Old 12-14-2008, 11:30 PM   #1
dgoodgion22
dgoodgion22 is on a distinguished road
Dizzy hardwiring leds
I was wanting to hard wire some led lights to the battery that connects to a three prong switch.
How do i go about doing this?
I have wire through the fire-wall but don't know how to hook it up to the battery.
I am new to this so don't be too hard
Add to dgoodgion22's Reputation
Rate the quality of this post and help dgoodgion22 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dgoodgion22 is offline   Reply With Quote
Old 12-15-2008, 12:02 AM   #2
Default Re: hardwiring leds
Going to need a bit more data. What exactly are you trying to do? Where did you get the LEDs and do they have a built in resistor?
Old 12-15-2008, 12:40 AM   #3
saturnsctwo
are you referrring to those under car lights that look sort of bluish that make the car look like it's floating?
i seen a motorcycle lit up like that parked at a carnival last year & i thought to myself he has a lot of balls to do that after all it's sapping the battery for hours. it would suck not being able to start his bike & it was a big bike not easy to push start. never the less it looks cool... if that's what your doing you would have to connect them to the battery & run the switch wires through the firewall to turn them on & off. good luck....
Old 12-15-2008, 12:47 AM   #4
banditkaine
banditkaine is on a distinguished road
banditkaine's Avatar
Assumin the LED's have resistors already and are rated for 12V, you would need 2 wires! One for + and one for -, Don't connect anything to the battery until you have everything else already wired! You should also disconnect the negative terminal on the battery.
LED's are polarised, so they will only work if the the + on the LED is wired to the + on the cable.
Get 1 cable for + and attach one end to the battery (at the end) and the other end to the + side on the LED, get another wire and attach it to the other end of the LED and then to one contact on the switch.
Get a 2nd piece of wire and attack it to ground (any metal piece on the car) and attach the other end to the other contact on the switch.
That's it, turn the switch on and watch the LED's glow. For extra security you can add a small fuse anywhere in between the + side of the cable.
Why is your switch 3 prong anyway? a 2 prong switch would have worked just fine.
If you don't understand anything please ask before attempting.. electrical system in a car can easily be damaged if you screw up.
Use a 2AMP fuse just incase.
Here is a simple diagram i just drew for you, Remember this is assuming the LED's are rated 12V already.. if you just got bare LED's from radio shack or something then you will need resistors and that's a whole different story which i can help you with aswell.
Add to banditkaine's Reputation
Rate the quality of this post and help banditkaine reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
banditkaine is offline   Reply With Quote
footwell leds zpurdy S-Series Mods 6 06-13-2013 09:32 PM
more LEDs! dorisSL S-Series Mods 21 12-13-2008 04:25 PM
Hardwiring a radiator fan ecaryn S-Series Tech 3 10-07-2008 10:56 AM
best 12v aux power for hardwiring dragon370 S-Series Tech 4 04-01-2007 01:13 AM
LEDs mkapp S-Series General 10 01-20-2006 10:00 PM
