Old 12-27-2008, 04:55 PM   #1
travisj027
travisj027 is on a distinguished road
travisj027's Avatar
2002 SC1
Default How do you drain a radiator on a Saturn SC1 2002?
Just wanted to know because I have no clue.
Add to travisj027's Reputation
Rate the quality of this post and help travisj027 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
travisj027 is offline   Reply With Quote
Old 12-27-2008, 06:17 PM   #2
Default Re: How do you drain a radiator on a Saturn SC1 2002?
There is a little plastic drain valve on the bottom right corner. It breaks real easy. Best way is to remove the lower radiator hose. The valve is hard to get at from either above or below.
Old 12-27-2008, 06:34 PM   #3
mr18436572
mr18436572 is on a distinguished road
2000 SL2
i also find it easier to disconnect the radiator hose
2000 SL2 auto - 167k - sold
1996 SL2 auto - 161k - sold
1997 SC2 auto - 105k - sold
2000 SC2 auto - 117k - sold
1996 SL2 auto - 250k - sold
2001 SC2 5sp - 160k - sold
Add to mr18436572's Reputation
Rate the quality of this post and help mr18436572 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mr18436572 is offline   Reply With Quote
Old 12-27-2008, 11:07 PM   #4
Lower rad hose is higher than the rad drain.
Add to ssicarman's Reputation
Old 12-28-2008, 12:04 AM   #5
eRic 02sc2
eRic 02sc2's Avatar
Wrench Re: How do you drain a radiator on a Saturn SC1 2002?
http://www.autozone.com/shopping/rep...00c1528017e62e
DRAIN & REFILL
Make sure the engine is cool and that the vehicle is parked on a level surface, then remove the surge tank pressure cap.
Position a large drain pan under the radiator drain plug on the right side of the radiator and engine drain plug under the right front of the block.
Open the radiator drain and remove the engine drain plug, then allow the coolant to drain from the system.
Close the radiator plug and install the engine plug to the cylinder block. Tighten the engine drain plug to 26 ft. lbs. (35 Nm).
Fill the system through the surge tank using a mixture of water and the recommended type of antifreeze.
Start the engine and check for leaks.
After the engine has run for 2 or 3 minutes, add coolant as necessary to bring the coolant level to the surge tank FULL COLD line.
Install the surge tank pressure cap.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 10-29-2014, 10:51 AM   #6
strnlvr
strnlvr is just really nicestrnlvr is just really nicestrnlvr is just really nicestrnlvr is just really nice
2000 SC1
how do you bleed the air out though, or burp?
Add to strnlvr's Reputation
Rate the quality of this post and help strnlvr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
strnlvr is offline   Reply With Quote
Old 10-29-2014, 11:43 AM   #7
Happens automatically. Much nicer than my Subie's that you have to jack up the front end so the radiator cap is higher than the rest and hope for the best and not as nice as my dad's '95 Oldsmobile that has 2 bleeder screws for the cooling system.
Old 10-29-2014, 03:58 PM   #8
Yeah, I like the Saturn design. Surge tank/reservoir is at a high point, so it is self purging.
Old 10-29-2014, 04:50 PM   #9
54packman
54packman will become famous soon enough
1998 SW2
2000 SC2
there is another Block drain bolt in the bottom of the thermostat housing too
Add to 54packman's Reputation
Rate the quality of this post and help 54packman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
54packman is offline   Reply With Quote
Old 10-29-2014, 06:10 PM   #10
Yup, simple, reliable system; pressurized reservoir at the high point, level in the reservoir reflects the coolant level of the whole system. Easy visual check. Coolant is never exposed to "the outside world". Our two Ford pickups use the same design; they actually refer to the reservoir as a "de-aeration" tank or degas bottle (although I have no idea what it has to do with French Impressionism...). Kind of astonishing how many owners of these trucks get confused when they can't find the "radiator cap"....
Block drain is about at the same low point as the radiator petcock, but it drains the block, not the rad. Depends on the OP's intent; if it's just for a radiator R&R, and retaining the coolant in the block, the petcock is a better choice. Also, even if the petcock is vulnerable to breaking, so is the block drain, and the consequences with the block drain plug breaking are, um, well, more complicated.
Add to madpogue's Reputation
Radiator drain plug wishihadacamaro S-Series Tech 6 11-15-2008 11:27 PM
radiator drain valve GROVERBOY S-Series General 11 09-29-2008 12:00 AM
radiator drain valve saturnsctwo S-Series General 13 05-12-2007 03:58 PM
Radiator Drain _PuNiShEr_ S-Series Tech 5 04-03-2006 04:53 PM
How much coolant in the if I drain the radiator johnyrrr S-Series General 3 10-17-2005 12:52 PM
