Old 12-09-2008, 08:34 AM   #1
mikem60525
mikem60525 is on a distinguished road
Mad Having problems after a rebuilt trans.
Hey folks-
Info:
1999 SC2 74,000 Auto trans
I had a code come up for the first gear in my trans being bad (I don't remember it now). I had a rebuilt trans put in because of cost and the age of the car. Now, my car vibrates and runs rough while in gear at idle. It ran great before this.
I am bringing it back to the trans place to have them take a look at it. any ideas what the problem is so I can tell them specific things to look for?
Thanks....Mike
Add to mikem60525's Reputation
Rate the quality of this post and help mikem60525 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mikem60525 is offline   Reply With Quote
Old 12-09-2008, 09:20 AM   #2
OnDaGround
OnDaGround's Avatar
1993 SC2
Default Re: Having problems after a rebuilt trans.
Is the idle high? Who installed it, and are the mounts bad?
Saturnless...
Old 12-09-2008, 10:35 AM   #3
1995sl1sohc
1995sl1sohc is on a distinguished road
1993 SL1
Definately have them double check all the engine and transmission mounts.
Change ECTS if it's plastic, you never know it may have failed.
Add to 1995sl1sohc's Reputation
Rate the quality of this post and help 1995sl1sohc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1995sl1sohc is offline   Reply With Quote
Old 12-09-2008, 04:27 PM   #4
mikem60525
They did charge me for a mounting bracket too. Idle isn't high, just rough. I brought it back the next day and they put up on the lift. I thought it sounded at first like the exhaust system was touching the frame. But, It wasn't.
I left thinking maybe it just needed to wear itself in.... I never had trans work on any of my cars before this....except a clutch on a manual trans. This is a auto trans.
Please let me know what else I can point the problem at...
Thanks, Mike
Old 12-09-2008, 05:00 PM   #5
OnDaGround
OnDaGround's Avatar
1993 SC2
Hard to say, let them do what they do, but if they say something seperate is bad, go look at it so you can make sure its really bad.... You don't want something they did to cost you. Be a dick about it.
Saturnless...
Old 12-09-2008, 07:17 PM   #6
mikem60525
Is there something possible that they didn't do right between the trans and engine?
Are there any vacuum system lines on these cars? It's almost like the old cars when a vacuum line was disconnected.
No Voltage to IACV + Trans problems...Replace Computer or Trans Val Body or Both ialonso S-Series Tech 1 05-22-2009 03:23 PM
For those who have rebuilt SL auto trans' - any special tools? 2003MercMaraude S-Series Tech 2 06-18-2008 04:10 PM
Trans problems ! slo2go S-Series General 3 09-30-2005 09:36 AM
Rebuilt Trans still no reverse - what next? SaturnNewby S-Series Tech 7 02-04-2005 09:28 PM
Engine rebuilt: Serious Problems SIYAM S-Series Tech 26 07-17-2002 07:35 AM
