Old 11-15-2008, 05:51 PM   #1
triple_el
triple_el is on a distinguished road
Default pop-up headlight mod
I have a '93 SC2, and the headlight covers are really beat up (dented/rusty) I was originally going to replace them, but I was thinking... I don't really like the pop-up headlights anyway. So while I was scouring the forums for alternatives, I came across this image:
I know that's a probe converted from pop-up to fixed-position headlights, but I'm not looking for a "how-to", I'm looking for advice.
I want to make a cover like that for my SC2 headlights. My dad** thinks I should be able to use a flat sheet (since the covers are essentially flat anyway) of tempered glass, plexi, or what-have-you... My question is whether or not I need a full enclosure... I don't know much about headlights, but I believe you can buy small sealed projector bulbs, so I wouldn't need to build a reflector for my cover. So I would essentially be removing the pop-up bracket and cover, and attaching a clear cover in the place of the stock covers. Then, I would make a bracket for the sealed bulbs and not care that water can leak around the sides of the cover. That would be my first choice.
Otherwise, I'm thinking that I'll have to make a fully-enclosed headlight assembly, which would be much more involved.
I haven't looked at the wiring harness yet, but I assume it won't be too difficult... I have a manual and my brother is an electrical engineer. I'm more concerned with the mechanical aspect of this project.
Anyone care to weigh in on this? I'm pretty much looking for bulb recommendations, logistical advice, and ideas on how I could attach my cover to the car sturdily without interfering with the aesthetics of the mod.
**Yes, I am only 17, but please don't hold that against me. I rebuilt this car's engine this summer and have been chipping away at the multiple problems it has. I'm quite determined, I just like bouncing ideas off other people.
Add to triple_el's Reputation
Rate the quality of this post and help triple_el reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
triple_el is offline   Reply With Quote
Old 11-15-2008, 08:18 PM   #2
rc1488
rc1488's Avatar
Default Re: pop-up headlight mod
If you make the glass part of the hood, then I think you should be alright. Make the lights permanent in place and have it so when the hood comes down, the plastic is right over the bulbs.
Heres the issue though. The angle may not be enough where the beam can project out. It may get clipped by the front bumber, since your bulb will almost 2-3in lower than the stock bulb. More investicating would have to be done.
You would have to get projectors also
Add to rc1488's Reputation
Old 11-16-2008, 02:51 PM   #3
PurdueGuy
PurdueGuy's Avatar
1999 SC1
The angle is a big obstacle. Find a way to measure the angle, and you can figure out how much space you have to work with. It's going to be tough. The only car I've seen/heard of that has done this, did it for show, and they didn't have enough room to really do it right. It looked good, but functionally the lights did a lot better at giving a clear view of the powerlines than the road.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 11-16-2008, 09:23 PM   #4
triple_el
This kinda shoots down the whole "affix the cover to the hood" idea, but would take care of the angle issue... reference this image:
Below the pop-up headlights, there is a rippled part on the plastic bumper cover. if I cut that out and extended the cover to there, it should provide enough clearance... I plan on installing clear corner lights, too... I would rather not do that, but if it's necessary, it's an option.
Can anyone recommend what kind or even a specific brand/model of headlamp to use for something like this?
Old 11-16-2008, 10:00 PM   #5
wishihadacamaro
wishihadacamaro is on a distinguished road
If the projectors are sealed then couldn't you just attach the plexiglass to the bumper once you cut off that little plastic piece on the bumper? Are the stock flip-up headlights flat on the top, or curved? If they are curved then you have to heat up the plexiglass and bend it into shape.
Add to wishihadacamaro's Reputation
Rate the quality of this post and help wishihadacamaro reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wishihadacamaro is offline   Reply With Quote
Old 11-17-2008, 01:14 AM   #6
coolcat2
coolcat2 is on a distinguished road
coolcat2's Avatar
2002 SL1
I belive I read that the owner of those headlight mods had access to a vacuum molder.
Add to coolcat2's Reputation
Rate the quality of this post and help coolcat2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
coolcat2 is offline   Reply With Quote
Old 11-17-2008, 01:18 AM   #7
plastic torpedo
plastic torpedo will become famous soon enoughplastic torpedo will become famous soon enough
plastic torpedo's Avatar
2000 SL2
1994 SC2
That's correct, and that would be my friend. He is thinking about making inexpensive molds for 1st gen SC2 owners as a side project, and my 94 SC2 would be a test mule.
2000 SL2 5-speed turbo
MSnS-E fuel & spark controlled @ 17-20 psi (methanol injected)
Fully forged, P&P head and manifolds, FSR turbo cams, balanced to 9k RPM
http://www.cardomain.com/ride/3070918
Add to plastic torpedo's Reputation
Rate the quality of this post and help plastic torpedo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
plastic torpedo is offline   Reply With Quote
Old 11-17-2008, 03:13 AM   #8
coolcat2
coolcat2's Avatar
2002 SL1
No more pop-up? I could be very interested!
Old 11-17-2008, 08:02 AM   #9
OnDaGround
OnDaGround's Avatar
1993 SC2
Have fun, let me know what happens, I thought about doing it once for a HID conversion, but I think I am just gonna go with what I got.
Saturnless...
Old 11-18-2008, 07:03 PM   #10
triple_el
Thanks! I admit, it's going to be a while until I get to this (probably until summer - I don't want to get rid of my pop-ups badly enough to do this in a Minnesota winter) but when I do, I'll try to document it and I'll certainly let you know how it turns out!
Old 11-18-2008, 11:16 PM   #11
quiksc2
quiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura about
quiksc2's Avatar
2002 L-Series 3.0L Sedan
I'd love a 1G coupe to make into a race-only car, and those pop ups are probably the worst thing about them. I was planning on cutting out right below the light...
If I wanted ride quality, I would drive a Cadillac. If I wanted to be a sheep, I would drive something that says Vtec on the side of it...
DCS
Add to quiksc2's Reputation
Rate the quality of this post and help quiksc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quiksc2 is offline   Reply With Quote
Old 11-19-2008, 08:05 AM   #12
OnDaGround
OnDaGround's Avatar
1993 SC2
ehh the car looks sexy with them down and like crap when they are up. When its just the parking lights on it looks great. Especially when the car is lowered with rims or something.
Saturnless...
Old 11-21-2008, 12:17 PM   #13
quiksc2
quiksc2's Avatar
A friend of mine had a Probe, and he just mounted some good fog lights, and never used his headlights...
DCS
Old 12-02-2010, 09:29 AM   #14
bigalpha
bigalpha will become famous soon enough
1997 SL1
Did you ever attempt this?
Add to bigalpha's Reputation
Rate the quality of this post and help bigalpha reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigalpha is offline   Reply With Quote
Pop up headlight issue... HELP!!!! ClosetGeek S-Series General 0 01-07-2008 10:28 AM
busted pop-up headlight Jeff P S-Series Tech 2 01-22-2003 03:41 PM
96 SC2 headlight doesn't pop-up Heartbeat - '95 SL2 S-Series Tech 7 10-26-2001 02:00 AM
Pop-up Headlight MOD Yobos4vr Classifieds 5 03-30-2001 01:49 PM
Pop-up Headlight Mod Yobos4vr Mods and Performance 6 02-28-2001 11:40 AM
