Astra General Photos
by fotc13
Astra - Member Photos
229 photos
77 comments
by ZippysMom
229 photos
77 comments
by AstraLover
229 photos
77 comments
by Black vxr
229 photos
77 comments
Old 01-04-2009, 04:46 PM   #1
hoody123
hoody123 is on a distinguished road
Default Hazard lights won't turn off (and I didn't turn them on!)
So, I went out to snowblow my driveway (yet again!) and when I head out I notice the hazard lights on my Astra are blinking. That's funny cause I'm pretty confident I didn't turn them on (in fact, I'm not sure that I've EVER turned them on). So, I truck back into the house grab my keys, unlock the car and try to turn them off. NOTHING DOING!
I can't get my friggen hazards to turn off, I've tried taking it for a quick spin (don't know why that'd do it, but I'm just) and turning them off, that didn't do it. Obviously just pressing the button doesn't do it. I found an entry on this site indicating to pull the negative terminal from the battery and leave it off for a bit, tried that, to no avail.
Onstar's got nothing. So now it sits in my lane with the battery disconnected. I guess I can head to the dealer tomorrow, but that's a pain the butt and it means that I'll have to take some time off work.
I'm hoping some of you knowledgable fans have some suggestions for me...
Don't know whether it's at all relevant or not but it's just rolled over 20k. The only other problem that I've experienced (although never had looked at) was a couple of times my cruise control just flat out wouldn't set. I use cruise ALL THE TIME, so it's not like I'm not familiar with how to set it. That just resolved itself after about 10 minutes of driving. It's happened twice...
Add to hoody123's Reputation
Rate the quality of this post and help hoody123 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hoody123 is offline   Reply With Quote
Old 01-04-2009, 11:17 PM   #2
mart
mart is on a distinguished road
2008 Astra XR
Default Re: Hazard lights won't turn off (and I didn't turn them on!)
The brake pedal needs to be pressed at least once for your cruise to be able to engage.
I don't see what was the logic behind this engineering solution though...
Add to mart's Reputation
Rate the quality of this post and help mart reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mart is offline   Reply With Quote
Old 01-05-2009, 07:53 AM   #3
dubstyl86
dubstyl86 is on a distinguished road
Get into your manual and see if the hazards run on an independent fuze.
Add to dubstyl86's Reputation
Rate the quality of this post and help dubstyl86 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dubstyl86 is offline   Reply With Quote
Old 01-05-2009, 09:40 AM   #4
andrew-astra
andrew-astra is on a distinguished road
2008 Astra XE
Pull the Hazard relay/ flasher unit?
Add to andrew-astra's Reputation
Rate the quality of this post and help andrew-astra reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
andrew-astra is offline   Reply With Quote
Old 01-05-2009, 05:58 PM   #5
hoody123
Well, an update. I left the battery terminal disconnected all night and when it was reconnected this morning - still flashing. My wife took it to work this morning in order to take it to the dealer later in the day. She of course disconnected the battery while in at work and when she came out to take it up to the dealer - POOF! No more flashy lights. Frustrating to say the least, but the dealer didn't want to see it after that.
I'll keep you posted if it happens again...
Old 01-05-2009, 07:42 PM   #6
SaturnRaycer
SaturnRaycer is on a distinguished road
SaturnRaycer's Avatar
2008 Astra XR
Based on what you're telling us I'd suspect two different failures. The flashers are controlled by the steering column module (SCM), but the cruise control is managed by either the Body Control Module (BCM) or the transmission control module.
Rex
2008 Astra XR
5 dr, 5 spd, sport package
Black Sapphire
If you're going to wave, use all your fingers.
Add to SaturnRaycer's Reputation
Rate the quality of this post and help SaturnRaycer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnRaycer is offline   Reply With Quote
Old 01-16-2009, 10:20 AM   #7
Daredevil6534
Daredevil6534 is on a distinguished road
theres a single fuse in the front box and another in the passanger kick panel box
Add to Daredevil6534's Reputation
Rate the quality of this post and help Daredevil6534 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Daredevil6534 is offline   Reply With Quote
Old 01-18-2009, 02:35 AM   #8
AstraXR
AstraXR is on a distinguished road
AstraXR's Avatar
2008 Astra XR
Idea Re: Hazard lights won't turn off (and I didn't turn them on!)
Hi there!
I will try to help.
hazard switch --> Instrument panel cluster --> Under hood electrical center -->Rear electrical center. That's the ''path'' of the signals to turn the hazard ON.
When you ground the hazard switch, it's send a signal. The ground wire is behind the cluster. So, logically, it should be a defective switch or the wire that goes to the switch is cut or shaffed and ground before it goes to the hazard switch, but that pretty unusual for a car that is pretty young! When the hazard light come on, without your request, if you disconnect the switch and
the lights goes OFF, then it's the swtich, if not........
Will be glad to hear from you the problem when the dealer fix it.
Good luck!
Add to AstraXR's Reputation
Rate the quality of this post and help AstraXR reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AstraXR is offline   Reply With Quote
2002 L200 - Hazard/Turn Signals not working. Plus driver's side brake light. gorollover L-Series Tech 1 04-09-2009 05:47 AM
91 sl2 turn signals hazard not working speed racer S-Series Tech 0 03-19-2009 03:59 PM
91 sl2 turn signal/hazard not working speed racer S-Series Tech 1 03-12-2009 07:26 PM
Turn by Turn Nav. / Hands Free Calling LeeNY Aura General 6 07-05-2008 11:06 AM
Turn Signal / Hazard Light Problem BladeOfAnduril S-Series Tech 4 02-13-2008 04:09 PM
