Old 10-26-2002, 04:06 PM   #1
Mark G
Mark G is on a distinguished road
Default Question on replacing differential cover gasket ( non-Saturn question)
I have reveived great technical help from you guys before on my Saturn, now I have a question on my brothers truck. I will be helping my brother replace the rear differential cover gasket on his Nissan Frontier truck. Is it as easy as removing all of the cover blots, cleaning the surfaces, putting on the new gasket and re-torquing the blots? I just want to make sure something inside doesn't pop out of place when I remove the cover.
Add to Mark G's Reputation
Rate the quality of this post and help Mark G reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mark G is offline
Old 10-26-2002, 04:14 PM   #2
Default
Unless it is dramtically different than any other rear wheel drive car out there no. If it has the cover on the rear of the rear diff with the ring of bolts around then yes, remove bolts, remove cover, clean everything well and reinstall and refill with new fluid as recommended by Nissan (in regards to type of).
Add to ssicarman's Reputation
ssicarman is offline
Old 10-26-2002, 06:32 PM   #3
wolfman
wolfman's Avatar
Default
I will only add to be sure to completely degrease the cover to housing mating surfaces with some "Brake Clean" or similiar product to ensure the new gasket and sealer will bond and seal.
Add to wolfman's Reputation
wolfman is offline
Old 10-27-2002, 12:50 AM   #4
Maritime Storm
Maritime Storm has a spectacular aura aboutMaritime Storm has a spectacular aura about
Maritime Storm's Avatar
2003 ION-2 Sedan
Default
Nissan Pickups{memory serving me correctly} use the removable carrier type rear ends{the differential mounts into a holder then bolts into the front of the rear axle}? If so you'll have to remove the axles, they should have pressed on bearings at each wheel & have retainers at each wheel that will have to be unbolted to remove them from the axle tubes. The axles will have to come out before you can remove the differential carrier. If you don't have a manual, get one. This type of rear end requires precise torquing of the bolts in order to avoid leaks & potential damage to the differential. The asian manufacturer stuck with this design because it is stronger & easier to adjust then the integral design that the Big Three use.
Save the Earth, Ban Slushboxes!!!!!
Add to Maritime Storm's Reputation
Rate the quality of this post and help Maritime Storm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Maritime Storm is offline
Valve Cover Gasket Question OU812 S-Series General 5 05-02-2009 11:24 AM
Currently replacing valve cover gasket - question giants55 S-Series Tech 2 10-23-2008 01:53 PM
Simple Valve Cover Gasket Question ... DieselPaul1980 S-Series Tech 17 12-01-2005 04:44 PM
Question about a valve cover gasket job the_new_raceman S-Series Tech 23 03-11-2005 08:22 AM
Valve cover gasket question Silver02ex S-Series General 1 06-28-2004 01:05 AM
