Old 12-27-2008, 10:56 PM   #1
timb99
timb99 is on a distinguished road
Default 2005 Ion Won't Start When Cold
Daughter is home from college, and tells me that occasionally, when its really cold outside, her Ion (2005 5-speed) won't start.
Happened to me in the driveway a couple days ago.
Everything looks fine, but when I turn it to crank, it won't crank. All the dashboard lights are on, and everything looks OK. Its almost like what happens when you try to crank the engine without the clutch fully depressed.
She says she'll try it early in the morning, and when it doesn't start, she'll try later in the day after the weather has warmed up a little, and it will crank and start fine.
Suggestions?
Add to timb99's Reputation
Rate the quality of this post and help timb99 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
timb99 is offline   Reply With Quote
Old 12-27-2008, 11:16 PM   #2
Default Re: 2005 Ion Won't Start When Cold
This one of several threads covering ignition switch issues and replacing it; http://www.saturnfans.com/forums/showthread.php?t=92569
Old 12-28-2008, 08:26 PM   #3
timb99
Thanks,
I'll give it a try.
Old 01-01-2009, 09:38 PM   #4
mrice2311
mrice2311 is on a distinguished road
2005 ION-2 Sedan
I have a 2005 Ion that had the same problem. I changed the ignition switch as detailed on this forum and it now starts fine all of the time. The part cost about $32 at Saturn and it took me about 1 hour, including resetting the pass lock.
Add to mrice2311's Reputation
Rate the quality of this post and help mrice2311 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mrice2311 is offline   Reply With Quote
2005 Saturn Ion Difficult to Start rotty john Ion Tech 3 02-23-2009 05:04 PM
2005 ION cold air intake prob? help blackbullet Ion General 23 01-08-2009 08:10 PM
Cold Start Engine Noise 2005 Ion2 kbg1 Ion General 7 10-14-2006 02:34 PM
2005 Ion - have trouble starting on Cold mornings. Alant2b Ion Tech 12 01-24-2006 12:55 PM
Cold Air Intake for 2005 Ion sedan trasher Mods and Performance 3 01-11-2005 10:32 PM
