1995sl1sohc is on a distinguished road
1993 SL1
Default Re: 1999 Saturn SL2 Fuel Filter
It is bolted to the driver side of the engine compartment under the master cylinder next to the trans, and can be a little bugger to change. No special tools required and I can't recall offhand what size the nuts are.
Add to 1995sl1sohc's Reputation
Rate the quality of this post and help 1995sl1sohc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1995sl1sohc is offline   Reply With Quote
Old 01-08-2009, 10:52 AM   #3
paulo
paulo will become famous soon enoughpaulo will become famous soon enough
Check the "How to Library" near bottom of the forum classification page. Richpin has done a video about changing a fuel filter. Very easy to follow.
The nice part is that he walks you through the steps on how to depresurize the fuel line so you don't have pessurized gas escaping when the filter line is opened up.
Add to paulo's Reputation
Rate the quality of this post and help paulo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
paulo is offline   Reply With Quote
Old 01-08-2009, 11:17 AM   #4
Yours is a combination filter/regulator and it is located inside the frame rail on the left side back by the fuel tank. See the How To Library for the video to change this.
If you use anything but the OEM Saturn filter you can expect fuel pressure problems and all of the grief that causes. You can order one from Get Saturn Parts.
http://www.trademotion.com/splash/in...?siteid=214643
The part number is 21009427
Put the part number in the box and leave the top part alone. Hit search and you will be there.
The filter/regulator is recommended for service at 100,000 miles and will function past that mileage.
Old 01-08-2009, 12:02 PM   #5
dabatman99
So it's not under the master cylinder then? Is it a big job?
Old 01-08-2009, 12:12 PM   #6
No, but its a bit pricey. The first post in the How-To Library has an index and links to the richpin DIY videos. There is a detailed video of the filter change job.
Old 01-08-2009, 12:14 PM   #7
dabatman99
The filter in the video, is that what the SL2 fuel filter will look like? You say you can get over 100,000 miles? The car has about 140,000 miles. Do you think I should leave it alone?
Old 01-08-2009, 01:18 PM   #8
The decision to leave it alone is based on the weather and whether you have a heated place to work as it is a not fun place to work in the snow or gravel. Nd those 2 little bolts that hold the plastic bracket tend to break off. So, you have to be prepared for that. the fix is to drill 2 nice new holes in the frame and run in a couple of #14 self drilling sheet metal screws. If you have sharp drill bits this is not a problem. You can also drill out the broken bolts but that is a larger PITA.
Changing the filter is easy.
My thought is that if you are not having any symptoms of fuel pressure of flow problems, leave it alone. The ones I have cut up were perfectly fine and much older and over 160,000 miles.
Buy the Harbor Freight fuel pressure tester for 13.00 and check the fuel pressure. If its OK then save filter/regulator replacement for the day you have nothing else to do. The HF item number is 92699, this is cheaper than the filter/regulator and its the regulator that will eventually fail first, unless you pump your gas out of a dirty tank and there is a filter in every gas pump in these days.
Old 01-08-2009, 02:15 PM   #9
dabatman99
Just bought one! That is a great tool to have as I can use it on other vehicles too. I'll hold off on the filter unless I get a good reason to change it. They're quite expensive ($90 from the site u suggested) and fram filter/regulator is $70.00
Old 01-08-2009, 02:20 PM   #10
1995sl1sohc
1993 SL1
Nope. Sorry, I think they moved it to where Old Nuc said it is in 1998 so I was a couple years off.
Old 01-08-2009, 02:32 PM   #11
I have not tried the FRAM copy but if it works as good as the other aftermarket filter/regulators it will just end up adding the purchase price to the price of the OEM you get to buy to fix the problems the FRAM copy caused.
Its 85.00 + the 7.95 to ship it and it comes with the plastic clips and a new hanger bracket. Its a new year and the price went up. That's why the tester is a good idea.
The fuel pressure should be in this range. Key On Engine Off 45-51 psi and if its not then you get to deal with the filter/regulator.
Old 01-08-2009, 03:39 PM   #12
Low Saturn
Low Saturn's Avatar
2000 SC2
This is only true on 1991-1997's. 1998-2002 is in the back next to the tank. And costs a lot more $$$$.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 01-08-2009, 07:51 PM   #13
dabatman99
Thank you gentlemen, especially you OldNuc, you have all saved me time and have pointed me in a good direction. I love these forums, I just wish the internet was around 20 years ago, imagine where we would all be now!
Old 01-08-2009, 09:11 PM   #14
Telnet and Tymenet existed in the early 80s and single line BBS. But the graphics did not start to show till the 90s. Its a good example of exponential growth though.
Old 01-09-2009, 12:52 AM   #15
Growser
Growser is on a distinguished road
Growser's Avatar
For what it's worth I shy away from Fram. I have had very good luck with the Wix fuel filter from RockAuto. You have to reuse the bracket and clips, but it's only $55.79 before shipping. Here's the link http://www.rockauto.com/catalog/x,ca...,parttype,6200 and you can use discount code 13418151044670 to save 5%. Just use this number where it asks where did you hear about RockAuto at checkout.
7 Saturn Car Family with + 900,000 miles.
2002 SL2, 2000 SL1, 1997 SC2, 1997 SC1, 1996 SC1, 1994 SC2, and now a 93 SC2 project car.
Add to Growser's Reputation
Rate the quality of this post and help Growser reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Growser is offline   Reply With Quote
Old 01-09-2009, 01:01 AM   #16
I used the same filter and had 58 psi key on engine off fuel pressure and a P0172. You might want to check your fuel pressure.
Old 01-09-2009, 06:17 AM   #17
Maritime Storm
Maritime Storm has a spectacular aura aboutMaritime Storm has a spectacular aura about
Maritime Storm's Avatar
2003 ION-2 Sedan
Old Nuc their is 2 versions of that filter, the one for the 2.2L Flex fuel is set at a higher pressure. The right aftermarket one is actually available through GKIndustries, Part#GF1846. If you use the 2.2L you will suffer from much higher fuel pressure. NAPA among others stocks the proper one.
Save the Earth, Ban Slushboxes!!!!!
Add to Maritime Storm's Reputation
Rate the quality of this post and help Maritime Storm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Maritime Storm is offline   Reply With Quote
Old 01-09-2009, 10:47 AM   #18
That does come up as the correct part. Also crosses to a WIX 33931. Neither one is listed at RockAuto and FRAM does not list a cross either so this is most likely the right part.
Good information.
1999 Saturn SL2 Fuel Filter replacement rquirosaz75 S-Series Tech 19 07-13-2012 09:10 PM
smells like fuel vapors under hood of 93 SL2. Cheap fram plastic fuel filter? 2003MercMaraude S-Series Tech 2 10-17-2008 06:29 AM
1999 SL2 Cabin Filter? DecayingOmega S-Series General 4 08-20-2006 11:52 PM
SL2 Fuel Filter thrax S-Series General 15 07-07-2005 03:14 PM
1999 SL2 fuel filter??! mcphian S-Series General 9 02-14-2005 01:37 PM
