Old 12-26-2008, 06:58 PM   #1
Kristine
Kristine is on a distinguished road
Default Headlights keep going off, and need to tap lens to turn on...
Sigh....it wasn't so bad when the weather was warm, but here in Manitoba, it's been COLD lately.
The right lowbeam light has been replaced, but it seems to be shorting out or something. If you tap the headlight lens in the right place, it will come back on. Now it's happening with the left light, too.
It is a 1995 SL1.
Any help would be greatly appreciated, cause right now, I have no clue.
Thank you!
Kristine
Add to Kristine's Reputation
Rate the quality of this post and help Kristine reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Kristine is offline   Reply With Quote
Old 12-26-2008, 08:00 PM   #2
jts749
jts749 is on a distinguished road
jts749's Avatar
Default Re: Headlights keep going off, and need to tap lens to turn on...
have you tried new bulbs?
Add to jts749's Reputation
Rate the quality of this post and help jts749 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jts749 is offline   Reply With Quote
Old 12-26-2008, 08:28 PM   #3
dorisSL
dorisSL is on a distinguished road
dorisSL's Avatar
1995 SL
could be a ground issue. my fogs are doing that right now, and i know they have a ground issue (my fault. waiting for the snow to clear to fix 'em)
1995 SL, born 12/23/94, manual, WAI 190,500, "Doris"
(I'm Ben, the car is Doris)
you can't mulch at those speeds man, that's too fast
Add to dorisSL's Reputation
Rate the quality of this post and help dorisSL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dorisSL is offline   Reply With Quote
Old 12-27-2008, 12:24 AM   #4
Kristine
Now that you mention it, the problem DID start when we changed out the right bulb last Christmas. But we haven't touched the left, and it's doing the same thing. I guess we'll have to open it up and check the grounding.
Old 12-29-2008, 08:17 AM   #5
OnDaGround
OnDaGround's Avatar
1993 SC2
Check the connector... its just probably not plugged in all the way.
Saturnless...
Old 12-29-2008, 10:27 AM   #6
Uzzy
Uzzy's Avatar
2002 SC1
The extreme cold is likely causing the issue. The ground is not great, so the cold is making things worse. Could be a loose connection,or wire somewhere.
Aut viam inveniam aut faciam
Add to Uzzy's Reputation
Headlights won`t turn off michael1944 L-Series Tech 1 05-12-2009 08:51 AM
Turn signal lens coolcat2 S-Series General 9 09-08-2008 11:13 AM
Headlights won't turn off cruzr S-Series General 10 07-11-2006 06:04 PM
Headlights Lens`s Ken A Relay General 0 09-03-2005 11:45 AM
Headlights (How do I turn the darn things off) stormcrow Vue General 57 05-05-2005 06:11 PM
